Question about GE DCSR483EA Electric Dryer
Timer / heater malfunction
When i go to run the dryer it is not heating and all the timed dries besides the "No heat air fluff" are not working properly
It is a GE
Model # NV1333EY0AA
  • GE Master
  • 8,220 Answers
NVL333EY0AA is more likely the model number.
The heating element is probably shot. You will have to remove the front and drum to get to it. You need not buy the whole pan, there is a restring kit available in aftermarkets.
Posted on Jan 17, 2009
  • 66 Answers
The heater coils or going bad. It has two wire rings that heat up. One are two has burned out.
  • David McCreery
    David McCreery Jan 17, 2009
    Unless the timer dial not moving. That model bad about the heater coils going bad .I have seen them go out around a year .Hope this helps.
Dryer heats-up on air fluff setting
This sounds like a grounded heater wire. If you turn the timer on and open your door, is the heater element on and making heat? This should not be the case if the drum is not turning. If heat is on then you will need to replace the heating element. Good Luck!
Oct 11, 2014 | Dryers
I put a small load of washing in the dryer and it doesn't dry and takes 2 or 3 drying cycles.
A restricted vent is the most common cause for long dry times. You can run a load of clothes with the vent hose disconnected from the back of the dryer. If you don't get any heat dring a cylce, and you verified an "air fluff" cycle has not been selected, I suggest having a professional service tech give you a diagnosis. The problem could be in one of a few thermostats, the heating element, main control (timer or control board), sensor, motor switch or even supply voltage.
Nov 04, 2009 | LG Dryers
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Whirlpool dryer LE6810XS110 timer only works on air fluff and tumble press does not work on regular or perm. press
Check to see if the unit will heat up in the time dry. if the heater does not come on in the time dry cycle, then you will need to change the thermol fuse on the back of hte dryer.
Oct 10, 2009 | Whirlpool LER4634J Electric Dryer
My dryer doesn't dry
The timer is responsible for initiating the actions of the entire drying cycle. if it is not moving, this will confirm timer failure. replacing this failed timer control module will fix this issue.
To clarify, its the timer that is malfunctioning. the heating assembly is fine.
Jun 17, 2009 | Maytag Dryers
Maytag Dryer has lost heat...
I would think the timer is not used but a humidifier when on auto dry mode. Check the humidistat, should be either make or break contacts, open or closed.
Nov 11, 2017 | Maytag Dryers
GE DCSR483EA Electric Dryer Logo
79 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
