Question about IBM ThinkPad T30 2366 Notebook
T30 cant find os
HI,
My new larger hdd failed. so I put back the original 20GB hdd. It will not find the OS (XP). We got to a dos shell and ran FDISK. It shows C: as the fat32 partition and active. I set the NTFS partition as active. Rebooted. Still fails. Ran FDISK again, and FAT32 is still the active partition.
How do I get it to boot to XP?
  • 2 more comments
  • mrwalker499 Jan 17, 2009
    the hard drive has 2 partitions. one with Windows XP SP2, and the other is the IBM recovery partition
  • mrwalker499 Jan 18, 2009
    at startup the laptop runs memory checks etc. Then it tries to boot from the hard drive. This is where it fails with the message "Error loading operating system - press any key to reboot." The screen is black and white.
    It was working OK when we took it out. I am able to read the hard drive in another computer. It just won't boot to XP, Its a mystery.
  • DEKR
    DEKR May 11, 2010
    on the hdd what os system did you have on it
    Genius:
  • IBM Master
  • 1,102 Answers
When you start does it come to point where it shows xp and ibm
Posted on Jan 17, 2009
  • DEKR
    DEKR Jan 18, 2009
    Its saying no operating system is installed
    is the hd plugged in secure or do you have the jumpers in the wrong place
    you may need to do a format
SIR I HAVE AN OLD LAPTOP MPC COMPUTER.IT HAS NO CD DRIVE OR USB PORT.IT HAS ONLY FLOPPY DRIVE AND SERIEL PORT. MY PROBLEM IS HOW TO LOAD NEW SOFTWARE AVAILABLE IN CD HAVING 100MB CAPACITY.IS THERE ANY...
there is one possible way
1. remove hard drive from your laptop
2. plug your HDD into another laptop in anyway(usb or enclosure)
3. Make your HDD bootable with DOS mode
4. copy the new OS folder to your HDD
5. Put back your HDD to your old laptop then boot it with DOS
6. find the OS folder you copied, from there run setup your new OS.
Dec 03, 2017 | MPC Computers Computers & Internet
IBM Thinkpad T30 2366 Can I replace the standard HDD with a SSD drive. Are there any security features which might stop me doing this?
As you are aware the HDD interface on the T30 is IDE. I replaced my 20GB with a 320GB IDE with no problems. Many sites offer replacement HDDs with the added bonus of supplying Factory Restore CDs. If you could find a SSD in IDE configuration, it's a simple job to fit the drive and reinstall the OS. Make sure you have the latest BIOS. Good Luck.
Dec 09, 2010 | IBM ThinkPad T30 2366 Notebook
Installing Win XP to my new seagate HDD but cant complete kept on going to install process and cant boot unless boot to CD thats why it keeps on going back to installation process, what is the problem why...
Have you tried replacing the ribbon cable? Did you remove the jumpers off the back? if no to these to then Get a windows boot disk and Fdisk the drive and reformat then install the system. When you do the proceedure above say good by to any files they will be gone. You could have a boot virus that is causing your problem. hope this helps.
May 29, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Freezing up when installing winxp pro.
MAY BE THIS COULD HELP. PUT YOUR LAPTOP IN FRONT OF A FAN, THEN TRY TO FORMAT IT AGAIN, IT SOUND FUNNY BUT I FACE THIS CASE MORE THEN 3 TIMES, THE LAPTOP JUST TOO HOT DURING THE INSTALLATION (PUT THE FAN WITH LEFT SIDE FACING THE FAN)
JUST SHARING=)
Jan 25, 2009 | IBM ThinkPad T21 Notebook
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Removed partitions. Now 'My Computer' doesn't see HDD.
You may want to use a program called Partition Magic to repartition your hard drive. You can try using the Disk Management Service built in to Windows 2000, XP, and Vista. This is available in "Computer Management" in Administrative Tools in the Control Panel.
Please note that after removing a partition, you need to create a new one then format it before the operating system can read it.
Hope this helps!
Oct 17, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Dell laptop with no cdrom and travelstar HDD
In this case you would have to...
1) preformat the drive
2) make it bootable in DOS
3) copy the CD contents to the drive
4) boot the target computer with the drive and run WINNT.EXE in the I386 directory to start the install.
*OR*
2) copy the CD contents to the drive.
3) put the drive in the target computer and boot it from a DOS bootable floppy.
4) run WINNT.EXE in the I386 directory to start the install.
Jun 26, 2008 | IBM TravelStar 40GN 20 GB Hard Drive
T30 2366 not recovering from original recovery disk
The 2 gig partition is probably your recovery partition that allows you to restore your computer from the hard drive instead of the Operating System discs that came with the unit. You don't really want to mess with your partitions (you may accidently delete all your data). I'd recommend using Acronis True Image and backing your data to an external hard drive first, you can copy individual folders or the entire hard drive. Then you can just destructive restore your entire hard drive back to factory settings.
May 06, 2008 | IBM ThinkPad T30 2366 Notebook
PC does not see t30
SAME PROBLEM...going to return it tomorow..the problem is that it works only with US and EU win XP......it seem that i dont have windows for that market.. check your OS.......
Nov 07, 2007 | iRiver T30 MP3 Player
IBM ThinkPad T30 2366 Notebook Logo
94 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
