Question about Pentax Optio 50 Digital Camera
Lens error I can switch my camera on. The screen at the back comes up with the Optio screen display, v1.01. Then the screen says 'Lens error'. I hear no attempt by the camera to push the lense out. Then the camera goes off, the screen a the back goes black. I have not dropped or damaged my camera in anyway. Any ideas? Thanks
  • 1 more comment
  • cos_mike_cos Aug 12, 2008
    yah i would really like to knoe the easiest way to fix this that doesn't cost me anyhitng or much. if you can help please go ahead thanmks for all your future help maybe ;)
  • Anonymous Sep 05, 2008
    I have the same problem, just purchased it. it takes beautiful pictures but now the lens won't close and the camera shuts off.
  • lazyduck15 Oct 05, 2008
    I dropped my camara and lenses got stuck in the middle between open and closing.
    I have opened the camera up to the very mechanism that opens, closes the lenses. I found a plastic gear attached to the electric motor broken. I have three choices, Buy a new camera (Too expensive), get an spare part to replace the damaged one or to make a clone of the mentioned gear.
    Do anyone has some experience on any of the last two options?
    Any comments will be very much appreciated
I had the same problem with my optio 50 last year. The lense was stuck out, sent it to have estimate, reported to be over $100 to fix. I said NO, and to send camera back. Got camera back with lense still out, no matter what I did, so, what did I have to loose, I tapped a corner of the camera body against a hard surface and VOILA ! the lense retracted and I could use it happily for another year. WARNING!!!!!!!! Here it is a year later and now the camera has black lcd, can display pictures previously taken, with out the comuter. LCD must be ok, but some posted a certain chip problem..oh, well, I had an extra year.....Good luck, you know it is a risk!
Posted on Jun 29, 2009
Its most likely the motor have you tryed pulling it appart then cleaning the motor that might do the trick? if not then you will need to buy a peplacement motor
Posted on Jun 28, 2008
    Genius:
  • 2,985 Answers
If it is a new[ish] purchase send it back via the seller. It may be an issue with the particular model. Get onto Pentax Tech support Team- See what happens- if it is an issue then a replacement free or at moderate cost may be available. If the camera is older -there will be no economic repair option.
Posted on Jun 21, 2007
When I switch camera on, lens comes out but no screen display and I hear a hissing noise. Any idea what is wrong
Unfortunately it sounds like a hardware problem.
Just to make sure, let's reset the camera.
Take the battery out, leave it out for 24 hours.
Put it back in, turn on the camera, and see if it works.
If not, it is indeed a hardware problem, and you have no choice but to send it in to be repaired.
Hope I helped!
Tom
Jun 20, 2009 | Pentax Optio S4 Digital Camera
Petax Optio E60 lens error of 0x15110000
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 13, 2009 | Pentax Optio E60 Digital Camera
No LCD display
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Pentax Optio S4 Digital Camera
Camera
Use your thumbs and gently yet firmly push the lens assembly back into the camera until you hear a confirmation "click"
Aug 01, 2008 | Kodak Easyshare M753 Digital Camera
Pentax a30 problem
I also have the same problem with the A30. Anyone know how to fix?
Apr 23, 2008 | Pentax Optio S50 Digital Camera
Pentax optio S50 Digital Camera problems.
does anything on the screen change when you press the display button? will the lens open? have you tried taking photos without the memory card in the camera?
Apr 12, 2008 | Pentax Optio S Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio 50 Digital Camera Lens Error
Not really, it sounds like the lens has been bumped while it was extended. Unfortunately, the "buzz" you hear is the gears stripping one another. The only fix is to have the lens assembly replaced, which usually costs upwards of $200. I see this problem at least 3 times a week in my shop.
Oct 27, 2007 | Pentax Optio S50 Digital Camera
Lens error No. 221,0,0,0
I have Pentex Optio E 30 camera
When i start my camera , i get error message Lens Error : 221,0,0,0
lens got stuck and it is not coming out for zooming
Sep 06, 2007 | Kodak EasyShare C703 Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Pentax Optio 50 Digital Camera Logo
216 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
