Question about HP Compaq Presario V2000 Notebook
Installed more memory into Compaq V2000
IU installed some more memory into the notbook now it beeps 4 times and wont start.
  • 1 more comment
  • vpage Jan 17, 2009
    It has a AMD Sempron Processor and 384 MB Ram expandable to 2G with 30GB Hardrive. It is so slow so thought I would add more memory to try and quicken it up. I bought 516mb Ram but it doesn't look the same as the other ram. I removed the new one and replaced the old one and it started OK so maybe they were uncompatible. I think it is time for a new faster laptop.
    Thanks for the help.
  • Michael Lucas
    Michael Lucas May 11, 2010
    256-MB DDR synchronous DRAM (SDRAM) at 266 MHz,
    expandable to 2.0 GB on models with Intel Pentium M
    processors and 1.0 GB on models with Intel Celeron M
    processors
    Did you install DDR or DDR2 memory. It makes a difference. The 4 beeps are an memory error code.
    Let me know what has been done so I can help you further.
  • Chris Hingee
    Chris Hingee May 11, 2010
    What was the original RAM size and what did you increase it to?
    Are the RAM modules fron the same manufacturer and the same type?
    Problem Solver:
  • 10 Answers
The new ram you have installed, is it the same speed/type as what is already in the system?
Take out the new ram and leave the old in. Try and boot. If all ok, swap out the old ram for the new and see if you can boot. If the system does not boot when trying one of the above, you know it's bad ram. If the system boots with the old ram and the new ram installed seperately, i'ts likely that you have two different types of ram. Check your old ram and see what spec it is. Your new ram should be the same. Compaq do not list a four beep error on boot, but my guess is conflicting ram.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Posted on Jan 17, 2009
What is wrong when my compaq v2000 beeps 2 times loud when I turn it on but no boot
Beep codes are unique to each brand of computer:
Compaq v2000
1 short with 1 long beep = bad bios. Must reload bios from disc.
2 short beeps = general bios failure
for more - do a google search for "v2000 Beep Codes" and go to the link for "bioscentral" - all are listed.
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
Computer will not start
It all depends how many beeps there were.
From http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML
Diagnostic LED Explanation Table Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
I have only really come across 4 beeps = order new Power Supply or 5 Beeps = reseat the memory and hope it works
Regards,
Oli
Apr 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
Compaq V2000 "Press <F1> to resume, <F10> to Setup
re install the operating system.insert the recovery disk and follow the instructions.
Feb 20, 2010 | HP Compaq Presario V2000 Notebook
Tha laptop just beeps when switched on. power ok, nothing on monitor - beeps 4 times then that is it!!!
4 short beeps might mean you have a bad memory module (beeps are coded) .. if you have two memories installed you can try takeing one out at a time .. it will start working when the good module is the only one plugged in .. just removing and replacing the memory sometimes cleans the pins so that it works again .. ... there are other possibilities that are more expensive usually ... so you hope its just the memory .. here is a site that gives beep codes for many machines ..
http://kb.iu.edu/data/afzy.html
Oct 06, 2009 | HP Pavilion dv6000z Notebook
5 beeps
do you have the RAM chips installed in the right socket, and the right way?
Aug 09, 2008 | HP Compaq d530 CMT PC Desktop
Presario V2000 will not boot
When your computer starts press f10 to enter the bios ,there you will find the option to reset its setting to default.....
Was this solution helpful .Show your appreciation by rating it.
May 30, 2008 | HP Compaq Presario V2000 Notebook
4 beeps and blank screen
It's either going to be a video memory error or base memory error. Either one requires replacing the motherboard, which more than likely wouldn't be worth the money. You should probably get your data backed up and buy a new computer.
May 22, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
