Central heat and air freezing up
My heat and air is freezing up,because it is very cold out side. What do I do to get it not to freeze up and to blow cold air in home.
    President:
  • 2,559 Answers
It is not freezing because it's cold outside,It is freezing due to a problem.
It needs to thawed before it will work,
1st:Check or change the filter if need be.
2nd:Make sure none of the vents are blocked off(especially the return)
3rd:The only way to thaw it when temps are low outside,without being out in the weather is to turn on the air conditioner,You will need to use other means to heat your home until it thaws.
and Please if you use the stove for heating,don't fall asleep with it on.
Posted on Jan 17, 2009
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Overheating
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Jan 30, 2012 | 2003 Chrysler PT Cruiser
Central air stops blowing cold after about 4 hours. The air blows at 63 degrees when it's cold.
Sounds like your evaporator coil is freezing up. This is a sign that you have a restricted air flow over the evaporator or you're low on freon. The 63 degree tempurature is indicitive of low freon. You should call in an a/c expert to check the freon level and while he's there have him clean the evaporator coil.
Oct 03, 2010 | Heating & Cooling
Its 15 degrees outside and my amana unit is off. every so often it kicks on by itself and runs for about 10 seconds then shuts off again. while it is running the control panel flashes FP, what is it trying...
I was wondering the same thing about our unit until I found the specs online and read that it has freeze protection. When the temp goes below 40 degrees, the fan comes on to prevent damage to the unit.
Dec 23, 2009 | Amana PTH123B25AJ Heat Pump Air...
The last time i used my ac here in las vegas nv. was july 2009 and it was freezing. i terned it on to check to see if it still blew cold and it dosnt. blows air fine but dosnt get cold, is there a re-set...
central air or window unit? central systems use a low/high pressure limit switches which self reset when pressures are nominal. suction about 50-60, high pressures around 300.
Oct 20, 2009 | Heating & Cooling
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer not freezing and blowing luke cold air. Fan running full time.
rotate the defrost heater timer until it clicks and see if the defrost heater is working
Jun 02, 2009 | Refrigerators
Unit Won't Cool Or Heat Just Blows Air and Displays FP
fp means freeze protection when gets too cold out unit comes on by itself so pipes dont freeze
Jan 17, 2009 | Amana PTC093B50AJ Electric Heat Air...
Home central air conditioning unit
check the filter, make sure it's not plugged. Make sure all the vents are open. Are the lines freezing up (have ice on them?) Could be a lot of things but if it is not blowing much air then you may have a motor problem or dirty filter. If the unit is freezing up then probably have a leak and will need to be found, fixed and recharged.
Jun 09, 2008 | APC Heating & Cooling
Heating & Cooling Logo
208 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
