Question about Whirlpool RCC3024 Electric Cooktop
Broke glass cook top for model RCC3024LB01
Can this be fixed without replacing the whole stove?
    Genius:
  • 2,920 Answers
Es the top runs about 400.00
Posted on Jan 17, 2009
How do you remove a 318223634 glass top frididaire
Good Afternoon Leslie, this is Z. Thank you for your post!
I see you are looking for information on how to remove the glass-top of your Frigidaire Cook-top (318223634). It appears above-listed model number is invalid; however, this is not a typical DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website. Best regards.
May 03, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Tip
GAS KITCHEN APPLIANCE CLICKING SOUND
Good Day,<br /><br />Have you ever had that problem with your Gas Hob, Stove or Cooktop where you hear a clicking the whole time, coming from <span style="font-weight: bold;">the ignition switches?</span> Well, then today I will show you how to <span style="font-weight: bold;">resolve the problem.</span><br /><br />Why does this happen? <span style="font-weight: bold;">Moisture</span> on the ignition switches... Be it because of you cleaning it obsessively or, because you might have had a small water spillage - the causes could be quite a few things <span style="font-weight: bold;">related to water.</span><br /><br />Now for the solution (Please note: I will be using a General Electric Stove & Hotpoint Hob as demonstration, but this solution should work for <span style="font-weight: bold;">most ranges - if not all</span>)<br /><br /><span style="font-weight: bold;">Step 1 (Safety first)</span><br /><br />Turn the machine off, switch it off at the mains if it is powered by it, and if powered by another source - Turn this off!<br /><br /><span style="font-weight: bold;">Step 2</span><br /><br />Remove the knobs of the Hob/Stove:<br /> <br /><img src="jedemeyer1_31.JPG" /><br /><br />If they do not come out, try to pull them as far out as possible, without breaking them. If there is a seal beneath them, then take it off as well - in the case if the knob does not come off, leave them be... If any grime or fat deposits are present, remove them with a damp cloth and some toothpicks.<br /><br /><span style="font-weight: bold;">Step 3</span><br /><br />Get a hairdryer, or fan.<br /><br /><span style="font-weight: bold;">If using the hairdryer:</span> <span style="font-style: italic;">Dry each knob area for 3 to 5 minutes for each knob respectively.</span><br /><br /><span style="font-weight: bold;">If using a fan:</span> <span style="font-style: italic;">Put the fan facing all the knobs, and leave it there for 30 minutes.</span><br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Step 4</span><br /><br />Leave the oven for <span style="font-style: italic;">about 20 minutes</span>, and then re-attach the knobs and seals and re-connect it to power.<br /><br />TEST, and viola! The problem is fixed.<br /><br />I have attached a video to this Tip, that shows a complete yet simple solution to this problem (Kindly provided by General Electric):<br /><br /><utube src="-vG9QQDiFCw"><br /><br />Now you can use your Hob/Cooktop/Stove with no more annoying clicking sounds.<br /><br />I hope this Tip has helped you, if it did - Please rate it.<br /><br />Kind Regards<br /><br />JEDEMEYER1<br />
on Aug 03, 2011 | Cooktops
Bosch NET9652UC STOVE TOP shows Er 42
Er42 constantly slashing on my stove top, sometimes lasted for hours. When that happened you can't use the stove top until it stops. What should I do to stop the slashing?
Feb 20, 2013 | Bosch 30 in. NET7452UC Electric Cooktop
I have a crack in the glass top cook top across the left front cook area. And this be fixed?
Hi glors732,m
A chip perhaps, but not a crack, you will need to replace the whole glass panel. Will be quite expensive though.
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it.
Aug 08, 2011 | GE 30 in. JP340 Electric Cooktop
The whole stove exploded while preparing dinner. Please any idea what would cause this to happen. My husband was slightly injured. Glass was flying everywhere. The cook top is 10 years old and we purchased...
it sounds like you got a dead short under the glass top , it could be a wire that shorted or some type of bug that got into the elements , I would even open the top with out pulling the plug out of the wall ,if it is 10 years old mite not be worth fixing but it should be looked at before you decide Frank
May 10, 2011 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Are replacement decals available for the heat settings around the stove knobs?
I just spoke to GE about this, NO, they DONT have decals, instead they want you to replace the whole Cooktop piece for $300 +...
Am so annoyed.
All my neighbors who have the same appliances put in by the builder are having the same issues. It's a GE problem.
Apr 05, 2011 | GE 30 in.JGP330 Gas Cooktop
Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
New stove top is smaller than old one.
Never seen one the hole is cut to size of the top so in most cases you go like for like .
Oct 08, 2017 | Cooktops
Roden Gas glass stovetop shattered MODEL GC73H
I have come across this occurence twice before.
With glass stove tops the glass is toughened and can generally withstand most temperatures associated with normal cooking situations. This, of course, assumes that there is sufficient space beneath the cooking utensil (saucepan, frying pan, etc) for air to circulate and the build up of heat to dissipate. If this cannot take place heat will build up to the point that the glass - a refractory material will no longer be able to withstand the internal and external forces created by the differences in internal and external temperatures and will thus shatter.
Though this is generally rare, it is known to take place and users are warned. Incidentally, this is the reason the shape of the glass top is the way it is and not the usual square as with other tops, in order for the heat to dissipate more easily.
In short, you should insist to your landlord that you were not misusing the appliance, but through genuine use this somewhat rare event occurred.
Aug 06, 2009 | Cooktops
Whirlpool RCC3024 Electric Cooktop Logo
593 people viewed this question
Top Whirlpool Cooktops Experts
vince
Timllfixit
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
