Question about Navman iCN 320 GPS Receiver
How to get my navman reset to factory settings
I can not get my navman to reset how can i fix this problem
    Problem Solver:
How do i reset my navman icn 320
Posted on Feb 14, 2011
3 Suggested Answers
SOURCE:
  • 412 Answers
SOURCE: i want to reset my navman s100 to its factory settings
Go to the setting area and select "Preferences" there is a "reset Factory default" option select it.
for more info...read the user manual--
http://www.navman.com/docs/manuals/navman-s-series-spirit-hardware-manual-en.pdf
Posted on Mar 19, 2009
SOURCE: navman s30 can not pick up gps
Took it To someone that knows about them, The GPS unit has failed its back for warranty claim NO WORRIES :)
Posted on Jan 21, 2009
Navman 450MLT worked fine until I went to do the first update of the maps - unit stalled during the process, and now won't work (no maps). Smart recovery does nothing. How do I un-brick my Navman?
If you have any chance of receiving a repair or replacement unit from Navman, do that. I do not know their return/repair policy but trying to fix it yourself may void any chance you have of getting real customer support, unfortunately.
Otherwise, take a look at this post:
In particular: http://forums.whirlpool.net.au/forum-replies.cfm?t=2014297&p=2&#r23
He says there is a paperclip hole. This should do a factory reset and may fix your device. Otherwise he claims that reformatting the drive then "safely disconnecting hardware' may fix the device.
Oct 05, 2014 | GPS
How to fix stuck on transfer screen
Hold down the on button until the screen goes black. wait two min, then turn it back on. If that doesn't work, try connecting your device to your computer and go online to the manufacture website. Most have a way to check your device and fix/update it.
Sep 01, 2014 | GPS
Change navman my55t pin code.
I tried to download the user manual for your model, but unfortunately the server link was dead (this may be temporary). Try going to Navman Support for either another try at the manual's download page or an e-mail link for the answer to your question.
Some equipment has a "reset to factory default" button or procedure; this should reset the PIN and user settings to factory default. I don't know if this is the case with your GPS unit since I can't get the manual, but this would be the simplest method if it doesn't erase map updates.
Jul 19, 2013 | GPS
I want to reset my navman to factory settings
uder the base of the unit you will see a small hole about the size of a pen this is the reset button get a pen or similar item insert the nib into the hole and press the button this should reset the unit
Aug 30, 2009 | Navman F20 GPS Receiver
We keep loosing contact to the sattelites. Is there a way to reset it, so we get a constant signal?
Mine did the same, and said no gps no fix. I called the factory, now called Northstar, tech said to reset unit, and it worked. Great signal strength. Turn unit on and access menu, access factory settings,hit factory reset. However you will lose all your waypoints.
Jul 04, 2009 | Navman Tracker 5500i GPS Receiver
I want to reset my navman s100 to its factory settings
Mar 19, 2009 | GPS
Navman s30 can not pick up gps
Jan 18, 2009 | Navman Sport Tool S300 GPS Pedometer...
How to remove all previous direction searches from navman 320
go to factory reset under spanner and keep pressing next till reset comes on
Dec 29, 2008 | Navman iCN 320 GPS Receiver
Navman S reset
Please go to Preference option on your navman. From the main screen you can setup the following preferences.Now scroll to 3rd page of the prefrences.There you will see the following options:
  • Start Up – enable/disable the tutorial and language selection screen that appear when the system is switched on.
  • Saved Info – here you can delete recent locations, favourites, avoidances and reset to factory defaults.
  • Bluetooth – this option allows you to setup bluetooth pairing with a mobile phone.
  • Tutorial – run the tutorial that appears at startup.
  • Shop Demo--runs a demo so you can see the Navman S50 in action.
Just select the SAVED INFO option and then you will see a RESET TO FACTORY DEFAULT OPTION.
Jul 23, 2008 | GPS
NAVMAN PIN 570
Try cold boot, that is factory reset button on the right of the power/usb cable slot.
Feb 12, 2008 | Navman PiN 570 GPS Receiver
Navman iCN 320 GPS Receiver Logo
2,266 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
