Question about Sony PlayStation 2 (PS2) Console
Rear Interlock switch for playstation 2 slim needed
Hi, I'm looking for an interlock switch for a playstation 2 slim. To my understanding there are two switches, one located at the front right and one located to the left rear of the laser deck. I need the one located at the rear. Where can I this device? Or are there some pins that I can short to get the same effect. The button on top of the switch is broken off/missing. If you have a replacement part that would be great or any info that you may have will be helpful also. Thanks in advance for your support. Sharma
Sldulin, we are having the same problem. Our PS2 the little rubber black piece is unglued and mom
saw a sandwich bag on our glass end table and through it away, not knowing that the broken off switch was inside. So now we have to find a little rubber pad to glue back on the board so it will work. So if you know where we can get one send to our E-mail that info.
Posted on Jan 19, 2009
What is the de error message
Hi Prasanthi.
On front load machines, some manufacturers us de as 'door error'. This generally relates to a fault with the interlock mechanism.
This is the door lock which prevents the door from being opened while the machine is working..
If the door won't lock and/or the machine won't run. OR the door is locked shut, then this is the most likely situation.
The interlock switch is part of the electrical circuit.
NOT recommended for a handyman.
It's not a big job for a technician, and you will probably need a new interlock.
Good luck.
Interlock switches look like this.....
Feb 09, 2015 | Washing Machines
In the Model C524 - The display show "112.05 Service Print Head Error" - Pls, I need a expert solution (Urgent) Tks, so much.
1 Is the front access door completely closed?
Yes)Go to step 2.
No) Properly close the door.
2 Turn the printer off, and remove the rear cover.
Check the connector JINT1 (5 V interlock switch cable) for proper connection to the system card, the cable for pinch points, and the cable or connector for any other damage.
Is the cable damaged?
Yes) Replace the front access door 5 V interlock switch.
No) Go to step 3.
3 Turn the printer power on, and check for 5 V dc between JINT1 pin (red wire) and ground.
Is voltage present?
No) Go to step 4.
4 Replace the printhead. Does the error clear?
Yes)Problem solved.
No) Replace the system card.
Aug 22, 2011 | Lexmark C524 Laser Printer
Mijn printer een lexmark c532n geeft 113.01 SERVICE PRINTHEAD ERROR
An error has occurred in the yellow channel of the printhead.
(Yes) Go to step 2. (No) Properly close the door.
2 Turn the printer off, and remove the rear cover.Check the connector JINT1 (5 V interlock switch cable) for proper connection to the system card, the cable for pinch points, and the cable or connector for any other damage.Is the cable damaged?
(Yes)Replace the front access door 5 V interlock switch. (No) Go to step 3.
Is voltage present?
(Yes) Replace the front access door 5 V interlock switch. (No)Go to step 4.
(Yes) Problem solved. (No) Replace the system card.
Jul 17, 2011 | Office Equipment & Supplies
Hi I can't get the washing machine door to open on model w970 please help
sounds like interlock has packed in.
you need to remove lid...............put your hand down front of door interlock and flick the switch.................replace interlock asap.....
Mar 26, 2011 | Miele Washing Machines
I have a 2004 F150 supercrew 4x4 and it will not shift into park and when I start it I have to put it into neutral any help Thanks
Sounds like the shift interlock circuit has an issue.
This can be 1 of 3 places
1. The fuse for the Shift Interlock circuit. This is fuse #16
2. The shift interlock switch. This is part of the BPP ( Brake Pedal Position ) Switch that also controls the brake lamps. There are 2 switches in the BPP switch, 1 for the shift interlock, the other the brakes. The circuit in the BPP switch for the shift interlock is the Tan w/ Red stripe wire ( from fuse # 16 ) to Pink w/ Light Green stripe ( to the shift interlock solenoid ).
Test both side of this circuit with a meter ( to ground ) you should have power on the Tan w/ Red stripe wire any time the key is in the Start or Run position.
The Pink w/ Light Green stripe wire should have power any time the brake pedal is pressed down.
If you do not have power at the Pink w/ Light Green stripe wire, you need a new BPP switch.
If you have power with the brake pedal pressed on this wire, you need a new Shift Interlock Solenoid.
Jul 05, 2010 | 2004 Ford F150
GE JVM1440 doesn't work, appears to be the primary interlock
I would refer you back to my solution here. It has links for ordering parts, and it talks about securing your door switch to its mount, etc. You may need to realign things, too.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
You can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Mar 01, 2009 | GE JVM1440 Microwave Oven
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
hi billy
the most likely cause is probably the interlock switch has gained some play through wear an tear replacing it may solve it but first check that the door hinge hasnt been put out of alignment by the door being pushed open futher than needed. fitting a new interlock switch is relatively easy on most models might have it
hope this helps
Oct 25, 2008 | Frigidaire FWT449
Safety Interlock "Switch"
This is not the safety interlock switch. This flat bar keeps shredder paper from backfilling into the cutters. The safety interlock switch is a vertical slot on the body that a tab on the top fits into.
Feb 29, 2008 | Tech Solution TS-4500 Shredder
Disc won't spin. Disc doesn't show up in browser
You got a problem with the lasers data getting back to the Motherboard.
One of these could be your problem
  1. Laser lens is melted. Look at the lens with a magnifying glass to see if it or its supporting frame is melted. REplace the laser in this case.
  2. The ribbon Cable going from the Laser to the motherboard is damaged or loose.
  3. Your laser is burned out. Press the two interlock to override the door being open, to see if the laser even lights up. 2 switches, one at rear left corner, one behind the On/reset switch.
  4. Your Laser is dirty and needs cleaning look at it with a magnifying Glass to make sure you got it clean. Use Q-tip and window glass cleaner, not alcohol.
Nov 25, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
