What is use of Jdbc or odbc driver? - Computers & Internet
    Scholar:
  • 67 Answers
Go through these links to get an overview of JDBC and ODBC:
http://en.wikipedia.org/wiki/Java_Database_Connectivity
http://en.wikipedia.org/wiki/Open_Database_Connectivity
Posted on Jan 17, 2009
I have to make minor project on java and i know core java and jdbc odbc connectivity will u please help me
It would probably be wise to post this on a Java forum (like this one, this one, or this one), as they will be able to help you better.
Alternatively, try Stack Overflow.
Feb 19, 2010 | Microsoft Windows XP Professional
How can i connect the data base during my project
That seems fine.
I cant assume your level of confidence in programming, however, following are some simple steps you can follow to achieve (for complex implementations, much more time and details will be needed, i can help u with them as well)
1. Create a database in Access ( i assume u r using Access 2003)
2. Create a System DSN (if aren't clear, how to create then goto administrative tools under control panel and you'll find Data Sources (ODBC), here u need to create System level DSN for Access driver (may be Jet 4.0+)
3. In java, you need to import java core libraries for sql (javax.sql package specially)
4. you are almost done, just google for database code in java, simple code will be around 5-10 lines (just for your reference, search with these keywords, ClassName(""), jdbc:odbc:YourDSN)
5. Open a connection using Connection object
6. Fetch the records (select query) using Recordset object
7. You're done.
thanks
Kuldeep
Mar 13, 2009 | HP Computers & Internet
How to make a connection with sybase using jtds driver
hi,
the first thing you need is the correct JDBC driver, that must be included with your database.
Then you need to create a connection using the driver.
This link could help.
http://www.redmountainsw.com/wordpress/archives/jdbc-connection-urls
regards
Mar 13, 2009 | Sybase SQL Anywhere Studio for Workgroups...
How to write jdbc connections
http://www.jdbc-tutorial.com/
window.google_render_ad();
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Feb 01, 2009 | Microsoft Windows XP Home Edition
How can i connect jdbc odbc to do my program
Create a System DSN in Windows XP loadTOCNode(2, 'summary');
  1. Click Start, point to Control Panel, double-click Administrative Tools, and then double-click Data Sources(ODBC).
  2. Click the System DSN tab, and then click Add.
  3. Click the database driver that corresponds with the database type to which you are connecting, and then click Finish.
  4. Type the data source name. Make sure that you choose a name that you can remember. You will need to use this name later.
  5. Click Select.
  6. Click the correct database, and then click OK.
  7. Click OK, and then click OK.
Jan 14, 2009 | Microsoft Office Professional 2007 Full...
I can't connect the ms-sql 2005 database with flex
hi this is jesica am expert to help you to fix this issue for you,kindly call me on +1(518)348-9393 and we will be glad to help you.
Sep 24, 2017 | Microsoft SQL Server 2000 Standard Edition...
I can't connect the ms-sql database with flex
It sounds like you don't have the proper authentication to access the SQL server from the error code you are receiving. I would ask you SQL DBA to check on the permissions within SQL and verify that you have the proper access rights to the database you are connecting too. It is SQL throwing that exception error...
Cheers!
J the Guru
Jun 27, 2017 | Microsoft SQL Server 2000 Standard Edition...
MyEclipse6.0.1 connection with sqlserver 2000
hi
Try with MS SqlServer 2005 JDBC Driver,
i had a similar problem with 2000 jdbc driver
Dec 03, 2007 | Microsoft SQL Server Standard Edition for...
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
