Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Does the adapter work?
When I plug the adapter into the outlet, the green light at the end of it that goes into the printer turns on, then when I actually plug it into the printer, the green light goes off, and the printer never turns on. Is the problem the adapter, or the printer? Its a brand new Kodak 5300. Never been used.
My connector ba to
Posted on Jan 17, 2009
I have an HP power adapter 0957-2269 for an HP Deskjet D1660 printer which has stopped powering the printer. when the adapter is plugged into the mains, a green light comes on but when the adapter is
Check eBay for replacement parts. Voltage, power capacity and the connector can all vary but you can probably find a replacement part. If not, the things are so cheap these days.
I knew a consultant who did training. In every city he would buy a new inkjet at the start of his courses. At the end of his courses he would leave the printer in the room as a tip for the hotel staff.
Aug 08, 2012 | HEWLETT-PACKARD Hewlett Packard Hp...
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
My printer will not turn on.
try to insert the cartage properly
Feb 23, 2012 | Kodak Office Equipment & Supplies
I have a HP Deskjet D1560, and with the power cord plugged into a working outlet (I checked), the printer won't turn on. Is it just old? Is something wrong with the power cord or the printer?
There is only one way to find out if it is an issue with the printer or the Power cord.
Normally every HP printer has 2 parts. One cord connects the Printer to an Adapter. the Adapter cord then connects to the Wall outlet.
Now that you have connected the printer to working outlet, Check after 10-15 mins if the Adapter ( black box ) is warm or cold. If the Adapter is warm and the green LED light on adapter is glowing, then it could an issue with the Cord or the Printer.
Try with another Adapter or power cord to diagnose.
Regards,
Shawn
May 07, 2011 | HP D1560 Deskjet Printer InkJet
Printer is dead
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave the other end of the power cord attached to the power outlet. Bypass any surge device or power strip, plug the power cord straight to the power outlet in the wall. Properly secure the power cord in the power adapter. There should be green LED light on on the power adapter. Plug the power adapter back in the printer. Make sure it's plugged in securely and in the correct position. If it won't power on automatically, press the power button. If that doesn't help, it may be a hardware problem. If that's the case, I suggest you contact Lexmark Technical Support to further investigate the problem.
Jul 15, 2010 | Lexmark X2600 InkJet Printer
Lexmark 2600 wil not turn on, no lights, nothing absolutely zippo. Definately has power from the mains switch so could be either the transformer into the printer or within the printer itself. have tried...
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave power cord attached to the power adapter and the other end of the power cord plugged in straight to a known working wall power outlet, bypass any surge device or power strips. There should be green LED light on around the power adapter's silver contacts. If none, make sure the power cord is properly secured. If that doesn't help, that's the main problem. If LED light is on, plug it back in the printer in the right position and properly secure it in. If printer won't automatically power on, press the power button. If that won't help at all, the printer itself is the problem. I hope I can assist you more on this.
Jun 28, 2010 | Lexmark X2600 InkJet Printer
Hp deskjet 6540 power adapter turns on but printer doesn't
This printer have a problem on HP circuit board. Usually its grounded due to ink waste, or not using it like what you said it took about three months. Here is a tip if your printer HP is still under warranty then you can send or contact to HP Center or the one you buy from it. To be sure that your printer is working back normally.
Sep 13, 2009 | HP DeskJet 6540 InkJet Printer
On the issue with th ebattery on the 1521 inspiron. Took battery out and plugged in still will not power up. Could it be the adapter as well?
On the ac adaptor, look for a green light that will turn on when you plug it into the wall outlet, if its on that means the ac adapter working. If you get a green light on the ac adapter but then the green light goes away when you plug it into the laptop then that means the laptop has a bad motherboard.
If you plug the ac adapter into a wall outlet and get no green light then that means the ac adapter is bad and you would need to get another one.
Jun 21, 2009 | Dell Inspiron E1705 Notebook
HP ac/dc adapter 0950-4340
Hi , plug first the adapter to printer before plug it to ac outlet.
Feb 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Power issue with LCD Monitor
Try another power adaptor. Check the delivered voltage and go get a universal power adaptor that has a switched for varios voltages and a number of connectors. Simply match connector to the voltage switch.
May 21, 2007 | Princeton Digital LCD17 17" Flat Panel LCD...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
61 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
