I have a Carrier Weathermaker SXi. Furnance will not turn on. I shut power off and waited ten minutes and tried to restart. Codes flashing are 12, 31, 32, 33, 41, 42. Can this be started in emergency mode?
  • dmtent Jan 17, 2009
    Is it possible to put our Carrier in emergency heat mode? If so, how do we go about doing this?
    Given these codes: 12, 31, 32, 33, 41, and 42
    What needs to be done to repair our furnace and is this a costly fix? Last time we had a repairman he charged us $2,500 and didn't fix the problem. When we tried to call him back - he disconnected his phone. He replaced part number 311164-701 ECM Motor Control 8794700ACG02. Could this be the problem again or is there something else going on?
    President:
  • 2,559 Answers
Emergency heat is made for this kind of situation.So yes you can.
now for the codes.
code 12= Blower on after power up
code 31=High heat pressure switch or relay didn't close or reopened
code 32=Low heat pressure switch or relay didn't close or reopened
code 33=limit circuit fault(Flame rollout switch is open)
code 41=board fault
code 42=control lockout
Please rate this solution
Posted on Jan 17, 2009
  • Randy Hough
    Randy Hough Jan 18, 2009
    Replacing the board will fix it.
    I suggest calling around for Prices since they are area dependent.
I have a carrier furnance model # 398AAV036060 serial # 0293A03686 it comes on for a few minutes the cuts off please help
Check for smell of gas first, call gas company if leak detected. May be a loose thermostat wire, dirty main control board, dirty/ lint filled gas tubes, mine had both. Cracked or dirty ceramic igniter (This is a BIGGIE!) or dirty flame sensor. Dirty fan sensor, or flame over sensor, and or burner safety sensors. Shut off power for 10 minutes, follow owner's manual to restart, wall thermostat might usually get set to lowest temp setting, then power turned on, then set thermostat to desired temperature?
Nov 16, 2017 | Carrier Heating & Cooling
Funace keeps shutting down
Restarting after removing the power is how the equipment is designed to operate because removing power temporarily clears the fault code. Not starting could be caused by a number of built in safety devices such as roll out switches or partially blocked flue pipe. I've seen them with bird's nest in it. This should be looked at by a trained professional.
Nov 26, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Power Surge
charlie the proble has something to do with the tv guide here is a response from an older post Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was. Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Aug 05, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
2006 Chevrolet Equinox won't start, security system is engaged, how do we restart it?
Make sure the doors and trunk,and hood are shut,open them,and shut them .activate the anti theft,wait about 1 minute,and disarm it,see if it will start,if not,the key fob may need to be relearned,try turning the key on,leave it ten minutes,then turn it off,and right back on,then wait ten minutes,and turn it off,and right back on,do this a total of three times,,30 minutes,then try and start.
Apr 21, 2010 | 2006 Chevrolet Equinox
Weathermaker 8000 furnance flashing code 31 blower comes on for 90 sec .. then shuts off .. then other fan goes on.. don't see any flames or lighting goin on can you help?
31 PRESSURE SWITCH DID NOT CLOSE OR REOPENED - If open longer than five minutes,
inducer shuts off for 15 minutes before retry. Check for: - Excessive wind
- Proper vent sizing - Defective inducer motor
- Low inducer voltage (115VAC) - Defective pressure switch
- Inadequate combustion air supply - Disconnected or obstructed pressure tubing
- Low inlet gas pressure (if LGPS used) - Restricted vent
If it opens during blower on-delay period, blower will come on for the selected blower
off-delay.
33 LIMIT CIRCUIT FAULT - Indicates
Nov 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
How to repair Samsung AQV 12 FAN Air Conditioner
You can turn off the Thermostat, and the powers switch on the furnance and turn the breaker off in the breaker box wait about 20 - 30 minutes and turn the breaker back on, and the power to the furance back on and the thermostat, this should reset the system.
Melvin
St Louis
Oct 03, 2009 | Samsung Heating & Cooling
Carrier Weathermaker SXI Model 58SX8100LG Code 12
Code 12 I believe is power up after power off and a call for heat from the the thermostat. If you have a weak door switch that may be vibrating and going on and off it would cause this as would any thing that causes the power to drop low or out then reapply its self. try holding the door switch in while watching the board and after 2 or 3 minutes the furnace should go on to lite and the blower cycle off. If it stays in this mode try turning the thermostat off (heat - OFF -cool) and then push in the door switch nothing should happen except the lite on the board come on and stay on. If it does this than have someone turn the thermostat to heat and see if it starts or put the door on and set the heat and see if *** goes through the normal cycle of heating. If however it goes right back into the blower mode and shows the 12 code your problem is still with you. So next remove the wire on the "W" terminal on the board. Retry power to the door switch and now nothing should be on except the red lite. If it tries to start the 12 code and blower up again Im pretty sure you have a bad ignition/blower control board.
Mar 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Hello my name is veronacarrier 8000 weathermaker will not ignite
call the furnace repairman. you have a fairly easy repair but the parts are expensive
Dec 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Dec 10, 2008 | Heating & Cooling
Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
786 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
