Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Water keeps dripping after it dispenses water thru the door
Side by side Frigidaire with ice & water dispenser and the water keeps dripping after I am done filling my cup with water. It clicks on & off but I have to keep a cup under it to catch the drips. Also drips some when ice trays fill with water.
  • 298 Answers
When you push the button, the CLICK you hear when the water flows is the Water delivery solenoid opening to let water thru, then snapping shut when U R done. The Spring is weak (prob wrong type, size, strength at factory) or the valve seal is cracked, torn, hardened or crushed.
Since all this is inside the door, you will either have to take it apart to see/fix/replace.
Quick fix: turn down the water pressure coming in(?)
Call Mr. Handyman to fix.
If under warranty - they might fix this for you for free
If this is a factory defect, there might be a recall in place for repair/replacement parts
Googlee both - Make/Model + Dripping Valve + Recall
Good Luck!
Posted on Jan 17, 2009
Frigidaire side by side FFHS2322MBKA ice maker stopped working, but still dispenses water
Change the Water Solenoid Valve. This is a dual solenoid valve, one side is for water thru the door ... the other side supplies water to the ice maker and probably is bad. good Luck! Handy Henry
Feb 17, 2017 | Frigidaire Refrigerators
Frigidaire water dispenser drips constantly. I have been told there is a main water valve and a second valve for the water dispenser. Where is it and how to replace?
if you are referring to the cold water on the door , then there is a solenoid valve on the bottom back left side of fridge, you will see two there , one is for ice maker and one is for water on door , most times it's a good idea to replace both of them , also there should be a filter inside fridge on bottom middle (cartridge) this should be changed monthly to maintain fresh taste and keep foreign objects out of tubes
Jun 01, 2015 | Frigidaire Refrigerators
Water dispenser leaks on model number KSRS25FGSS13. I HAVE FLUSH THE AIR OUT AND IT STILL HAS A VERY SMALL DRIP
Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser.
May 10, 2010 | KitchenAid Architect 25.3 Cu. Ft....
Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by side Frigidaire. The water dispenser
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the tube.. You can take the water line off the valve and watch to see if it drips.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 30, 2009 | Refrigerators
Water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Jan 20, 2009 | Frigidaire FRS26R4A Side by Side...
No water from dispenser
Frig is set too low of temp Water is freezing in tubing chill coil
Jun 07, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Water dripping from the water dispenser on freezer
If the water is dripping from the dispenser tube, you need a water valve. The valve is not shutting off completely. Check to make sure water is not dripping from ice chute. If the chute door doesn't seal off you will get moisture there and it will also frost up the ice chute.
Sep 30, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
475 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
