Question about Dometic Rooftop RV Air Conditioner
Remote does not make the a/c or heat come on
I have a 2006 Landmark 5th wheel. Everything ran well until I ran out of propane last night. Now the Dometic Duo Therm (heat and a/c) remote seems to work alright and the unit's light indicates that it is on, but nothing happens. I put new batteries in the remote, but still nothing. I now have 2 tanks of propane, but still nothing. I have read the instruction sheets for the remote and re-set everything, but to no avail. Also, the unit was beeping before when I changed temperatures or modes, but I don't hear the beep now. I have checked the breaker and the fuse but they appear to be ok. Is there anywhere else that a breaker, fuse or re-set button may be? As of now nothing works on the unit - not the a/c, heat or even the fan.
The rotary girder might be broken.
Posted on Jan 17, 2009
Remove the wheel bearing/hub assembly from the
need detailed pictures of how to change rear wheel bearings on a chevy equinox
Aug 01, 2010 | 2006 Chevrolet Equinox
Have atwood furnace and coleman mach thermostat and it would not shut off. I unplugged power to rv and had to hit battery disconnect so that it would stop.waited few minutes...turned on...heat would not...
It may be your thermostat, but try this first to see if time delay relay may be sticking. When it won't shut off, turn propane off, and go outside and unscrew the 2 screws that hold your cover on, and lower the cover down. Look straight ahead, attached to the housing of the fan up near top you'll see a square relay (time delay relay) with 4 male spade connectors, and wires attached to each. It's usually held on with 2 Philips screws. Give it a little rap with the handle of a screwdriver or similar a couple of times, and see if fan stops running. While your there as well, pull the wiring connector off the ignition board, and put back on a couple of times, to clean the connections. Now try it again, and let me know what happens.
Apr 23, 2010 | Coleman Mach III Air Conditioner
Magic Chef propane in 90 Terry 5th Wheel
unfortunately the model plate for these
was usually mounted on the the drop wall
or were paper on the inside right corner
Oct 05, 2009 | Cooktops
Honeywell propane furnace. Ran out of propane last night. Refilled this morning. Has automatic pilot. Heat will not go on. Is there air in my lines? How would I purge the lines??
You will need to cut off power
find the gas shut off at your unit and cut off.
Loosen the fitting after the cut off and open the cut off slowly until you smell gas. re tighten and turn gas and power back on.
Nov 29, 2008 | Heating & Cooling
Defrost Cycle Problems
You need to replace the defrost board and sensor
Nov 21, 2008 | Weather King 10AJA6001AH Air Conditioner
Intertherm heater blows cold air.
do you have elec or gas heat? nat or propane?
Nov 16, 2008 | Intertherm P3RA-048K Air Conditioner
Bosch dryer not heating
make sure you try it a couple of times. gas takes a long time to travel to the pipes. no way to purge the lines.
check if there is propane in the new tank, check if the valve is open, check if the propane is at the hose going to the dryer already.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Bosch Nexxt WTMC 6500 Gas Dryer
GE JVM 2050BH001 does not heat but everything else works
hey! you told that everything working in your microwave oven! inside the microwave oven! transformer only producing heat! that transformer only fault in your oven! try to repair or change the transformer!!!!!!!
Sep 29, 2008 | GE JVM2050 Microwave Oven
Dometic Rooftop RV Air Conditioner Logo
228 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
