My heat is freezing up because it is cold out side,what do I do
  • BOB  BROWER
    BOB BROWER May 11, 2010
    i am guessing this is a heat pump? oil heat ? propane ? hot water baseboard ? . you are under "air conditioners" ? what make ? how old ? i cannot help without knowing what you have SORRY
Sounds like you having a problem with the defrost board, also check to see if the freeze stat is connected, if not it will not since the coils temp and send a signal to the board to go in defrost and your electric heat strips should kick on if you have them. Depending on what unit you have you be able to which the dip switches to call for defrost at a quicker or longer time depending on the outside temp.
Posted on Jan 17, 2009
How can I turn off the freeze protection this units are running in electric heat only is like 32 out side
32 deg s out strip heat will run and if you remove defrost your unit is going to freeze up. When that cold assuming you have a heatpump strip heat is needed .is it a threw wall heatpump?
Feb 18, 2015 | Heating & Cooling
Needs to defrost more often?
tHE FRIDGE TIMER IS SET TO DEFROST EVERY 8-10 HOURS AND IS NOT MEANT TO BE CHANGED. IF UR HAVING A COLD FREEZE ISSUE YOU MAY NEED TO CHECK THE HEATING ELEMENT OR MORE LIKELY THE THERMISTORS AND COLD CONTROL THERMOSTAT
Aug 06, 2014 | GE 21.7 cu. ft. Side-by-Side Refrigerator...
Overheating
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Jan 30, 2012 | 2003 Chrysler PT Cruiser
Its 15 degrees outside and my amana unit is off. every so often it kicks on by itself and runs for about 10 seconds then shuts off again. while it is running the control panel flashes FP, what is it trying...
I was wondering the same thing about our unit until I found the specs online and read that it has freeze protection. When the temp goes below 40 degrees, the fan comes on to prevent damage to the unit.
Dec 23, 2009 | Amana PTH123B25AJ Heat Pump Air...
My 2002 s type jaguar doesn't heat. the fans
Probably the heater control valve, had same issue, started with one side not hot, then erratic, hot then cold while heat is set to hot, now both side are cold to lukewarm. diagnosed as heater control valve, common for jag s-types and x-types. located on the passenger side, down low the side of the radiator, it has several hoses into and out of valve, and a electrical connector.
Oct 20, 2009 | 2002 Jaguar S-Type
The frizer outside is very hot. kenmore model 71192107 year7/02
The condensor coils run around , up , down , the sides of the freezer . This heat is the heat being pulled OUT of the inside , which makes the freezer cold . Freon (refrigerant) attracts heat , which causes the frost in refrigeration . But , the heat has to dissapate , otherwise , hot gas would pump thru the system , and , no cool . A freezer does not get cold , Heat is pulled out , causing food to freeze . So , hot is good .
Aug 01, 2009 | Refrigerators
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
Central heat and air freezing up
It is not freezing because it's cold outside,It is freezing due to a problem.
It needs to thawed before it will work,
1st:Check or change the filter if need be.
2nd:Make sure none of the vents are blocked off(especially the return)
3rd:The only way to thaw it when temps are low outside,without being out in the weather is to turn on the air conditioner,You will need to use other means to heat your home until it thaws.
and Please if you use the stove for heating,don't fall asleep with it on.
Jan 17, 2009 | Heating & Cooling
Hotpoint hss25gp Not keeping cold or freezing
Check and clean the condenser coils where heat is transfered to the room air. If they are plugged with dust it will cause your problem. Check the back wall of the freezer for snow. If snow is on the back wall you have a defrost system problem.
Mar 09, 2008 | Hotpoint HSS25GFP Side by Side...
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
