Question about Toshiba Satellite A40-S161 Notebook
Accessing RAM slots in toshiba satellite A40 laptop
I heard its under the keyboard but i think their talkin ****, i cant even remove keyboard to check, please help before i throw it off my Varandah.
  • jason May 11, 2010
    have you checked the panel on the bottom of the laptop , there is a screw holding it down. are you trying to upgrade your ram ?
  • 170 Answers
Click on never installed memory? warch how, then click on laptop and watch video. Enjoy
Posted on Jan 17, 2009
How can I increase memory of toshiba Satellite A105
A RAM expansion slot is located on the bottom of the laptop behind a small panel. Remove the panel to get access to the RAM slot/s. It may have two RAM slots, if it has only one the the 1st RAM slot will most likely be located under the keyboard.
If the laptop has two RAM slots on the bottom of the laptop and the 2nd one is empty then you can add anothe RAM module. Try to get the same make and model as the original to double your RAM..
If both slots are occupied then you need to replace the existing RAM with larger capacity RAM modules.
Sep 02, 2010 | Toshiba Satellite A105 Notebook
How do i replace ram in a toshiba 2450
Unclip top trim the one with the on button ,undo 3 screws lift up the keyboard and put in your memory in the slot under the plastic reassemble in reverse order
Feb 20, 2010 | Toshiba Satellite 2450-401 Notebook
I have a Toshiba Satellite 1905-S301 that has 512mb of DDR memory currently. I have a stick of 128 that I was going to throw in there to boost performance but when I opened the compartment the there was...
There are 2 types of memory, one for laptops and one for pc.
Your additional stick seems to be for pc from what your saying.
Additional thoughts:
I'm sure you can buy sticks for laptops at walmart or whereever you bought ur laptop. Just make sure it is the same speed type. Example: yours is 512mb ddr PC 5200, you will need to find PC5200, the 512mb and up you shouldnt have to worry about. So do your research before you upgrade or you will burn your laptop.
Sep 09, 2009 | Toshiba Satellite 1905-S301 Notebook
Toshiba Satellite Pro A40 Can't find RAM memory
The memory is located under the keyboard
Remove batt and cables
open screen
pop out the rectangular panel surrounding the on off buttons
remove the 3 screws and lift up the keyboard to access the memory
Dont ask me why they made it this complicated
Manual can be got here
Sep 05, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
2nd RAM slot for Toshiba Satellite M45-S331
if its not under the laptop, it can only be under the keyboard.
Jun 18, 2009 | Toshiba Satellite M45-S331 Notebook
Wheres the ram?
RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled. Typically you will see 2x512MB or 2x256MB signifying you get 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
The Toshiba Satellite A40-S270 has 2 bank(s) which have 1 socket(s) in each bank for a total of 2 memory socket(s). This means the Satellite A40-S270 can support up to 2 individual RAM modules.
Below is a visual representation of the memory bank(s) and socket(s) configuration for the Toshiba Satellite A40-S270.
socket_1.gifsocket_1.gif This graphical representation above details what the memory configuration would look like with the maximum memory installed and does not necessarily model your system memory configuration. This graphical representation is not drawn to scale and should only be used as a general reference. Please consult your system’s user manual for your actual memory configuration.
May 11, 2009 | Computers & Internet
Upgrade memory for legacy Toshiba Satellite A40-S270
If those are the correct specs for your computer, you can indeed install two 1 Gb sticks in it. The overheating may be caused by a ventilation issue on the laptop. There is an access door on the bottom of the laptop that is held in place with a Phillips head screw, you can remove the panel and see if there are two sticks installed. .
Mar 19, 2009 | Toshiba Satellite A40-S270 Notebook
Dont know how to change ram in the toshiba satellite pro A40
Flip it over and loosen 2 screws holding a panel in the center of the laptop.
Once door is removed, it will expose ram modules.
pry locking tabs out, and module will spring UP. remove, and replace reverse of removal.
Jan 12, 2009 | Toshiba Satellite A40-S270 Notebook
Cant install two emory modules as can only find one slot!
I hope you have not gave up on your problem. Your Notebook is equipped with two memory module slots. One slot is user accessible ( under the notebook) , the other slot sits beneath the keyboard under a EMI shield (Electromagnetic interference Shield). All it requires is the removal of the panel where the power button is at and two screws that hold in the keyboard. If you are uncertain of performing this task, any local Certified computer shop can perform this in 5 minutes.
if you think you can tackle this task it is not hard and i have detailed photo's if you need them.
Jan 09, 2009 | Toshiba Satellite M105-S1021 Notebook
Accessing memory (RAM) to upgrade
First of all, remove the battery
Insert a thin object under the securing strip and lift it up.
Be careful, it may be very tight.
Remove the securing strip.
Carefully work with finger to disengage plastic latches securing the securing strip.
Remove three screws and a metal brace securing the keyboard.
Lift off the keyboard and place it on the palmrest
Now you can access the memory modules.
Jun 12, 2008 | Toshiba Satellite A25-S207 Notebook
Toshiba Satellite A40-S161 Notebook Logo
416 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
