Question about Canon Pixma MP500 All-In-One InkJet Printer
Error code Please can you help me solve this my canon mp510 gives me an error code 5010
  • Akabi John Jul 17, 2007
    i broght the canon printer at denmark and i am now in ghana please what do i do
  • Anonymous Dec 08, 2007
    Our brand new MP510 reported it couldn't recognise the cyan cartridge, we took out the cyan cartride, then immediately clicked it back in...the light came on & it worked for a couple of days. Then it began being "not recognised " more & more frequently, but would work for a while if loosened then replaced, until it refused to be recognised AT ALL. If one tank can't be recognised the whole printer wont work which is VERY inconvenient. The shop we bought it from is a long drive away, but I managed to get a new cyan locally, & we've had no trouble for 2 weeks. BUT yesterday the yellow intermitently couldn't be recognised, and today refuses to be recognised at all...so my printer again wont function at all. It seems to be a design fault if one cartride malfunction negates the whole machine....most of my printing needs are black for documents.
Cheebster's suggestion may seem to be not helpful but I daresay that he is right. In my case, I have that 5010 error as well and we called in the technician to solve our problem under the 2 year warranty that was given to us. Apparently, the motherboard has issues and had to be replaced.
Posted on Aug 20, 2007
    Scholar:
  • 39 Answers
Hi Jakabi. That error code means there's a defective module in the printer. It's not user replaceable, unfortunately. The only solution is to contact the store where you bought it, or Canon's tech support to get a replacement. That comes directly from Canon support ! I know it isn't what you'd like to hear, but unfortunately it's the only way out of it. Thanks ! cheebster.
Posted on Jun 20, 2007
  • Anonymous Jul 19, 2007
    Hi Jakabi. Contact Canon's tech support. They are the only ones who will be able to help for your issue ! Thanks, cheebster.
6ya staff
SOURCE:
How to fix canon mp510 pixma error 5010
It means your scanner error base on Error Codes
solution: you must take it to the printer service
May 23, 2011 | Office Equipment & Supplies
Pixma MP510
There are several reasons to get this 5010 error in your printer but the most common one will be you would have caused this after pulling the printer to bits to fix a blockage. You can fix this issue by inserting the ribbon cables from the scanner into the circuit board properly.
Thank you !!
Jul 19, 2010 | Canon PIXMA MP510 All-In-One InkJet...
MY CANON MP510 KEEPS SHOWING ME A ERROR 5010 WHEN I PRESS SCAN CANNON PIXMA MP510
The scanner unit cannot detect the home
position, or the scanner unit warming-up is not
done properly at power-on.
On the LCD, "SCANNER ERROR" is
displayed.
Mar 27, 2010 | Office Equipment & Supplies
Canon printer mp 510 error 5010
That is a purge system error, either you need a new purge assembly or there is a paper scrap caught in there stopping it. The purge unit is on the right where the printhead parks at shutdown and where the printhead is cleaned.
Aug 25, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Error code 5010
5010 is a scanner error, where the scanner either cannot find home position, or is not warmed up completely. Only cure is to replace the entire scanner assembly, if it's less than a year old it can be done under warranty, otherwise around $150 to $180.00
Jun 30, 2009 | Canon PIXMA MP510 All-In-One InkJet...
ERROR CODE 5010
Hi Friend,
kindly follows the below 2 steps
1.Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
2.The MP510 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need.
Regards,
Ayyasam
Jun 01, 2009 | Canon Office Equipment & Supplies
I have Canon pixus MP510 error code 5010
did u check your ink cartridges?take them out and replace them if that don't work then try to unplug it and plug it back in lets see if this helps
Jan 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error code 5010
Yes, same thing happens to me...Error code 5010...and flashing green and orange...alternating lights.
I was trying to photocopy (in basic black, not colour). I had a few pages to copy. I got this 5010 Error code after EACH copy!
I had to turn off the printer after each copy and then turn it back on for the next copy. That's not the worse of it.....once I turned the printer back on and hit copy again...the printer took a VERY long time to scan the item for the next copy. It took me a good 40 minutes to copy 15 pages.
Sooooo irritating!!!!!
Anyone know what to do?
I've also had the paper jam on me tons of times. I am really disappointed with this product. I would not recommend this printer to anyone!
Mar 24, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
420 people viewed this question
Clive
Clive
old marine
old marine
Ekse
