Question about Ricoh Aficio 450 Copier
Afficio 450 copy faded in some area...
Hi can any1 help me.. wat is da problem of my copier afficio 450 wen i make a copy.. the copy is not good bcuz some area of txt is faded... or the copy is not equal...
  • Tim Babcock
    Tim Babcock May 11, 2010
    Usually when that happens, it means you need developer for your copier. What is the copy count?
  • 162 Answers
It can lack developer in the revealing unit it checks and it adds or it replaces.
Posted on Sep 13, 2009
If the image is good in parts, but light in others it is most often toner build up on the laser exposure glass which can be easily -but also VERY CAREFULLYremoved. If you lift the green handle for the toner bottle, you should see a narrow piece of glass protruding just underneath. You can grasp it with you fingers and slide it out for cleaning. Sometimes these have been removed (or broken) so they are not there. If the machine is also a printer, you should see much improvement (if this was the cause). If regular copying is still light in areas, then you may want to remove the copier glass - 2 screws on left scale, and 3 screws on rear scale (POWER OFF ON MACHINE), remove glass and clean with glass cleaner, then slide scanner to the left and clean the mirrors.
Hope this helps.
Posted on Feb 13, 2009
Parts and consumable of afficio 450
http://www.ricoh.com.ph/support/contact.html
Sep 07, 2009 | Ricoh Aficio 450 Copier
Afficio 450 developer type 4 or type 5
This machine takes Part Number "887733: Developer Type 5"
Hope this helps.
Jul 05, 2009 | Ricoh Office Equipment & Supplies
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Did you use a vaccum on the developer unit???? You may have blown out the ATDC sensor on the developping unit
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Jan 26, 2009 | Ricoh Aficio 450 Copier
The copy of afficio 450 become lighter
You may want to consider putting developer into the unit. What is the copy count on the machine?
Jan 15, 2009 | Ricoh Aficio 450 Copier
Afficio 450e gray copy or lighter copy
Look into replacing the developer in your copier. It has to be replaced every 125,000 cycles.
Jan 14, 2009 | Office Equipment & Supplies
Copier.... afficio 450 vs konica 7025
You're talking about two really old machines, the 450 from 1998 & the 7025 from 2000.
Both are about the same class, but I'd give the edge to Ricoh since it was also sold under a number of other brands & replacement parts are readily available.
Hope this helps...
Sep 10, 2008 | Office Equipment & Supplies
Afficio 450 camera lense alignment
You need a manual to calibrate the scanner do you have one?
There are some holes in the scanner that need to be calibrated with a tiny screwdriver. The manual teslls you the correct settings.
Did yiou remove the cable?
Aug 19, 2008 | Office Equipment & Supplies
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
121 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
