Question about Gateway MX7118 Notebook
Charging Led issues
For some reason every time i put in the battery the charging indicator and LED comes on without the Ac adapter. I believe a surge went through it, How the system works fine, only my customer wants the LED light for the charging system to go off.... It there anything i can do to make the lights go off.... Thanks alot and look forward to hearing from you. BLessings
  • 432 Answers
So, in other words, The system works fine with the AC adapter and battery installed. Have you tried a different battery? Ray CompuGuy44
Posted on Jun 21, 2007
My laptop not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
Its that the battery is not charging, and on the power meter icon its blinking four times orange and one time green. If I remove the battery, the laptop works with ac adapter. but if I reinstall the...
Check for a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Dell Latitude D610 Notebook
Yesterday my battery was indicating it was at 17%, so I plugged it in. Awhile later the "battery low" indicator came on screen so I realized it hadn't been charging. It still didn't charge if I...
You have a DC connector problem:
Jan 27, 2011 | Panasonic Toughbook CF-51 Notebook
My laptop wont start even though the light indicator in the charger is on
You may first try performing the steps mentioned below:
1) Connect the AC adapter into a known working AC outlet and to the DC jack on the notebook.
2) Verify the correct AC adapter is being used, and not a third-party replacement AC adapter.
3) Do not connect the AC adapter to a surge protector or extension cord.
4) If the DC jack on the computer is loose or damaged, the computer may require service.
5) Some AC adapters have a POWER LED indicator and can be confirmed as receiving power by ensuring the LED is lit. If the AC adapter is damaged, or the LED is not lit or continuously flickers when plugged into a working AC outlet, the adapter must be replaced.
6) Attempt to turn on the computer normally.
7) Press and hold the Power Switch for 5 seconds.
8) Remove the battery.
9) Disconnect the AC power adapter.
10) Press and hold the Power Switch for 5 seconds.
11) Connect the AC power adapter.
12) Attempt to turn on the computer.
NOTE: If the computer turns on without the battery, connect and charge the battery for 24 hours.
13) Disconnect all external devices that are connected to the computer.
14) Attempt to turn on the computer.
15) Remove any additional Random Access Memory (RAM) that was installed in the computer.
16) Attempt to turn on the computer.
17) The troubleshooting steps listed above should resolve your issue.
If you have completed all of the steps and the issue is not resolved, service may be required.
Jul 06, 2010 | Dell Latitude D600 Notebook
Laptop not working on battery, i have changed the battery
There are several simple indicator to determine the source of the problem. There are 4 major components involved, the laptop circuitry, contact terminal, AC adapter and battery. Every laptop has a LED light indicating if it is in the charging mode (without powering up the laptop). Start out with your laptop shutdown. Pull out the battery, then plug in the AC Adapter. See any LED light go on? Try again, the same procedure now with the battery plug in first, then plug in the AC adapter. See any additional LED lights go on? If there is no different, than the laptop can not detect your battery. If the AC adapter can power up your laptop, you can eliminate the battery (assumed brand new battery) & AC adapter. This only leaves you with the laptop circuitry & contact terminal. If your laptop can charge up your old battery or any battery, then it might be still the battery & contact. So, you try these procedure to reduce down to the "problem" component.
Oct 13, 2009 | Acer Aspire 5315 Notebook
Battery life
Try another battery cause if for some reason one of the cells inside of the battery isn't charging that will keep the rest of the battery from charging.
If that doesn't work then try another known working AC Adapter.
If neither of those work then its an issue with the motherboard DC Jack needing to be resoldered back into place.
Aug 22, 2009 | Acer Aspire One AOA150-1405 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
NO POWER AT ALL
Remove the battery and unplug the AC adapter. With the AC adapter unplugged from the system, plug it into the wall, see if the power LED comes on. If it does, plug it into the system and see if it goes out. If the LED never comes on, or goes out when connected to the system, replace the AC adapter.
If the LED stays one, see if the system will power on and give any indications of power at all (Flashing Caps Lock, Scrool Lock, Num Lock LEDs) If no power indication with a good ac adapter connected, then the motherboard is the next item to replace.
Either item listed above can prevent the battery from charging. So the battery is the last item I'd replace unless the system turns on with the battery out of the system.
May 20, 2008 | Dell Inspiron 9300 Notebook
Open Questions:
Gateway MX7118 Notebook Logo
100 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
