Question about Pds GE Profile Bottom-Freezer Drawer Refrigerator Energy Star 22.2 Cu. Ft. - PDS22MFS
GE Arctica refrigerator is making a noise like someone is knocking at the door for about 5 seconds, then it stops. I have narrowed it down to a fan at the bottom of one of the refrigerator doors on the inside....when the fan stops....this noise starts as the fan blades slow down. it doesnt appear stuck on anything either or being blocked
  • Anonymous Mar 18, 2009
    I have a GE model # stating with gts the banging is now so loud it wakes me up and scares me during the day  what the heck is wrong with it?
3 Suggested Answers
tborn6
  • 700 Answers
SOURCE: GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
Posted on Jan 24, 2009
heatman101
  • 43501 Answers
SOURCE: 16 month old GE Profile
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
Ge profile artica constantly knocking
Broken internal motor mounts in compresser.
Jun 03, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Knocking sound in upper left of refrigerator.
Yes, there is a ventilator (fan) for recirculating air. Looks like needs some maintenance (bearings regreased/oiled) or, if the worn is too high and blades are disbalanced, a new one.
Sep 11, 2017 | GE GSS25JEMCC Side by Side
My Jenn Air French Door Professional Refrigerator makes a strange annoying knocking sound. It seems to come and go and happens for a few seconds to close to 1 minute. It will stop soon after I open the...
You have two fans and a compressor which could be making the noise. Inside the freezer behind the back cover is the evaporator fan. It probably stops running when you open the door. Hold the door switch down to keep the fan running to see if it's making the noise.
the compressor and other fan is under the unit accessed from the back behind the cardboard cover.
Nov 30, 2009 | Jenn-Air JFC2089HE French Door...
GE Profile making knocking noises at different times
I have the GE profile Refrigerator with ice maker in the refrigerator compartment. Mine was knocking loudly for long periods of time, so I finally removed the icemaker by removing the side panel in the icemaker compartment held with 1 phillips head screw, disconnecting the electrical plug (unclip), pulling the tab of the icemaker down (on top) and sliding it toward the door, thus removing it. There was ice frozen in the motor compartment that was the problem. I let it thaw out and re-installed. All was OK after that..
Jun 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Dec 16, 2008 | GE Profile Arctica Stainless Steel Top...
The Top Freezer Is making a Loud buzzing Noies!
Hello psimmons304,
Yes it does sound like a issue for the fan. What i would do is look up the model on google and type in replacement fan. you should be able to find it that way.  If this doesn't answer your problem please post again.
Please post what you do and how you did it. I look forward to your posts.
Nov 11, 2008 | GE Profile Arctica Stainless Steel Top...
Open Questions:
I've had a problem with my GE profile fridge (bottom drawer freezer), purchased in 2006. My GE Profile refrigerator is running non-stop, is not keeping food cool in the refrigerator section, and continues to be very cold in the freezer (ranging from -18 to -1 fahrenheit) I called ****** and arranged for a technician to diagnose the problem. The first visit occurred on November 4, 2008. The technician could not diagnose problem, and then called the GE tech line. He then told me that the problem was caused by one of 3 things: main board, defrost heater, or a thermostat. The repair tech did not have the correct parts available, and said that they would have to be ordered, and a call to GE tech line again to confirm parts needed and he would call me back. I paid $70.00 for this visit. A different technician arrived at my home on November 6th, and told me that it was not a defrost heater or a thermostat problem, but rather that a new main board would be needed, and possibly a new damper. The main board was installed and the damper was forced half way open to keep the refrigerator cool while the technician called the GE service line to confirm this problem. The technician stated that he would call me back in a few days, and I paid $230 for a new main board. The forced damper kept the refrigerator fairly cool for about 1 week or so, but then the refrigerator became warm again and stopped reading the temperature accurately. I never received a call back from a technician, so I called ****** on Monday, November 24th, and arranged to have a technician come to the house again to see why the refrigerator was again 55 degrees, but yet reading at 34 degrees. A technician arrived on Friday, November 28th and replaced the main board again, and also replaced a damper sensor and stated that this should fix the problem. At the time that the technician was here, the vent was indeed blowing cool air into the refrigerator and the temperature appeared to be accurate. I left the house and ran errands for about 4 hours, and returned home to a warm refrigerator that read ?37? for the temperature. The refrigerator was running and there was no cold air blowing in the vents. So, this did not fix the problem. I then called ****** again, and discussed the problem, and the owner of ****** then comes over, and appeared to not really be concerned that I?ve had technicians here three different times over the past month, that I?ve paid $300 in repairs and still do not have a working refrigerator, and that I?ve had to keep my food and drinks in coolers for the past MONTH. The refrigerator has continued to run all weekend, non-stop. The temperature reading remains at ?37? and the refrigerator is warm. The freezer is working, and keeping the food frozen. I am starting to wonder how much this is costing me in increased electricity to keep the refrigerator running non-stop. I would prefer to unplug the refrigerator if it isn?t working, but I was told that I needed to keep it running to diagnose the problem. I am about at my wits end, and am about to push the damn thing into the street and go buy a new one.
Feb 26, 2017 | Pds GE Profile Bottom-Freezer Drawer...
Pds GE Profile Bottom-Freezer Drawer Refrigerator Energy Star 22.2 Cu. Ft. - PDS22MFS Logo
154 people viewed this question
Top Pds Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
LARRY BARAN
LARRY BARAN
Level 1 Expert
Are you a Pds Refrigerator Expert? Answer questions, earn points and help others
