Question about Philips 50PF9630A 50 in. Plasma Television
I have a Philips plasma TV model #50PF9731D/37 with a weird ambi-light issue. When I first turn on the set, the ambi-light functions on both sides. But after I introduce a signal (cable and PS3 use HDMI ports...XBOX360 uses component video) the ambi-light turns off on the left side. The right side still works normally. The picture and sound work flawlessly.
  • 362 Answers
Hi cobrax50, Are you aware that your TV has been recalled because of the Ambu-Light. apperently they are haveing an issue with the light being a fire hazard. If you have already taken care of this, please disregard this solution. I have provided a link to the recall notice.
http://www.cpsc.gov/cpscpub/prerel/prhtml06/06536.html
Let me know how it goes and please rate this solution. Lone99star
Posted on Jan 17, 2009
  • 11,896 Answers
Unfortunately the 'green line' issue mentioned in the review appears to still be happening on screens that are shipping to end users. (It's been documented in detail on AVForums).
Hopefully this should be rectified by a firmware change (simply being able to adjust the picture vertically as well as horizontally would help).
The clearlcd technology is new for philips
VERY VERY COMMON IN PHILIPS!!! People all over the internet are noticing the same problem. Philips is still working on it. I will let you know as soon as they have a solution.
Phillips Plasma 50 inch - Model: 50PF9731D-37 - Does not turn on
It is at least worth looking at to make a decision.
Some general info:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
May 25, 2012 | Philips 50PF9731D/37 50 in. Plasma...
Want to buy stand for this tv
Well walmart has em,so does Bestbuy, try looking there.For starters.
Mar 07, 2011 | Philips 50PF9731D/37 50 in. Plasma...
Power come on then shuts off after seconds and blinks red lights four times
Open the back of the TV and check for blown, swollen capacitors. Usually 10v-3300ufd. There is one near where the 120v cable that powers the power supply, 350v-47ufd that might be bad too. The power supply sits in the center of the TV. Good luck!
Sep 21, 2010 | Philips 50PF9731D/37 50 in. Plasma...
Philips 50pf9731d RED BLINKING LITE ON STARTUP FLASHING IS 6 LONG AND 3 SHORT
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 27, 2010 | Philips 50PF9731D/37 50 in. Plasma...
There is sound but no picture when i turn the tv on
Many things could be wroung here, 1. bad HD driver board or bad thermal fuse ether the situation here its hard to narrow down over a email but you sure can start a chat with us to do diagnosis or pay the pipper to have it fixed your choice. If under warranty even better.
Please leave honest feedback and ratings.
Dec 11, 2009 | Philips 50PF9731D/37 50 in. Plasma...
I have a Philips plasma 42 with black lines across the screen
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
Aug 26, 2009 | Philips 42PF9630A 42 in. Plasma Television
System will not power up
Remove the back from the set and look at the power board in the center of the TV. It will probably have one of more capacitors with the tops bulging out. Replace them with the same value part. Available from radio shack and almost any electronic suppliers.
May 16, 2009 | Philips 50PF9731D/37 50 in. Plasma...
42 plasma phillips trouble code D3V3
Check the power board for caps with the tops bulged up. 3300uf 10v I think.
Jan 14, 2009 | Philips 50PF9731D/37 50 in. Plasma...
Open Questions:
See all Philips 50PF9630A 50 in. Plasma Television Questions
Philips 50PF9630A 50 in. Plasma Television Logo
395 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
