Question about Dell Dimension 4500 PC Desktop
Processor upgrade I got a dell 4500 dimension and was wondering how fast of a processor will it handle.
    President:
  • 948 Answers
What is the service tag? Pentium 4 2.8 GHz is the fastest they put in them according to Dell, but not all of them have the hardware to support the 533MHz Front side bus.
Posted on Jan 17, 2009
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
I have an AA A83421-107 motherboard, E210882. I want to upgrade the video card and was wondering what the details are for my mother board?
Your model 4500 has an AGP slot for video cards. The Accelerated Graphics Port (often shortened to AGP) is a high-speed point-to-point channel for attaching a video card to a computer's motherboard, primarily to assist in the acceleration of 3D computer graphics. Since 2004, AGP has been progressively phased out in favor of PCI Express.
Here is a link to the technical specs of your motherboard:
http://support.dell.com/support/edocs/systems/dim4500/specs.htm#1101572
Jun 24, 2011 | Dell Dimension 4500 PC Desktop
Looking for what kind of processor upgrade
Well it seems you can go up to at least a 3.6GHZ processor. It is socket 775, so any Processor that will fit will in all likelihood work fine. As for the hard drive well I like 7200RPM 8MB Cache 3GB/sec SATA drive. or similar spec, & truthfully one brand is as good as another... But if forced to say.. well Seagate.
Also if you want a fast machine RAM as MUCH as you can put onboard and afford.
I have found a manual here for you. http://support.dell.com/support/edocs/systems/dim9100/en/D86630LRs.pdf
Feb 03, 2010 | Dell Dimension 9100 PC Desktop
Can dell dimension 5100 run windows vista? Does it have a dual core processor?
Your computer can handle it hardware wise, the issue your going to run into is you need to find the vista version of your hardware drivers since the Dell website doesn't have vista drivers for your computer.
Jan 06, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Need graphic card upgrade for Dell Dimension 4500 w/ pixel shader
This is an older machine that has a 4x AGP port for graphics cards. The good news is that cards for this slot are cheap...usually in the 30-50 dollar range. The downside is that you wont get the greatest performance out of them. I would recommend going with a Geforce FX 5200.
Nov 24, 2009 | Dell Dimension 4500 PC Desktop
Dell Dimension 4300 PC Processor upgrade
if the sci36-r13 is the stock mobo that came with that pc it isnt worth upgrading
pentium 4's use the LGA-775 socket this is compatible with all pentiums and core 2's (not includeing core i7), so you could put in a core 2 quad if you wanted to but it would not make much difference to performance because your motherboard would not be able to handle some of the fetures
your ram would also reduce preformance
if you wanted to upgrade that computer you would have to replace everything but maybe the case
Oct 12, 2009 | Dell Computers & Internet
I need help upgrading PLZ URGENT dell dimension E521
The most powerful CPU Dell sole in the E521 was the 5600+, 2.8G, Pretty Cheap on EBay
http://shop.ebay.com/i.html?_nkw=Athlon+5600%2B&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Athlon%2C+5600%2B%2C+2.8G%2C+1MX2%2C+Dual+Core%2C&_osacat=0
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150369
Power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
Oct 08, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
I want to know what speed my board will handle for the processor
Per Dell documentation, your computer has a NVIDIA motherboard with AM2 socket. Both the dual core processores support this socket. So, the board should be able to take it. However, the Maximum temperature and wattage for both is different.
Mar 25, 2009 | Computers & Internet
Upgrade cpu
It is a bit of a crapshoot trying to upgrade a processor from a major manufacturer. Their motherboards are designed specifically for the manufacturer and documentation on exactly what will work NOW compared to when the unit was new is rather hard to come by. They don't support people upgrading very well compared to the aftermarket manufacturers.
You should go to dell.com and put in your service tag to check your exact configuration yourself before spending any money.
According to Dell, the Dimension 5150 has a motherboard that uses the Intel 945G Express chipset. You can see INTEL'S documentation on that chipset's capabilities here. According to that documentation you can use a socket LGA775 with up to a 1066 MHz system bus speed.
Looking at Newegg, the fastest LGA775 processor with 1066 MHz are a 2.93GHz Duo core or a 2.4 GHz quad core. Again, no guarantees either will work with your system, and you definately want to make sure your power supply and case cooling are up to the task.
Mar 21, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Looking to upgrade processor
your motherboard chipset is Intel 865GV and it supports Pentium 4
Dec 25, 2007 | Dell Dimension 3000 PC Desktop
Dell Dimension 4500 PC Desktop Logo
119 people viewed this question
Alun Cox
