I can;t received faxes on my computer - Computers & Internet
    Scholar:
    New Friend:
  • 42 Answers
Are you using DSL connection or Dial-up?
What OS are you using?
The fax line and voice line are using the same frequency so you should be able to fax directly from your pc fax modem when using Dial up connection but in DSL the data and voice are using different frequency. So in normal situations you wont be able to fax using DSL modem unless you use a separate fax machine.
However, if specified during the set-up of the DSL line, the signal can be separated so that some of the bandwidth is used to transmit an analog signal (for voice and fax) while the remaining bandwidth is used to transmit digital data. This allows for the use of the telephone or fax, and computer on the same line and at the same time. When inquiring about DSL with the service provider, specify the desire to use the phone line for voice or fax calls while connected through the computer to the Internet.
Reference the following setup options for using a DSL line with HP all-in-one or fax products.
Please refer to my solutions to your issue at http://www.fixya.com/support/t1440518-want_able_fax_from_computer_even_though
PLEASE RATE MY SOLUTION.
Posted on Jan 19, 2009
Erase fax memory on epson workforce 3620
If you see an error message telling you that the product's fax memory is full, try these solutions:
  • If you set the product to save received faxes in the product's memory or inbox, delete any faxes you have already read.
  • If you set the product to save received faxes on a computer, turn on the selected computer. Once the faxes are saved on the computer, they are deleted from the product's memory.
  • If you set the product to save received faxes on a memory device, connect the selected memory device containing the save fax folder to the product. Once the faxes are saved on the memory device, they are deleted from the product's memory. Note:Make sure the memory device has enough available memory and is not write protected.
  • If the memory is full, try sending a monochrome fax using theDirect Sendfeature or sending your faxes in smaller batches.
  • If the product cannot print a received fax due to a product error, such as a paper jam, the memory full error may appear. Clear any product errors, then ask the sender to resend the fax.
May 24, 2017 | Epson Office Equipment & Supplies
Tip
Can I send and receive faxes from my computer ?
Yes. You can. You will need a telephone line, a modem and a scanner, along with your computer. And before you can send and receive faxes from your computer, you will need to install the fax component. This fax component is not installed in Windows XP by default.
How to install the Fax Component:
Go to Start Button -> Control Panel -> Add/Remove programs ->Click on Add/Remove Windows Components ->Click in the Fax Services check box and click Next. Now you will see a Windows Component Wizard, which will setup the Fax service in your computer. Make sure the modem and telephone line are connected to your computer, along with the Scanner.
Now you have to configure the Fax component in your computer. In order to do that, you have to go to the Fax Console which is located at
Start Button ->All Programs->Accessories->Communications->Fax ->Fax Console
fax_xp.gif In the Fax console, click on the Tools Menu and select Configure Fax - this will start the Fax configuration wizard. Click Next to start configuring the fax service in your computer.
Enter your Name, Your Company's name and your fax (Telephone) number on the Sender Information page.
Your modem will be selected under Select Device for Sending or Receiving Faxes - if you have more than one modem, you will have to select the correct device to send and receive faxes in your computer. You will also have to specify if the send and receive options - whether you will manually answer incoming faxes or if you want your computer to automatically answer them for you.
Remember to Enter your Company's Name and Fax Number under Transmitting Subscriber Identification(TSID) and Caller Subscriber Identification (CSID). These fields are very important.
Now, under Routing Options, you will need to specify where incoming faxes are going to be stored in your computer. You can specify a local folder or just let it go to the default location, which is the Fax Console.
You can change these settings anytime you want by running the Fax Configuration Wizard again from Tools -> Configure Fax.
Sending Faxes from Your Computer
You can fax any document that is stored in your computer. You can also scan a document and fax it by sending it to the Fax Printer in your computer.
To fax a document from your computer, Click on the File Menu of the document and select Print. Then under print (or Print Setup), select Fax in the Printer Name box. This will open the Send Fax Wizard. You can also use the option called Send To and select Fax Recepient if you are using MS Office.
As soon as you hear your computer dialing, the Fax Monitor (as shown in the image below) will start up
fax_monitor_xp.gif How to Fax Scanned documents:
Another way to send a fax from your computer is to scan documents and then fax it through your Fax Printer. This can be made possible by using your scanner software. You can also fax from a scanner using the tools provided by Windows XP.
For this, go to the Control Panel and click on Printers and Other Hardware, then select Scanners and Cameras and then, double-click on the icon for your scanner to start the Scanner and Camera Wizard.
Then, on the Choose Scanning Preferences page, click Grayscale Picture and then click Preview to start the scanner.
Provide a name and location for the scanned document.
Now, go to the saved image which you scanned just now and right-click on it and select print - This will start the Photo Printing Wizard.
Click on the check box for the image to be faxed and select Fax as the printer you want to use.
When you finish the Photo Printing Wizard, the Send Fax Wizard opens and you proceed as described in the procedure for sending a fax from your computer.
Faxing from MS Outlook:
You can also fax from MS Outlook by adding the Fax Transport Service as an email account.
Receiving faxes on your computer.
Remember, you have already specified where the incoming faxes should be located and also how you wanted the incoming fax calls to be answered -manually or automatically. The Fax Monitor opens up automatically when the modem detects an incoming fax.
To view an incoming fax, go to the Fax Console and click on Inbox. Double-click on the fax entry you have just received and it will open up in the Windows Picture and Fax Viewer. Fax files are images in TIFF format so they cannot be edited. But u can print it out or email it to anybody else as an attachment.
on Jul 06, 2010 | Computers & Internet
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Oct 31, 2016 | Computers & Internet
HP OFFICEJET 6500 SAYS NO COMPUTER CONNECTED WHEN RECEIVING A FAX, BUT PRINTS FROM THE SAME COMPUTER
to receive fax, you must connect the fax line to the printer. All-in-one printer can received fax without computer.
Sep 26, 2011 | HP Officejet 6500 Wireless All-in-One...
I cannot receive fax on my dell940 printer. help
The A940 is not a standalone fax machine, and needs to work with your computer to send and receive faxes. Your computer needs a dialup modem installed and a connection to a phone line, and you need to have fax software installed. The printer actually only works as a scanner to input a document to be faxed, and as a printer to display a received fax. The installation CD supplied with the printer has fax software on it you can install, and other software is available online. This document from Dell (the fax section of the user's guide) may be helpful.
Jul 29, 2011 | Office Equipment & Supplies
How to receive fax documents
You cannot receive fax using this printer, because this printer doesn't support fax sending/receiving. Only fax supported printers can receive fax documents. You will know if a printer is fax support if you see a Fax button there or if you can see a numpad buttons where you can dial numbers.
These are the photo examples of fax printers
Hope my solution helps. Thanks for using Fixya!
Jul 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
I can't recieve fax
The MP500 is not a fax machine. If you want to send and receive faxes using the printer, you need to have a dial-up modem in your computer with a telephone line connected. The computer then needs some kind of fax application like Microsoft Fax, which does the actual sending and receiving. The printer is just used as a scanner when you send, and to print received faxes.
If you have all this connected already and you can't receive, check your incoming telephone line and fax software settings to be sure the line is answering correctly.
Mar 03, 2011 | Canon Pixma MP500 All-In-One InkJet...
Using a Lexmark 3400 series to fax
Yes your printer will send and receive faxes. 1. Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. 2 Load an original document facedown on the scanner glass.
Here is the manual, in case you don't have one http://www.retrevo.com/d/ds/progress?doc=7d2128cd89431b0e3d4c2a1c31fa8fc4
3 From the desktop, double-click the Imaging Studio icon. 4 Click Fax. 5 Click Scan and send a fax. 6 Click Preview Now. 7 Click and drag the dotted line box to select a specific area of the preview image to fax. 8 Adjust the settings as needed. 9 Click Next. 10 Follow the instructions on the computer screen to complete the task. Receiving a fax using the software 1 Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. 2 From the desktop, double-click the Imaging Studio icon. 3 Click Fax.
Dec 05, 2009 | Cars & Trucks
Not receiving fax on my Lexmark X6570 coming from a computer
on a lexmark if someone send you a fax ,first the machine has to be in fax mode ,then when the phone start ringing you have to press the start button or #9 button
Oct 03, 2008 | Office Equipment & Supplies
My hp 3055 has not been receiving any faxes
The only thing that I can think of for you to do is to completly delete it from your computer & then re-download it. Only do this if you get no other resolution. Or you can call 1-800-474-7739 for hp technical support. I just did & they were a great help to me!
Jun 05, 2007 | HP LaserJet 3055 All-In-One Printer
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
