Question about IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric III backspace not working.
Is there something I could check myself to see why the above is not working? The liftoff tape is working fine (once I position it correctly), and the express key works fine, but the correction key and the backspace key will not work and just make a noise when pressed. I bought this typewriter new years ago and rarely used it. Just pulled it out of the cupboard as I am thinking of selling it and was dismayed to find the above problem. Thanks in advance.
  • noyuppie Mar 13, 2009
    Wow, that would be cool if it is a 10-second fix. How do I email you?
It's a 10 second fix with a can of non-drying lubricant (I had the same problem). email me/repost if you still have this problem and I'll tell you exactly where to spray.
Posted on Mar 13, 2009
  • markiemark1 Mar 13, 2009
    Noyuppie, you can reach me at (I'm going to deliberately encript this) mark92663 at yahoo dot com and I'll give you my phone #.
  • 297 Answers
Since it hasn't been used in quite a while the lubrication in the machine has become gummy & sticky. The cam that operates the backspace is being activated, but the arm that drives the backspace mechanism isn't being pulled on.
Machine needs a deep cleaning and oiling and then readjusting to correct this problem. (Don't spray WD-40 in it...makes it worse !)
(This repair is usually beyond what a non-technician can do.)
Posted on Jan 17, 2009
Theres a manual here that should tell you everything you need to know.
Dec 05, 2014 | IBM Correcting Selectric III Electric...
Correction tape won't work. correction key works. read your comment on wd40, but won't wd40 gum up the works?
do not use WD40 an any typewriter. Are you pressing the letter you want lifted of after the correction key> Is the dull side of the lift off tape facing away from you?
Jun 30, 2014 | IBM Correcting Selectric Iii Typewriter...
Not correcting & corrector ribbon not moving to correct
At this point almost all selectrics suffer from a case of the gummies.
it most likely needs a tech that under stands the selectric.
Aug 28, 2012 | IBM Correcting Selectric Iii Typewriter...
IBM Selectric III stopped working
Needs servicing. it slow up because the cycle clutch needed lube, Never leave on a selectric it will over heat the motor. and shut off totally, but after it cools it will turn on again. Turn the silver bar that goes through the carrier. a slight bit top away from you and try turning it on. May work for a bit
Mar 27, 2017 | IBM Correcting Selectric III Electric...
IBM Selectric III correcting. Carriage return and
You most likely have a broken torque limiter tension spring. We have them in stock but tou must have a good mechanical ability to install.
Jan 29, 2010 | IBM Office Equipment & Supplies
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
May 28, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II backspace not working
The tab tensioner is probably broken you need a tech.
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
268 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
