Question about Dell E173FP 17" LCD Flat Panel Monitor
Cannot display video mode
I just bought a used dell flat screen E173FP1and when I plugged it into my tower it says "cannot display video mode" what is wrong? is there a compatability issue or a way to fix it and make it work?
  • 555 Answers
The problem is your video card not able to communicate properly with the hardware. To solve this problem you need to install the drivers for your video card. In case you already installed it (long time ago), you need to update the drivers. Check the video card manufacturer for updates.
Good luck.
Posted on Oct 05, 2009
Plugged in my emachine LE1938 to my dell without the DVI cable, screen displays 'no signal'. Shouldn't the monitor work without the DVI cable?
The DVI cable transports the display signal from the video card to the monitor.
I think what Ron is asking is if you used a different cable to connect the monitor to the computer. (I'm assuming you used an old 15 pin monitor cable or whatever those old cables were?)
Without getting into your BIOS:
So on your computer, you probably have an onboard video card (a video card built into the motherboard itself), and a dedicated video card (probably where you're seeing the DVI out).
It may be possible that you have the on board video card (with the traditional connection) disabled, when the dedicated video card is plugged in.
This isn't rocket science, so don't worry. Phillips head screwdriver is all you need.
Pull the side panel off your computer (assuming it's a tower... if not, it's the top panel). Once you have it off, you'll see that video card plugged into a slot on the motherboard, with 1 phillips head screw holding it in place (inside, near the back, where the DVI port is).
Pull the screw, and the video card should come out. From there, the BIOS should recognize your card is missing, and thus revert to using the onboard video card.
Sep 02, 2012 | eMachines E-machines flat screen CRT 17"...
I just bought a flat screen monitor 15 inches and have a acer tower. I have a dell monitor now but want a flat screen will they work together
it should work just fine ..... if not identify the connector DVI- VGA- Etc.but in most cases monitors and towers are pretty compatible
Aug 26, 2012 | HP Vs17 17" LCD Flat Panel Monitor
When booting the cp is going to power saving mode
Unplug power sources for the monitor and computer.
Hold down the power button of the computer tower for 10 seconds, this will drain remaining from the motherboard.
Plug back in the power sources for the monitor and computer tower.
Power on the monitor first, make sure the monitor power button will turn green then amber.
Power on the computer tower.
Try to check if you were able to see the Dell blue logo just right after you power on the computer.
If you were able to see the Dell blue logo then do these steps:
1. Turn off computer then turn it back on then immediately keep tapping on the F8 key. If options will appear please select safe mode.
2. If you were able to access in safe mode the problem we have is the video card driver needs to be uninstall then reinstall. To uninstall/reinstall the video card driver. Once you access the safe mode go to device manager then uninstall the display driver. Reinstall the display driver using the CD drivers came with the computer.
3. If you were not able to access safe mode then try again step 1, when you reach the option screen then select "last known good configuration".
If all fails from these steps, back up your HD files by asking a local tech to use an enclosure to copy all your data from your HDD to a different storage cause this will end up reinstalling the windows operating system.
Just in case just right after you power on the computer and it immediately gave you the message entering powe safe mode then you need to re-seat the video card which needs to open the side cover of your computer.
Re-seating the video card ut's just like taking it out from the slot then put it back again, make sure it's properly seated.
Jun 30, 2011 | Dell Dimension 2400 PC Desktop
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer,...
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
May 28, 2010 | Dell Dimension 2400 PC Desktop
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
I have had problems with communication between the tower and the monitor. I recently bought a Dell flat screen monitor. The monitor worked for about two months, now when it is turned on, it immediately...
Sorry it IS the monitor this is a common problem, unfortunately, this is evidenced by the fact it still didn't work when connected to another machine,regardless of lack or message. Do a warranty claim.
Mar 05, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Error: Cannot Display This Video Mode
You may have to boot into safe mode and reset the video settings to a safe setting like 1024x768.
  1. To get into safe mode, continuously press F8 while the computer is booting up.
  2. Eventually you will get a Windows XP Boot Menu.
  3. Choose the option for Safe Mode.
  4. Go to Start, Control Panel and double-click Display.
  5. On the Settings tab, drag the slider bar to 1024x768.
  6. Click OK
  7. Shut down and reboot.
If the problem goes away, then you are good. Otherwise, you'll have to boot menu again (F8) and choose Enable VGA Mode.
Aug 29, 2009 | Dell OptiPlex GX620 PC Desktop
Monitor is black with message "Cannot Display This Video Mode".
the computer is having problems displaying the video mode from the tower. Im not sure what kind of flat panel monitor you have but you should have a menu button there where you can choose video input. its either VGA(analog) or DVI(Digital). if you are using the monitor cable with the blue connector use VGA if its the white cable use DVI.
hope this resolves the problem. thanks.
Jan 03, 2008 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
284 people viewed this question
Alun Cox
