Gigabyte GA-8PE800 PRO Motherboard Logo
Posted on Jan 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I buy a GA-8PE800 Pro motherboard?
A couple capacitors went out on the old one. Need to replace with exact board to avoid re-saving all the data. Can't seem to locate one on the net. Any assistance would certainly be appreciated.
Jack
  • 1 more comment
  • jackday Jan 17, 2009
    I was told to replace it with same or all programs etc. would have to be saved and reinstalled. Is this bull?
    Jason:
    You've been very helpful. The problem is that I wouldn't have any idea how to install an OS.
  • Anonymous May 11, 2010
    Resaving all the data? "The data" is stored on your hard drive, which is typically unaffected by a motherboard failure. Is there some motherboard specific data you have that is irreplaceable?
Jason
Level 2:
  • Expert 42 Answers
  • Posted on Jan 17, 2009
Jason
Expert
Level 2:
Answers
42
Questions
0
Helped
9881
Points
112
Sorry Jack, I exhausted most of my resources and did not come up with one. This mobo will be a big pain to find. I would say buy a new board and unforunately reinstall your operating system. I know it's a pain, but I don't think you're going to find this board without some extreme luck.
What you could do, is find a similar board with the same north and south bridge, same chipset. This will allow you to not have to reinstall your OS.
It is possible to keep your current data set and still install a different motherboard. It requires disabling all plug'n'play support built into the OS before swapping the board. Then you install the new set of chipset drivers for the new board. I have made it work before, but its certainly not the cleanest way to do this, as you well know.
Sorry for not being anymore help. I can usually find old mobo's fairly easily, but this one must be a needle in a haystack.
  • Jason Jan 17, 2009
    While not reinstalling your operating system can be done, it is highly recommended to do so. It can be done, as I described above, but again, I do not recommend doing so.
2helpful
2answers
There are five capacitors next to the CPU cooling assembly on my Gigabyte GA-M61VME-S2 motherboard. One is leaking and two are bulging. Can these bad capacitors be replaced or do I need to replace the...
Hi,#
Yes they can be replaced if you were thinking of doing it yourself, desoldering the old ones is the hard bit, however if you were looking to get someone to do it for you I suspect the price may well go at least around the same price as simply replacing the board as its available
http://www.kikatek.com/product_info.php?products_id=37836&source=froogle
£37 (around $50 if your stateside)
1helpful
I need lan driver for ga-8pe800
Go to Google search and download the driver ga-8pe800 you will get it on the net!!!
2helpful
What RAM to use. I would like to use 1600mhz RAM but am not sure what would be the best to use. I am installing 12gb of ram. I will install 6gb now and another 6gb later.
Memory  6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system memory (Note 1)
 Dual/3 channel memory architecture
 Support for DDR3 2100/1333/1066/800 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)
and
Memory support list Date Subject 2005/05/12 Recommended memory module list for GA-8I915P Duo Pro ...More 2005/03/01 Recommended memory module list for GA-K8VT800 (Rev 2.0) ...More 2005/02/21 Recommended memory module list for GA-K8NF-9 ...More 2004/12/13 Recommended memory module list for 8I845GE-RZ/C ...More 2004/10/15 Recommended memory module list for GA-8TRX330-L ...More 2004/09/02 Recommended memory module list for GA-8TRS350MT ...More 2004/03/22 DDR400 support list for FSB800 CPU support - GA-8IE2004P \ 8IE2004P-L ...More 2003/12/23 PC3200(DDR400) Recommended module list for GA-8TRS300M ...More 2003/11/28 DDR400 support list for FSB800 CPU support - GA-8PE800 \ 8PE800-L ...More 2003/10/16 Recommended DDR400 (PC3200), DDR434 and DDR466 memory modules for GA-SINXP1394 ...More 2003/10/02 Recommended DDR200/266/333/400/466 Memory support list for GA-K8NNXP ...More 2003/07/23 Recommended DDR333(PC2700) memory modules for GA-8S650GXM-P (-C) ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SQ800 Ultra and 8SQ800 ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SG800 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-8SG667 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-7VAXP Ultra, GA-7VAXP, GA-7VAX, and GA-7VA ...More
1helpful
I have a Motherboard gigabyte GA-8PE800. when i
The ATX 12v ( 4 pin Connector ) is For The CPU Power.
This could Indicate, either A Faulty CPU.
Or a fault To The Motherboards ( BGA ) or CPU Socket Holder.
Or alternatively, The Actual PSU Itself is Faulty.
You can obtain A CPU Socket Tester from e-bay. And A PSU Tester.
Hope This Helps Mike @ Compurepair.
Please help me I forgot setup password of my computer that main board is 8PE800 PRO-R and bios is 845PE thank you
look for the 3pins near the CMOS battery, change it in position for about a minute, then put it back restart your computer password has now reset
GA-8PE800 MOTHERBOARD DRIVER
Hi, I'm listing a link below to the GIGABYTE site for your motherboard. Download and install the drivers for your operating system there. If this helps, please rate this answer. Thanks! Hal
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1619
1helpful
GA-8pe800 pro and kvr333x64c25 memory problem
the 1g is defective return it and get a replcement
Iv just been given a gigabyte GA-8PE800 motherboard
Gigabyte actually has a very good website. I pasted a link below to the CPU support list.
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1619
As far as what would be the best to buy I would say the closest to the top that you can afford ignoring the P4-Extreme CPUs.
2helpful
3answers
GA-8PE800
re seat your memory and clean them.
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
