Question about Sony PlayStation 2 (PS2) Console
Playstation 2 The cd tray is jamming on the way out,does anyone know how to fix this,any advice would be grateful.Thanks.
    Scholar:
  • 47 Answers
There is a chance that the plastic track on the loading tray either has a break or is out or time with the load gears. Also located in the front of the dvd assembly, there is a load belt , sometimes after many hours of use, this belt becomes stretched and needs to be replaced. A knowledgeable technician can usually fix this problem for about $40 if the load tray does not have to be replaced. Also, if you decide to attemp this yourself, clean the laser while the unit is apart. Use eiher ispropal alcohol or acetone. Be careful not to spill any chemicals on the plastic. Scrivitron
Posted on Jun 20, 2007
SOURCE:
My door on my playstation 2 is jammed any ideas on how i can fix it???
hit the open tray and then try to pull it out yoursekf the rubberband that drives the tray out could be off
Nov 07, 2009 | Sony PlayStation 2 (PS2) Console
Door jammed
try opening it it has six screws just remember where it goes then youll see another cover for the cd player also remove the top part then you should see whats inside jamming it and try to yank just a little but be careful on the wires you dont want that severed, now try to pull tray and push back then try to power it up first how the goes or where it jams then you can adjust it. after this place back the parts where they were before and try it again, i hope this helps you thnk you ands let us know if this works and we will try to give our best again..
Dec 10, 2008 | Sony PlayStation 2 (PS2) Console
Plays when it feels like
Try using a compressed air can to blow air into the CD tray and also into the vents in the back. It sounds like either dust or debris is caught in the CD tray or is blocking the vent in the back causing the machine to over-heat.
Sep 05, 2008 | Sony PlayStation 2 (PS2) Console
CD Player not working
i have an older machien here its a mini hifi system fw 540c it wont play any cd's i put into it it skips tru all 3 trays and than says no disc or disc not finilised. i had it in storage for about 4 months over a winter worked fime b4 can some one tell me what could help before i trow it away (>-_-)> ty<(-_-<)
Mar 04, 2008 | Teac GF-350 CD Shelf System
Pioneer PDR-W839 Jammed Disc Changer (previously posted)
hello poopig1, after further review, I meant to describe this: look for a pinhole in the area of the CD tray to insert a pin...similar to the same pinhole you see on a PC's cd player to eject the tray manually. If there is none, then try this: Open the cover and find the motor that, when turning, performs the tray ejection. Then, turn that motor by hand until the entire tray (or cartridge) is ejected. Then power up and observe the events.
May 31, 2007 | Pioneer PD-RW839 4-Disc CD Recorder
Pioneer PDR-W839 Disc Changer Jammed
look for a small pinhole and insert a pin while powered up to reset the device
May 26, 2007 | Pioneer PD-RW839 4-Disc CD Recorder
Cd tray jammed
If you turn it off at the mains, wait a few seconds then turn it back on. As soon as you turn the power on, try and press the button for the tray to open. If this dont work, you will have to open up your system and remove this disc yourself. Good luck.
Sep 21, 2006 | Panasonic SC-PM313 Shelf System
CD malfunction
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again. If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system. Good luck.
Aug 29, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
Sony PlayStation 2 (PS2) Console Logo
82 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
