Question about Xerox DocuColor 12 Printer
WASTE BASKET NEED CLEANING. AFTER CLEANING IT AND REPLACE IT THE MACHINE GIVES ME SYTEM FAULT 3-380
Waste basket? Do not know what you mean. 3-380 most likely dirty silver patch on IBT belt. Caused by bad drum{leaking}
Posted on Jan 29, 2009
Dcp 125 printer ink absorber troubleshooting
1.plug the power cord while holding the menu with in 16 seconds to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. press the mono start key several times until the purge count appears on the LCD.
4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. press the stop/exit key to return to the initial stage of the maintanance mode.
6. enter 9 twice by using the up arrow & set key's to exit from maintenance mode
just follow the steps and hope you can do it......
I try it to my self before i post it and shared to others....thnx and GOD BLESS by Harry Technician.
Apr 20, 2011 | Brother DCP 165C Compact Color Inkjet...
My Saeco Royal Cappucino gives hard noise, when "tamping". The grind goes to waste-basket. No coffee..
HI
There is a lever on the top of the door that has a + to the back and a - to the front. Pull the lever back 1 click to the front or - side. Your putting too much coffee in the brew unit and could break the brew drive.
Nov 30, 2009 | Saeco Royal Professional Espresso Machine
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
Dc 12 ERROR 14-372
14-372 is Machine Laser Code Your laser is ......
and second thing is reset the machine
amitgraphix@gmail.com
Feb 03, 2009 | Xerox DocuColor 12 Printer
System fault 3-380
Remove and reinstall the print cartridge. If the error is still there you should replace the print cartridge.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=21,E=0000000001181489224,K=5792,Sxi=0,Case=obj(18087)
Jan 17, 2009 | Xerox DocuColor 12 Printer
How do we empty the waste basket?
The "waste basket" is to indicate that the waste toner area in the drum cartridge is full. If the copy quality is still ok you may be able to empty the waste by removing the drum cartridge from the machine and removing the opaque piece from the left side and dumping it out. BE CAREFUL this can be very very messy. toner is a very fine powder and will get all over the place if caution is not used.
Jan 07, 2009 | Canon NP 7130 Black and White Copier
Waste Toner Light won't go off?
just clean out the transfer belt
Sep 20, 2008 | Office Equipment & Supplies
Ricoh ft 3213 printing problem
Is it only when you use the top feeder? Check by placing an original on the glass and copying if the same fault then there are three possibilities
  1. Optics Dirty (Dust on the copying mirrors) Remove glass and clean the mirrors on the scan unit also remove the lens cover and clean the mirrors under there replace lens cover clean glass and refit. (Do Not remove any mirrors you can clean them in there place and use a glass cleaning solution)
  2. Toner Waste and drum cleaning unit full. Open front cover and split machine as to remove jam not touching the drum (Large Cylinder ) check there is no banding on there. IF so to the left of drum there is a unit that contains the cleaning blade and fills with waste toner remove vacuum out waste toner check that cleaning blade ok and reinstall. Close and check machine if ok then great if not could be fault number 3 or that the cleaning blade is worn and need replacing.
  3. The fuser section (Heat section) While the machine is split look at the bottom left you will see a Orange unit this is the fuser section that houses the heat roller which welds the toner to the page. Check that the top roller is OK that there is no toner stuck on it and the Teflon coating is even. If not then the fuser will need replacing and as you said that you are missing text the most likely faults are going to be the fuser or the drum or the drum cleaning blade.
I hope this helps you
Thanks J
Jan 18, 2008 | Office Equipment & Supplies
Smudging
hi i am a certified Canon repair tech on this model. when the waste message comes up this means that the waste absorbers in the bottom of the machine need to be replaced. just clearing the error and not replacing them will cause the waste ink to over fill and backup into the machines printing area smugging the print. there are Canon repair centers privately owned that can replace the waste absorbers and clean the machine. the average cannot take this machine apart into peices to clean it. The waste absorbers are fairly cheap but the labor to do this will vary from shop to shop. hope this helps clarify the problem.
Jan 05, 2008 | Canon PIXMA iP2000 InkJet Printer
The waste toner is usually a bottle near the toner cartridge which collects excess toner powder from the cartridge. It is usually present in more heavy duty laser printers, not all printers have them as a replaceable supply. You would need to refer to your manual for replacement instructions, they vary from printer model. For this machine, the Waste Toner supply number is #420131. In the case of the first poster, my best guess would be there was spillage of toner on the sensors to detect the waste basket overflowing, hence why the error message is constant. This would require cleaning of the sensors, a relatively simple task but for proper access, the machine would need to be partially disassembles for thorough cleaning. It would be best done at a repair centre.
Aug 04, 2006 | Ricoh Aficio CL2000N Laser Printer
Xerox DocuColor 12 Printer Logo
131 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
