Question about Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
Getting error "Fuser Error Low Temprature" and printer not working for a week.
  • 5 more comments
  • JRNyman Jan 05, 2008
    IT IS NOT THE FUSER UNIT. IT IS IN THE WIRING HARNESS THAT CONNECTS THE FUSER TO THE PRINTER. REPLACING THE FUSER UNIT MIGHT, JUST FROM LUCK IN THE WAY THE CONNECTIONS MATE, FIX IT BUT NOT NECESSARILY.
  • Anonymous Apr 08, 2008
    I have a new Fuser, 110 V; Phaser 6100. It's properly installed and the "Fuser Error Low Temperature" problem still exists. Do you have another solution?
    Just as soon as the Ready light comes on, the message light comes on with "Fuser Error Low Temperature". I haven't been able to reset the new Fuser.
    Please help!!
  • rufo_sanchez May 15, 2009
    Fuser Error Lowe Temperature
  • Anonymous Mar 27, 2014
    the printer shows error 010-397. Fuser stays cold. Printer does not work.
  • Anonymous Mar 28, 2014
    HP5200 is not working properly with a massage 'fuser error'. I turn off the printer and turn it back on. but the problem is not solved. pls help me
  • Clycly
    Clycly May 15, 2014
    ther is a thermostat behind the fuser: keep off the plastic (one screw) and then verify the thermostat (2 screw to keep it off: then verify if it is well in short circuit, and screw it again: I manadge to run it again!)
  • Clycly
    Clycly May 15, 2014
    I've just sold this problem: 2 fuser: one is printing the other not! why? the two are in perfet state of work: I test them individualy on AC power heating was there! I finaly invert piece to piece: I've found! the thermostat on the oposite side of the label, was exchange and then the 2 fusers work! So unscrew the litle cover, 1 screw, unscrew the thermostat, verify it if it is well in short-circuit, and then just replace it and screw well: It works for mine!
  • 186 Answers
Time to replace the fuser assembly.
Posted on Jun 21, 2007
  • john archer Jun 26, 2007
    Did you replace your fuser assembly? If this did not fix your problem let me know.
    Novelist:
  • 208 Answers
Try this before replacing the fuser.
You do have to reset a new fuser also.
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset.
Posted on Dec 03, 2007
    New Friend:
I've just sold this problem: 2 fuser: one is printing the other not! why? the two are in perfet state of work: I test them individualy on AC: power heating was there! I finaly invert piece to piece: I've found! the thermostat on the oposite side of the label, was exchange and then the 2 fusers work! So unscrew the litle cover, 1 screw, unscrew the thermostat (2screw), verify it if it is well in short-circuit, and then just replace it and screw well and stronger: It works for my two fuser! (technicaly speaking, I think that the resistance of the 2 light and the two thermostat must be below a certain limit to alows the printer to work)
Posted on May 15, 2014
SOURCE:
I have Xerox Phaser 7400 with an error 928 we changed the fuser 2 weeks ago now the error has come back
Error 928 refers to the fuser motor failing. Problem could be with fuser motor, motor drive board or engine board.
One other possible cause would be if you are sending too thick a card stock through the machine, this can cause drag on the fuser which the machine interprets as a motor failure.
Hope this helps.
Jan 05, 2011 | Xerox Phaser 7400/DXF Laser Printer
Printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Mar 09, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Engine fuser low heat error on my xerox phaser 3500
You will need to replace the fuser.
You may want to look and see if you just have a piece of paper wrapped around the roll, but most likely the heating element has gone bad or one of the thermistors have failed.
Call 1-800-835-6100 and tell them the model number, and if it is a 120 volt or 220 volt fuser.
Feb 10, 2010 | Xerox Phaser 3500/DN Laser Printer
Fuser Error. Low Temperature
there is a small thermometer that contacts/sits very close to the metal heat roller on your fuser, chances are when removing the jam its been bent away from the roller, have a look and try and see if you can see it, not knowing this exact printer im not sure the exact position but it is usually in the middle of the roller coming from the top of the fuser housing, another thing to check is if your fuser is actually warming up atall, if you cant feel any heat then the fuser lamp that heats it up has gone bad
Nov 14, 2009 | Xerox Phaser 6100/BD Laser Printer
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
Sep 14, 2009 | Xerox Phaser 6120/YN Laser Printer
Xerox phaser 8500 error 13,327.42:31555
If you have Warranty Still, CALL XEROX!!!, That error message indicates that you have a failed temprature sensor inside the print-head, 90% chance Xerox will have to replace print-head. Print head is VERY expensive to replace out of pocket ($500-800+)
Jan 23, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 6100/BD Laser Printer Logo
2,735 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
