Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge Side by side model PSS26MSRSS
The problem i have is that the Turbo Cool light stays on all the time. If i press the light it goes out but when i close the door it comes back on. Tried unplugging the refrigerator to reset it, but it still acts the same way. It is my understanding by reading the Refrigerator Guide that Turbo cool is only suppose to come on if i press the button for it to come on.
I had the same problem with mine, but I bought the 5 year warranty from Sears. They sent me a new board (Part Number WR55X10552) and the problem stopped. This is a common problem from what the guy at Sears told me. I put the board in myself in less than 20 minutes. It's a very easy job. I saw a few of these boards brand new on Ebay for $55.00. The board is different than the one that came with the refrigerator. It's been updated, so now when you open the doors the fan motor stays on (mine always shut off when I opened the doors with the old board). Good luck!
Posted on Sep 23, 2007
  • BarryT82 Sep 23, 2007
    Also, you'll want to confirm that this is the correct part number for your model. I have the PSS26MGPA BB
Oven light stays on and oven is inop on Kitchenaid KGSS907SSS01. Tried to go to self clean mode, Display states close door, but door is close.
I suspect the door/light switch has malfunction. Look for a plunger type of switch and press it in and see if light goes out. If light goes out, close door and gently press on door and see if light goes out. If this happens, I think the door hinges are not closing the door 100% so the door switch is not engaged. Now if door light stays on while pressing door switch, then the door switch might be your issue. Good Luck
Sep 27, 2017 | KitchenAid Kitchen Ranges
How to turn the light back on a Kenmore refrigerator after the door has been open for more than 7 minutes?
There are 2 different systems I know of for the light shut off because of excessive door open time. One system uses a heat sensor near the light bulb to shut off the light if it gets too hot there. To turn light back on that sensor needs to cool back down after door is closed. Second system for the light off---is that the time light on is actually timed by a electronic part on the mother board. It would come back on until the mother board senses the door closed for a similar amount of time. sometimes just closing and reopening the door will bring it back on, All depends on the type light system.
Apr 12, 2015 | Kenmore Refrigerators
My wife noticed our side-by-side GE Turbo Cool water dispenser was dripping water so a quick look in freezer showed a huge ice buildup in the drip tray that had frozen back into the spout. We emptied both...
let see if I understood correct me if i'm wrong! When you close the freezer door water star running from the dispenser? If so you water valve solenoid is staying in the open position just replace it.
Dec 21, 2014 | Refrigerators
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Jul 06, 2013 | Televison & Video
What problems exist with GE model pscs5rgxafss
I have a GE Profile Side by Side Model PSCS5RGXAFSSThe lights work but it does not cool (or work) in the Fridge side or the Freezer side. The front door panel numbers illuminate but, will not control any setting. What's wrong? The unit is 4 years old.
Sep 04, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
My mom & I each have a Craftsman garage door opener at our respective homes & live @ 15 minutes apart. Our openers are about 13 to 14 yrs old. The past two yrs. we've both had the same problem. ...
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure both lights on the sensors stay on and don't flicker while the door is moving and the sensors are firmly attached so they don't move. Tweak them just a bit.
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
Garage Door will not stay closed.
You need to check the adjustment for the travel of the door ... All automatic closers have a built in safety mechanism that prevents children, pets and even yourself from being crushed by the door ... so if the travel is set to low the door will hit the ground too hard and safety mechanism will activate opening the door again! Look at you documentation for how to adjust this for your particular model :)
Sep 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
903 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
