Sir how to make stright cable and cross cable make caan you help
I have big network i have no little bit but help me pls and otherwise how to croscable and stright cable make with color wise right dowan plz
    Scholar:
  • 108 Answers
This is the easiest way to tell you. Copy and paste this address in you address bar. It has steps and a diagram.
http://www.duxcw.com/digest/Howto/network/cable/cable5.htm
Posted on Jan 17, 2009
How to unhook monster cables
Hi there, i posted a link to a monster manual, hope it helped with your problem otherwise you might have to be a little bit more specific, let me know if it works. :)
http://www.monstercable.com/lit/MANUL_THX_G1ls.pdf
Jun 26, 2012 | Monster Cable (109611)
DEAR SIR, I CANNOT ABLE TO PRINT THROUGH PRINT SIR PLUS 10/100 PRINT SERVER (PS1203) THROUGH NET WORK. I CONFIGURED EVERYTHING BUT I CANNOT ABLE TO PRINT. REGARDS BASHEER
If you have configured every thing correctly , the problem may be with the network cable. There are (2) types of network cables are available.They are 1). cross net work cable ,2). Parallel network cable. I think you have used the parallel network cable. Now try to purchase the cross network cable or you may prepare it if you are awre about it. Hurray ! your problem will be solved automatically.
Even though if your problem is not solved , kindly follow the instructions as follows;
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ). According to above addresses, you have to complete the networksettings of your printer by mentioning the different IP address .
To find out the above mentionedaddresses first open the control panel -> network connections -> local areaconnction -> properties -> Internet Protocol Version 4(TCP/IPV4) ORInternet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection asmentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , thegateway may be 192.168.0.1 Or any number. And the subnet mask may beXYY.XYY.XYY.0.
Accordingto your ISP addresses you have to complete the network settings of yourprinter. First press the additional functions -> system settings ->network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your networkconnction with the printer to your computer will be automatically solved.
Sep 28, 2010 | Edimax PS-1203 Print Server
Not able to connect to network
use branded cable of lan (pre climped by Dlink company). Example:  D-link 1mt stright for pc to hub, hub to meachine. if u connect directly pc to meachine use cross cable it will be salove.
Mar 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
ONE LAN CONNETION AND THREE COMPUTER
Sure you can
In fact the wireless router is your best bet for multiple systems to connect to the net.
As per crossover wiring you can interlace the computers via using their USB ports.
Jul 27, 2009 | NAD L40 CD Player
Cannot connect my wireless adapter to Belkin wireless router
hi,
ok sir i got it if the wireless network is detected then try and connect and the if it doesnt connect try and connect in safe mode with networking sometimes wireless doesnt work in safe mode,but still try that,uninstall and reinstall the wireless driver for adaptor and then open the gui page(router page with the default gateway page and then change the wireless channels and also turn off the firewall,and from the start,all programme turn on the wireless adaptor utility and then start the services of wireless zero configuration from services.msc.....then if it is connected with the ehternet cable,then what u can do is that go to the router page and then also put a check in the let the windows controll the wireless network......and it will definately work and if it doesnt work then reinstall the operating system......good luck...
if it is a little bit also helpful pls.rate this soultion for me pls.....
Feb 07, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Virus affected our network
hello sir,
first checkout which one node uploding more data on network, nd chocked ur whole network, remove these node from ur network and check another node working good then scan findouted pc from symantec antivirus otherwise take backup and reinstall windows on problumatic pc.
Yogesh Tetarwal
(System/Network Engineer)
Feb 02, 2009 | HP Compaq thin client t5510 (PC539TABU)...
Faillure connection
Hi
I think in cable is faulty, when conneting to pc to switch, cables as to straight cables, pls cross check the cable..
Jun 03, 2008 | Computers & Internet
When I goto my web browser to install my router it says connection has timed out, I put in http://192.168.1.1/ Tried it so many times I dont know why. Really aggrovating im trying to hook my 360 up for...
follow these steps
1) connect the stright cable from your router to a switch and connect another stright cable to the pc from where you are trying to access the router.
2) if you dont have a switch connect a cross over cable directly to pc from the router ( stright cable some time works)
3) Change the PC Ip address to 192.168.1.150 and subnet mask 255.255.255.0
4) open start programs --> run --> and ping 192.168.1.1 ( u should able to ping)
5) if pinnging is ok .. then connection to router is good
6) now open your browser and type http://192.168.1.1 -- this should work now.
7) if fails -- try resetting the router -- you can see a small hole besides your network ports or somewhere around
8) once reset try agin opening the browser
9) if all else fails probbly the firware in router is corrupt ,, u need to reinstall .. them contact the support site of your router
Good luck
Jan 19, 2008 | NexxTech 4-Port Ethernet Broadband Router...
Networking
This site will give you directions on how to make a CAT5 cable. http://www.computerhope.com/issues/ch000639.htm
Sep 17, 2007 | Computers & Internet
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
