Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Unable to format the drive r copy files to the drive
I tried to delete in dos prompt
but it was displaying the following error
Volume label (ENTER for none)? m
Creating file system structures.
The first NTFS boot sector is unwriteable.
All NTFS boot sectors are unwriteable. Cannot continue.
Format failed.
Even i tried in windows pane by right clicking on computer and go to manage and go to disk management and tried to format
still it is displaying the error as unable to complete the format
  • Anonymous Apr 17, 2009
    i m ununable to format the drive r copy files to the drive
  • Anonymous Apr 19, 2009
    i do have the same problem
  • 294 Answers
Pocket Fuzzies?
Get a bright light and look into the USB connector of the Cruzer. It is possible that there is lint, paper bits, cookei crumbs, etc in there and that is your problem. The outer 2 connections of the USB is DATA and the inner two Power. B/C it is able to flash,you are getting power... but the data lines may be dirty, covered, bent, etc.
Clean it up and try again. Flat toothpick, small ty-wrap or Proxident (dental/braces) brushes work well for this - DO NOT use anything Metal!! It will scratch the connectors and vastly shorten their life (they are GOLD plated)
Short of that, goto HP site and get their USB format tool (get it here: http://files.extremeoverclocking.com/file.php?f=197 ) and try reformatting... if that doesn't work, it is hosed and only I can fix it so let me know ;-)
Posted on Jan 17, 2009
Reformatting HCS725032VLA380
Is it your primary hard drive ?
Reformat hard drive to NTFS Windows XP allows you to easily format the hard drives with its inbuilt utility. Formatting the hard drive would forever delete all the files stored on it. There are two ways in which you can format the hard disk partition - from My Computer and from DOS. You cannot have a NTFS partition with allocation unit s above 4096.
Click on "Start," and then click on "My Computer." Right-click on the disk partition to format and then click on "Format." Click on the "File System" drop down box and select "NTFS." Click on the "Allocation unit " drop down box and select an allocation . It is recommended that you select the "Default allocation " option. Click on the "Start" button. b> Format the Partition from DOS b> Click on "Start," and then click on "Run." Type "cmd" in the 'Run' dialog box and then press "Enter." Type "format drive_letter: /FS:NTFS" at the command prompt and then press "Enter." Replace the 'drive_letter' here with the letter of the drive that you want to format (for example, format e: /FS:NTFS). For help on advanced formatting options, type "format/?'more" at the command prompt and then press "Enter." Keep pressing "Enter" as you read on. Hope it helps
Jan 24, 2013 | Hitachi CinemaStar 7K500 HCS725032VLA380...
I'm unable to format my pen drive. The following error has displayed for each time i tried to format my sandisk cruzer blade"Windows unable to format your drive"
HI Friend..!!!!!
try this
1. Insert your pen drive in computer and don't take it out.
2. Place WinXP Cd in CD-Rom
3. Restart your Computer
4. When your computer prompts boot from Cd click any button
5. Wait for upto 5-10 minutes.
6. Now when format screen comes select your pen drive over there.
7. Now install winXP over to it.
8. Now it asks for format.
9. After formatting it copies the files, at that particular moment restart your computer.
10. Remove the Cd from CD-Rom and the pen drive from computer.
11. Now when your computer is restarted insert your pendrive and delete if there is any unneccessary file exists.
12. Now you'll feel that your Pendrive is in OK condition.
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards'
sandy
Sep 04, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Can read the drive, directory corrupted
just run chkdsk command to recover your directory structure,
Manual steps to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Apr 22, 2010 | Hitachi hts548080m9at00 80 GB Hard Drive
File won't transfer, but HDD has plenty of space for it
In Windows, if you use fat 32, your file will be up to 4GB. Format your passport hd in NTSF to solve this problem. Note, save all your data, because this process make clean HD, all data will be lost.
Apr 05, 2010 | Western Digital Passport WDXML800UE...
How can I format my newly bought Seagate 250 GB External Portable Drive into FAT32 system. Are most dvd players now with usb support for divx cannot access external drives that are in NTFS format such as...
You can specify the format type on the option page for format before you press the format button when displaying the drives in "My Computer"
Additionally, you can CONVERT an existing FAT or FAT32 partition to NTFS. Follow the steps below for Windows XP:
  1. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. At the command prompt, type the following, where drive letter is the drive that you want to convert: convert drive letter: /fs:ntfs For example, type the following command to convert drive E to NTFS: convert e: /fs:ntfsNote If the operating system is on the drive that you are converting, you will be prompted to schedule the task when you restart the computer because the conversion cannot be completed while the operating system is running. When you are prompted, click YES.
  3. When you receive the following message at the command prompt, type the volume label of the drive that you are converting, and then press ENTER: The type of the file system is FAT.
    Enter the current volume label for drive drive letter
  4. When the conversion to NTFS is complete, you receive the following message at the command prompt:Conversion complete
  5. Quit the command prompt.
Sep 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
32 GBs Kingston Pen Drive
try uninstalling the fake 32gb program. Reboot your system and see.
Aug 24, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Windows was unable to complete the format
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Windows xp corrupted
This is supposed to be caused by some missing registry entries in your windows installation. Not exactly sure why this is happening. May be you have some important files that cannot be copied due to a damaged CD. Microsoft replaces the media for you so that you can try installing using the replacement. Click here for more details
http://support.microsoft.com/default.aspx?scid=kb;en-us;326246
You can also try to recover the PC using recovery console. To do it follow the steps below
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:windowssystem32configsystem c:windows mpsystem.bak
    copy c:windowssystem32configsoftware c:windows mpsoftware.bak
    copy c:windowssystem32configsam c:windows mpsam.bak
    copy c:windowssystem32configsecurity c:windows mpsecurity.bak
    copy c:windowssystem32configdefault c:windows mpdefault.bak
    delete c:windowssystem32configsystem
    delete c:windowssystem32configsoftware
    delete c:windowssystem32configsam
    delete c:windowssystem32configsecurity
    delete c:windowssystem32configdefault
    copy c:windows epairsystem c:windowssystem32configsystem
    copy c:windows epairsoftware c:windowssystem32configsoftware
    copy c:windows epairsam c:windowssystem32configsam
    copy c:windows epairsecurity c:windowssystem32configsecurity
    copy c:windows epairdefault c:windowssystem32configdefault
  6. Type exit to quit Recovery Console. Your computer will restart.
Source:http://support.microsoft.com/kb/307545
Dec 29, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
My External USB 250hard drive shows error Drive is not accessible
You most likely need to delete the partition on your external hard drive, then create a new one and format it again. You will lose the data on your external hard drive.
1. Go to the Control Panel, click on Administrative Tools, click on Computer Management, then Disk Management. (You will need Administrators rights to carry out the following tasks)
2. On the lower Right Panel select the External drive, this will be displayed as Disk 1, Right click on this drive (MAKE SURE YOU DON"T SELECT THE C: DRIVE which will be displayed as Disk 0)
and then Delete the partition.
3. This drive should then be Unallocated, Right Click on this drive and create a New Partition.
4. Then select Primary partition.
5. Check that the maxium disk size matches close to 240000(MB) you about 10+MB in the formating process
6. Click Assign the following drive letter (let the computer select this.
7. Chick Format the partition with the following settings
File System = NTFS
Allocatin unir size = Default
Volume label = "name of your choice eg. BACHUP DATA"
DON'T TICK Perform a quick format & Enable file & folder compression
8. Click Finish
Nov 27, 2008 | Western Digital 250GB MyBook External USB...
Accessing a folder.
This will sound off the wall, but we had something similar to this happen with my last laptop, where it was "access denied" in lots of areas, and we would have to find little backdoor ways to get into control panel and document files. The problem with our computer was that it had previously crashed, and we had rebooted and reinstalled the xp, but didn't have the registration number, so it would run ok, but to get into all those access denied things (which you eventually need to get into) we had to come up with our registration number.
Did it prompt you to enter the product key when you re-installed it?
Jun 27, 2008 | SmartDisk FireLite USBFLB120 120 GB USB...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
285 people viewed this question
Top Kingston Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
