Question about Akai LCT3285TA 32 in. LCD Television
Lct3285ta Akai Hello, I was fixing this Akai LCD that was given to me by a friend. Looks like the power supply has some bad caps. I was not the first person to open this LCD tv up. Looks like someone removed the control board on the side. I wanted to know if anyone has pics of the inside of this TV. I need pics of the control board all the way to the main board. I found a board online, but need to know where it plugs into on the main board. If you can help with pics or with a Akai repair booklet you would help me a whole bunch. Thanks for your time all. Patrick
  • 1 more comment
  • stafford691 Jan 18, 2009
    Man thank you for the pics!!! It looks like my tv is missing a cable!!! Those pics are very good, but could you take a few close up pics of the connecter in the right had corner? It looks like it jumps from one board to the next. Looks like the 5v goes to the 5v twice. Then skips a ground. Then three grounds then the 9v goes to the 12 v?? Boy thanks for the pics. I bet that makes a differance :) If you can get a closer pic of each connection that would be grate. Thanks a bunch!!!!!!!
    Sorry I ment Left hand upper corner :)
  • stafford691 Jan 23, 2009
    Thanks for the very nice pics!!!! This will help a bunch!!! It's nice to have people like you in this world!!
I have one I'm replacing the caps on also, the back is off, here are some pic's.Lct3285ta Akai - f49c805.jpg3cfe79a.jpgf402f49.jpg
Posted on Jan 17, 2009
  • chriscourt Jan 18, 2009
    here are pics of upper left had corner.
Akai LCD tv model LCT3285TA will not respond to remote. Green and red lights at sensor are out
The most common cause of this type of power issue is a failure of the filter capacitors on the power supply board. Below is a picture of the board with the faulty capacitors circled, there are 2 more under one of the big black heat sinks. The board can be repaired by replacing the bad capacitors. Below the picture is a link to a kit of the correct parts for the board repair if you want to do the job yourself.
http://www.ccl-la.com/catalog/product_info.php?products_id=240
I hope this helps you out.
Oct 11, 2012 | Akai LCT3285TA 32 in. LCD Television
My akai tv wont turn on
check all caps 1000mf-16v & 470mf-16v before buy a new one. maybe the board have blows caps.
Jun 18, 2010 | Akai LCT3285TA 32 in. LCD Television
TV wont come On
The power supply may have failed, you can try to fix the power supply if you have good knowleadge to fix electronics down to component level with proper tools, or you can buy a new power supply.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Akai+LCT3285TA
Learn about what usually failed in TV/MONITORS.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 12, 2010 | Akai LCT3285TA 32 in. LCD Television
My akai television wont stay on. it turns off on it's own
You have a bad power supply ,most likely the capacitors are bad in the power supply.
Nov 03, 2009 | Akai LCT3285TA 32 in. LCD Television
Akai LCT3285TA Television won't turn on
the problem is in the power supply(they know about it good luck fighting them)but there is good news.you can remove the power supply and replace electrolytic caps,EC18,EC19,EC20 all of them are 1000mf at16 volt use 1000mf at25 volt.you can also go to shopjimmy.com enter model number you will see power supply part number MLT169B
it will be cheaper for you to replace the caps,the board cost about $80.00 from them
Sep 24, 2009 | Akai LCT3285TA 32 in. LCD Television
My akai 32 in lcd tv keeps turning off every 2 mins
you got a bad power supply with a bad capcitor inside or the tv is overheating but you first want to rule out the power supply in this regard- Thanks
Sep 23, 2009 | Akai LCT3285TA 32 in. LCD Television
Power supply board needed from a Akai LCT3285TA 32" LCD TV
Go to partsstore.com this is where I found the power supply board for this TV.
Jun 30, 2009 | Akai LCT3285TA 32 in. LCD Television
Screen powers up then goes blank after 2 seconds
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
Oct 30, 2007 | Akai LCT3285TA 32 in. LCD Television
Akai LCT3285TA 32 in. LCD Television Logo
246 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
