Question about Pentax Optio X Digital Camera
Out of Focus
My photos have somehow become blurred and out of focus. It happened earlier this year and somehow I managed to fix it by playing around with the settings. But it happened again and this time I'm totally stuck. Any suggestions without getting some repairman to fix it?
Have you tried to clean the lens?
Posted on Jun 20, 2007
SOURCE:
My samsung es80 does not make sharp pictures anymore
Difficult to go on only does not make sharp pictures anymore.
Seeing one picture says more than 1000 words. Still I give it a try.
When you are sure you did not change the focus settings and don't switch over to macro settings, while shooting normal, I can't help. But I do advice to look in the manual on page 41 and put the camera in Auto focus. (Not one of the macro modes) then when shooting, wait till the camera has focused, while you pressed the shutter realise button half. When the camera is in focus, the square in the middle of the screen becomes green, press the button down. (without moving the camera)
Also select a high resolution (big photo size) because small photo size is easy seen as a blurred picture.
Success
Feb 17, 2014 | Cameras
I have a nikon 55-200mm lens for the D40X digital camera. The pictures I take are blurred. I use the auto settings. the 18-55mm lens works fine and there are no problems with the picture clarity. Is the...
One of a few things might be happening
1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself.
2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light.
3. The camera may be focusing on something other than what you intended.
3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario.
If the lens is "hunting" for focus, that could be a sign that something is amiss.
A local camera shop can verify the accuracy of focus for your lens.
Mar 04, 2011 | Nikon D40x Digital Camera
It wont focus and the photo is blurred
If the camera is showing a black or distorted screen when set to photo, and photos that are taken with the black screen also show up black or distorted, then this would likely be a CCD imager failure, a common occurrence for your model camera.
If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status.Please check this linkfor more info.
May 31, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Focus problems with Nikon D700
use center fous mode dont keep multi focusing mode
Jun 17, 2009 | Nikon D700 Digital Camera
Blurred subject in middle of photo
I own Rebel XT and Canon 50mm f1.8 MKII lens with plastic mount and noticed many pictures with missed focus, either front or back focusing. Meaning objects slight forward or below the intended subject is in focus. I've sent my body and the lens to Canon for evaluation and thet adjusted my focus sensors on the body. I still have problems and there are many threads related to focusing on this camera with 50mm f1.8 that the sensors on this camera do not do so well with fast lens and prone to missed focus.
Test your camera's focusing ability with a book or magazine where you focus on just one specific line and see if it is truly in focus when you review the picture.
Feb 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Fuzzy/ not very sharp pictures
If the photos look pixellated, perhaps you've turned down the resolution/quality setting? Check the manual for how to correct this.
If your photos seem generally hazy, your lens could need cleaning. Use a lint free cloth such as one for cleaning spectacles.
If all your photos have a smooth, out of focus appearance, it could be a camera fault. However, if you've recently been taking photos in poor light without flash, it could also be "camera shake". You can distinguish this from out of focus because the blur is slightly directional rather than being smooth in all directions. Points of light become lines not blurry discs.
Jun 22, 2008 | Samsung Digimax A402 Digital Camera
Samsung digital s73 camera
Hi, there are many reasons why a camera may produce less then sharp pictures.
1) Dirty, oily or damaged lens: Check for dust and fingerprints.
Clean lenses with extreme caution, using dry lens paper.
Use only minimal pressure and gently wipe from the center
outwards, NEVER in circles.
If the lens is really dirty, ask a professional photo dealer to
clean it for you as a free courtesy.
2) Check to see if the auto-focus is working correctly, this could
be an electronic or mechanical problem requiring servicing.
Focus the camera on sharp image at various distances,
to see if it responds by moving the lens.
3) Can you focus the camera manually?
4) Can you focus by moving the camera back and forth
in regards to the object of interest?
5) Is the auto-focus feature somehow disabled in the menus ?
6) Are the batteries up to snuff, they may be strong enough to
turn on the camera, but too weak to move the focus motor.
7) Is the subject you are trying to focus on out of the
focus range of the lens: i.e. too close ?
8) Is the subject you are focusing on too bland, with insufficient
detail to activate and lock the auto-focus.
9) Do you have enough light for the auto-focus to operate.
10) Does the flash unit project an red pattern to help with
focusing.
11) Are you mistaking sharpness (focus) for depth of field.
In low light conditions, the lens iris opens wide, just
like your eye, to let more light in.
This results in a loss of focussed depth of field. This
means that focusing becomes much more sensitive
and critical, such that (when) the main subject is in focus,
everything behind and in front of the subject is not.
This is a theoretical limitation of all optical lenses:
The greater the focal length and the greater the aperture,
the shorter the depth of field.
This can actually be very beneficial when shooting a
portrait: Focus on the eyebrows, blur the background,
or it can be very detrimental: When trying to magnify
a butterfly on a tulip in low light conditions, getting
everything in focus is impossible.
12) Are you mistaking motion blur with lack of focus,
due to slow shutter speeds.
13) Are you shooting in very low light conditions,
causing the picture to become more noisy,
due to the way the digital camera sensor works.
14) I you come up empty on all these suggestions,
you probably have a defective camera and it is
warranty time:
a) Defective electronics
b) Defective auto-focus mechanism
c) Defective lens, loose internal elements
d) Detached sensor chip
.... etc
Try to isolate the problem. Try to manually and
automatically focus on a wide range of subjects,
at various distances, in bright daylight conditions.
If you are still unable to focus the camera,
it is probably defective and requires replacement
or servicing
BTW
Quick review of the internet, indicates that
this particular model is notorious for high battery drain
and battery connection problems. This may be the cause
of poor auto focus as indicated above.
Also this camera has insufficient internal memory, and
and an add-on memory card is required. It is possible
that without the memory card, the camera is defaulting
to a very low pixel resolution, in order to save memory
space, thus creating the appearance of poor focus.
The nominal resolution of the camera = 7.2 Mega Pixels
is respectable for such a low cost camera, but the
reliability reviews are not good.
Martin
Apr 24, 2008 | Samsung Digimax S730 Digital Camera
FOCUS PROBLEM
So... there's poor focus, and there's shutter speed.
If the light is very low, the shutter has to stay open for longer to allow enough light in to make a bright picture. Suffice to say, if you move around while the shutter is recording, it will record you moving around, and it will look blurred. That covers the concert you went to. Just use the flash. The camera will know it can use a very fast shutter speed if the flash is going to go off.
As for the person in the background thing... if they are the only blurry thing, then it's the same as above. If not, try this:
Check your camera setup menu... you should have focus options. Most toy cameras have an auto-focus that can focus on multiple points in the shot, or one point only, or even by face recognition these days! Try using a "spot focus", one focus point in the dead-centre of the shot.
On this setting, it shouldn't matter what is going on around your subject, the focus spot will be in the centre, where you are aiming it. =-]
Apr 22, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Blurred Corners
hi there, its a decousing problem, look for the connection of the decousing which is connected behined the pic tube to the board. check some electronic parts, it may be temperature resistor, termistor, transistors, capacitor, etc.ty
Dec 25, 2007 | LG Studioworks 775N 17" CRT Monitor
Blurred Images/ Photos
Check out the Fiji Tech support team. Depending on the age of the camera there may be a swap out option. Independent repair will not be an economic prop.
Jul 04, 2007 | Fuji FinePix F450 Digital Camera
Pentax Optio X Digital Camera Logo
49 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
