Question about AT&T Sony Ericsson W580i Cell Phone - White
My phone will not turn on.
I dropped it once, the battery fell out, and when I put it back in and tried to turn my cellular device back on, nothing happened. I waited a couple of days, and now when I hit the power button, it vibrates quickly and then a red light flashes quickly (the light is usually green). Please let me know any advice that you have.
  • Anonymous Feb 21, 2009
  • deeringv Apr 04, 2009
    My phone shut off, and will not turn back on. When I press the power button, I got a red flashing light, and then nothing.
    When I took out the battery and put it back it, the phone started to vibrate, but still would not turn on.
Well that has happent to mee to a couple ideas would be make sure the sim and battery are in right then let it charge for like an hour
Posted on Apr 05, 2009
My Nokia 7390 wont turn on!!!
the drop might lossened the lcd or damaged ur phone and this is a hardware problem i recommend u to take it to ur product care center
Apr 04, 2010 | Nokia 7390 Cellular Phone
My center button does not work when pressed. How
Try putting the phone in a bag of rice for 24 hours. It's a popular fix for water-damaged electronics. If that doesn't work turn the phone off and take the battery out. Then use a Q-tip to drip a few drops of alcohol on the button, and put your mouth right on the button and blow into it. I did that once with an iPod.
Feb 24, 2010 | Samsung SCH-U470 Juke Cellular Phone
My nokia 6681 fell in the water and is not turning on.all my contact details are stored in it.i cannot retrieve them as the phone is not turning on.please help immediately
dry the phone out and keep it off for a day or two. Your phone is interanlly wet and trying to tamper with it while wet will only fry your phone. Once it is dried inside and out put your battery back on and turn it on :o)
Oct 20, 2009 | Nokia 6681 Cellular Phone
I have a samsung SCH-U520 and I dropped it in water
If your device gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
Sep 16, 2009 | Samsung SGH-t219 Cellular Phone
T-Mobile Shadow Water Damage
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Mar 08, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Sidekick 2008 got wet
I dropped a phone in the toilet once, a T-mobile phone. it took a couple of days for it to dry out completely. Then I snapped it back together, and it was fine. Being that yours just got wet, and not immersed is different though, so you may want to take it into T-mobile and see if they can check it out for you because then you will know for sure what is going on. Good luck.
Jan 12, 2009 | T-Mobile Sidekick® 3 Cellular Phone
N70 Fell in water, Only White Screen is Shown
Don't put the battery / power on. Take the phone to the mechanic / nokia service center on urgent basis. They will remove the remnents of the water and salt over the circuit.
If the problem is still not solved, either the power supply or the motherbaord will require a replacement.
Dec 16, 2008 | Nokia N70 Cellular Phone
My fone fell into water
the same happened to me tooooo, it fell into the sink, and now only has light on the screen and nothing else, and goes off it self in a few moments, i tried USB'ing all data to PC, but PC is failling to recognise the device! even with PC suite!!!!
What shall i do?
Nov 04, 2007 | Sony Ericsson K800i Cellular Phone
Broken screens
Yes, I've seen this happen twice, similarly. When enough shock has been applied to a phone, such as your case, the screen is very susceptable to damage and will need to be repaired or replaced. There's nothing you can do with expertise or spare parts unfortunately, you may even want to look at a new phone if the warranty is out on the phone. Sorry to be the bearer of bad news.
Sep 07, 2007 | Sanyo Katana SCP-6600 Cellular Phone
AT&T Sony Ericsson W580i Cell Phone - White Logo
127 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
