Question about Ranger RCI-2995DX Base Scanner
Squeals when keyed up. Detecting talk back.
I have a 2995DX and use a Turner Plus 2 microphone. Just recently, I've noticed it wants to squeal, or even hum, like the mic gain is up to high. I tried the stock microphone on it and I try to get the modulation up with the gain, and I detect some talk back through the external and internal speaker. No special mods have been done with this radio to have talk back. I really like this radio and want to keep it for a while. I thought it might be the Turner acting up and tried to trouble shoot that, but, like I said, the stock mic is acting the same, but not as dramatic.
Please help me...
ITS JUST NOT THE TURNER MIC IT HAPPENS WITH ALL BASE MICS HAVE HAD THE SAME PROBLEM WITH MY 2995DX WITH A ASTATIC D-104 & 1104-C AND ALSO ANY TURNER I HAVE USED BUT I CAN RUN A ASTATIC MOBILE D-104M6B OR RED DEVIL AND NO SQUEAL HAVE YOU TRIED GROUNDING THE CASE OF THE RADIO IT IS RF FEED BACK SQUEAL SO MY SUGGESTION TO YOU IS TO RUN A 48 COPPER GROUND ROD INTO THE GROUND AND RUN A NICE GROUND WIRE TO THE BACK OR THE CHASIS OF THE RADIO AND IF YOU ARE USING ANY EXTERNAL AMPLIFIERS ALSO GROUND THEM AND YOUR SQUEAL WILL BE ILLMINATED
Posted on Dec 26, 2009
  • seashark Mar 14, 2011
    ROGER B.W.26. I HAVE RCI-2995DX. AND RUN A SADELTA BASE MICE, AND HAD TOP REPORTS ALL ROUND. BACK GROUND SOUNDS OF ANY KIND
Microphone wiring
the rf power going out is geting inducted on the wires of the mic.try using some ferrites close to the coax on the pl259 connector and on the mic wire itself.
Mar 01, 2014 | Radio Communications
Cobra highgear hg75m mic squeals
get it away from the ext . speaker. They are cheap enough ,buy another one and see if it still squeals. If it does then you may have to jump the mic with resistors ,turn down your mic gain, check for talk back on rear where your pa. and external speaker hooks to inside the radio. If you see a resister connecting them then you have talk back . Mainly its a Keep the mic away from the speaker deal that makes them squeal. Try other cobra mics with the same pin out and see if it still happens . easy fix just have to be patient .
Feb 06, 2014 | Cobra 29 LTD CB Radio
Every time I push the talk button, it continually squeals
either;
1) microphone issue (bad wire)
2) audio chip inside radio
3) loose conection inside the radio around the speaker or jack
Oct 25, 2013 | Radio Communications
Connex 4300-300 squeals in talk back mode
turn rf gain up and the mic gain down until it stops squealing.
Jul 14, 2012 | Connex Cb Faceplate Sticker-fits 4300-300
I have a Cobra 148 mounted on the hump in a pickup truck and it works fine. Then I plugged in a old Turner +3 desk microphone and I get bad feedback when it is keyed up and I can also hear my voice thru...
You're most likely getting lots of RF feedback from the metal cab of your truck,combined with the real sensitive nature of the amplified Turner mike.I would put an old original Cobra (coffin mike) handheld mike or a Astatic Roadking 56 (RK56) on it.They are really hard to beat,especially when you have lots of feedback & squealing. I also have a 148GTL (malaysia made) that has a Turner +3 deskmike & it squeals in my truck but not in the house. The 148GTL has given me better service than ANY other radio I've owned.It has 120 channels (freeband) & upper & lower sideband. I think mine is a 5pin Cobra-type plug-in. Try a simpler mike & good luck. Squirrly
Mar 13, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Radio squeals when mic is keyed up and truck is not running. Why might this be
Check the SWR's and also Check that you have at least 10 amps or more on the power wires that you are connected to. if possible run + - wire from battery to radio and see if it squeals , 10 ga wire should work, if just a plain 40ch radio. if an export with more than 60watts you would need more amps. ...
when the vehicle is running it may be getting enough amps, but when it is off. there may be a loose connection or small wires and not enough amps.
Squeal problems
low amp draw - small wire.
High swr's
loud talk back
shorted mic cable wires/broken wires
loose grounds
Feb 27, 2011 | Radio Communications
Rear brakes (driver-side) squeal after replacing rotors and pads
you need to grease the metal clips at the top and bottom of the pads (dont get grease on the rotor or pad though) and also spray some "disc brake quiet" on the back of the pads. it comes in a red can and the spray that comes out is like sticky red paint. do those 2 things and the squeals will be gone.
May 30, 2009 | 2006 Hyundai Tucson
I have a Maxon handheld cb - it squeals when keyed can not talk.
sounds like you are getting a feedback squeal.. try taking a wire and attaching to you handheld and grounding it to something.. that might work.. i know i have to have my mic on my cb grounded to my radio or i get a feedback squeal...
Jan 02, 2009 | Maxon HCB-10C CB Radio
Ranger RCI-2995DX Base Scanner Logo
290 people viewed this question
Top Ranger Radio Communications Experts
Iron
Iron
AnyMHz.com
AnyMHz.com
bailenforcer
Level 1 Expert
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
