Hi, I bought a Whirlpool awm5145 about 1 1/2 years ago but it's never been great, the washing machine drum always has water in it, when i open the filter there is always soap and water. It doesn't seem to matter which programme i use, but all the programmes other than the daily 40 takes about 3 hours? The main problem now is that my washing looks clean but doesn't smell clean, even if i use top brand liquid/tabs, and top brand fab conditioner. My towels are also brick hard unless i tumble them, that makes me think there is still soap in the wash. Please help as i am pulling my hair out...
Hi Girociclo, We almost took the thing to pieces last night and no bends or blockages, however the drain hose does seem to go pretty high before it goes into the drain, tonights job will be to cut a lower hole in the side of the cupboard and lower the drainpipe. ThanksHi Girociclo, We almost took the thing to pieces last night and no bends or blockages, however the drain hose does seem to go pretty high before it goes into the drain, tonights job will be to cut a lower hole in the side of the cupboard and lower the drainpipe. Thanks
You can't post conmments that contain an email address.
The drain water pump its not working properly , needs to be cleaned the drain hose needs to be check for posible bent or clogged , ,please be sure that the drain hose ,and drain pipe are installed ,no more than 12 inches above .of the machine, and avoid long hoses. let me know
thanks
have you tried the super cleaner that works to clean just about everything--- vinegar
I dont know for sure if it affects several washers of that model but i have been a appliance tech for 30 years and haven't been to service that problem ever, the cabrio is what i have in my home and love it,cleans well without any foul smells
This will
potentially sound odd, but run the 90 degree cycle with 3 dishwasher tablets in
the drum. The smell is bacterial and probably the result of a build up of
residue from biological soap powder (Which is simply bacteria that eat your
stains). Dishwasher tablets are anti-bacterial and will kill the bugs making
the smell
you can open the filter drainage under near the drain hose. there may be something that comes into the washer drum and died leaving a smell. how to open the filter is rotated and pulled out only. then you try to drain the washing machine how to turn it. will allow water or sewage, which is in the drum filter out of the hole. and do not forget to clean the exhaust filter the water, there will be a lot of dirt.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Hope your filter is clean. Don’t wait for the
machine to jam to
look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and
other such
things can be stuck around the inside tub of your washer. Try this
product, it
works great on all front loaders. Use very hot water with the Affresh
pellet
with no clothes and run the machine through a cycle. Also helps with any
stagnant water smells. Put the Affresh
pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the
free help,
can't you. Thanks.
A solution from the internet:
Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell.
Another:
I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution.
MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts.
They are not very cheap but they work great --
I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain.
YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health!
I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com
Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon.
Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine.
While cruising around the net searching for some phone batteries, I came across an ad for a product called "Smelly Wash". I was intrigued by the name, and, since I have been trying to help out a friend who has issues with her front loader and water that is very high in iron and other fragrant minerals, I thought I'd take a look.
32 years ago I bought our first washer and the plumber who came to install it recommended SA8. He told me he had taken apart many machines and most were gummed up with the fillers that are in many detergents. Liquid detergents were not as prevalent at the time.
I friend of a friend helped me locate an Amway distributor and I bought SA8 from her for a few years until we moved. In our next home, I found another distributor and continued using the SA8.
Meanwhile, we added three more daughters to the family and I never once used anything but SA8.
Year's later, an older friend's husband (quite ill with emphysema and with severe contact dermatitis, countless allergies, etc.) called me to borrow some SA8 because that was all she could use for his clothing, sheets, towels...
With each move, we have left washing machines behind because sometimes they were "selling" points. My current machine is a 6 or 7 year old Whirlpool frontloader and I have never had "smelly" issues.
I care for my cloth-diaper using granddaughter and have absolutely no problems washing her diapers. I use one small scoop of SA8, and on occasion, a booster if the load is large. That's it. Nothing smells...EVER...even if I accidentally leave a washed load overnight. Every load smells CLEAN, but with NO scent.
I will go to my grave using SA8. I have to give my clothes away because they just don't get beat-up by the machine nor the detergent.
