Question about RCA DRC8030N
Finalized disk won't play in other players
I have a RCA DRC8030N and the last few disks I have burned and finalized are not recognized in my other players. Was working fine. Using the same Verbatim DVD+R's as before.
  • 537 Answers
You might check your burner to see if it is working correctly. If you are using the same media and it worked before, perhaps the burner or the burning software is not working correctly.
Posted on Jan 17, 2009
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
I have a sony CFD-S01 which will play commercial cd's but when a cd-r is inserted it either won't recognize the disk or it jumps constantly after appros 10 sec, any ideas?
The CFD-S01 is designed for use with CD-R and CD-RW discs. With that in mind a few things come to mind. Are the CD-R discs you are using music or data discs? There is a difference and some CD players do not get along with data discs and won't play them well if at all. Also the burn rate used can have an effect - too fast and it won't play well. If a disc doesn't play at all it might not be finalized. A disc must be finalized on the recorder it was burned on before it is playable on any other machine.
Nov 27, 2010 | Sony Boom Box With CD Player & Cassette...
I have downloaded the software, can burn a DVD,
Some DVD players require the disk to be finalized before they can be played, and older DVD playes may require that you used -R DVD disks.
If you are already using an -R disk, check to see if the movie has been finalized. (If you are not sure how to do this, check the help file). If you are not using an -R disk, try using one.
Good Luck
Apr 27, 2010 | Canon FS30.5U for MV Series
I burn dvd -r and dvd+r and it will not play on it
It is possible that the disks are not finalized. You may need to configure it to auto finalize, which is off by default. It would be impossible to have more than one title on a disk if you always auto finalized. Check your manual, and finalize your disks. Many times marginal disks will play OK in the unit they were recorded on, but not so well in other players. The media (disks) could be the problem as well. On a side note, the DR410 will NOT burn DL (dual layer) disks. I hope this helps and good luck.
Oct 28, 2009 | Toshiba DR410 DVD Recorder
I burned & finalized a DVD+RW with family
while u were burnin the disc which format of disc u selected.......if u selected data disc then some of the dvd players will not read those dvds..............u should not select data disc .................instead there r some options to burn the disc....it depends on which version of nero or the cd burner product u use
Oct 14, 2009 | Sylvania Televison & Video
I have windows vista the dvd-rw that i burn does not play on dvd players
Not all DVD players will play rewritable DVD disks. Check for compatibility. Also, burned DVD's need to be "finalized" and the region code of the burner must match the player. Check your software docs for steps to finalize and setting your region code. If you are in the U.S. your region code is 1.
May 31, 2009 | Gateway Computers & Internet
Player does not read dvd disc
You already clean the laser lens.
Jul 01, 2008 | Polaroid Televison & Video
Made a dvd copy from vhs. will not play on my rca dvd player.???
some videos are encrypted and will not play,also check that the disk as been finalized as it will not play,ie must not be a multi session disk as this will only play on a pc ,,,,andy,
hope this helps
Jun 22, 2008 | JVC Televison & Video
Can't read disk
Check the Player Manual what types of disck it can play
There is great diversity o among player makes with what they can do.
Also if you have burned this disk it must be Finalized in the burner before any other device can play it.
Jan 24, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
RCA DRC8030N Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
