Question about Jabra BT350 Wireless Headset
Need passkey to reconnect bluetooth
I somehow disconnected the bluetooth from my phone and it was a gift, and I need a passkey or pin to reconnect to the phone and bluetooth. is there any way I can reconnect?
  • 3 more comments
  • Anonymous Nov 20, 2007
    0000 worked for me and my iphone! Thanks
  • Anonymous Apr 03, 2008
    I had to hard boot my phone and when trying to reconnect I don't remember the passkey. It was 111111 or something like that. Why would I need a passkey anyway??????
    0000 didn't work. 1234 didn't work. 111111 didn't work. Any other thoughts?
  • Anonymous Jul 04, 2008
    logitech
  • Anonymous Jan 27, 2009
    0000, 1234, 9999, & others didn't work! Any Solutions out there?
Use this link to get installation instructions! http://web.jabra.com/JabraCMS/NA/EN/Misc/GettingStartedBT350
Posted on Jun 22, 2007
Try 1234 or 0000 cheers
Posted on Jun 20, 2007
SOURCE:
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Trying to connect my plantronics bluetooth to my samsung cell phone. I can find my instructions manual to put in the passkey. I tried four zeros, but it did not connect. You you help me, please?
First you want to make sure there is no other bluetooth interference. To reset the phone, turn off your phone, then disconnect and reconnect the battery, this should reset the phone. Then carefully follow the pairing instructions in the Explorer 360 User's Guide, pages 3-5
Good luck from Headsets Direct!
Apr 20, 2011 | Plantronics Explorer 360 Bluetooth Headset...
My friend gave me his bluetooth but i need the pin to connect it to my phone and i cant get it .how can I pair it to my phone without using a pin or making a new pin?
The pin or the passkey is "0000". To pair the SGH-T749 (Highlight) handset with a Bluetooth Device follow the steps below:
  1. Place the Bluetooth device in discoverable mode
  2. From the standby screen, press on Menu
  3. Press on Settings
  4. Press on Bluetooth
  5. Search for the Bluetooth device by pressing on Search, located at the bottom
  6. Press on Yes to Activate Bluetooth and start the search
  7. Press on the desired Bluetooth Device (if not shown press on the left or right arrows until displayed)
  8. If prompted, press the Passkey "0000" then press on OK
  9. You will get a brief message stating connecting followed by connected, if prompted press OK again
Note: The first time you try to pair with another handset, you and the owner of the other handset must enter the same PIN. Once the handsets have been paired, you will not need to use the PIN again.
Mar 30, 2011 | Samsung OEM Travel Wall Charger for...
Default bluetooth passkey?
Usually the default bluetooth key is 0000. If that doesn't work, do a master reset on your phone and re-enter the pin.
Mar 06, 2011 | Motorola Mobility RAZR V3i Cellular Phone
My husband disconnected his bluetooth headset from his phone so he could try it on mine, but he cant remember the password to reconnect it to his cellphone.
It is, most probably, '0000' (four zeros). Although far less frequent, other hardcoded passkeys chosen by manufacturers are '1234' and '8888'. Hope one of them works for you.
Please, let me know if you need further informations.
Regards, Carlos
Aug 12, 2010 | Plantronics Explorer 390 Bluetooth Headset
How to register a bluetooth cell phone with a 24127fe2 base?
Bring your mobile phone, with its bluetooth radio turned on, between 2 and 10 feet away from the 28127 base. Press and hold 'CELL 1' (if it is the first phone you are paring) or 'CELL 2' (for the second one) on the 28127 base, until the corresponding LED flashes. The base is now in pairing mode. Now, make your phone's bluetooth application search for new devices. After a while, the 28127 should appear on screen. Select it and make the application proceed. If a passkey (or PIN or pairing code) is requested, enter '0000' (four zeros). The paring process is successful when the LED gets lit, indicating that it is connected to your phone. To disconnect, press and hold 'CELL 1' (or 'CELL 2), until the LED is turned off. To reconnect it to your phone, briefly press 'CELL 1' (or 'CELL 2').
By the way, just in case you happen to be miss your cordless phone's user manual, feel free to download it from this location.
Hope you are able to sort your problems out.
Cheers! Carlos
May 17, 2010 | General Electric 28127FE2 - Cordless Phone
I lost my user manual and don't know the numerica passkey to connect this to my new phone.
To turn on Bluetooth and connect a Bluetooth hands-free headset or car kit:
  1. On the Home screen, press the Menu key.
  2. Touch Settings
  3. Touch Wireless & networks
  4. Touch Bluetooth to turn it On
  5. Touch Bluetooth settings
  6. Touch Scan for devices (make sure your headset is in pairing mode).
  7. Your phone scans for available Bluetooth devices
  8. Touch the Bluetooth device to select it
  9. Type the PIN if needed (PIN is usually 0000, or 1234)
  10. Touch the device name again to connect to it.
May 17, 2010 | Motorola Mobility H350 Wireless Headset
Need help pairing
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Feb 28, 2010 | Plantronics Explorer 330 Headset
Bluetooth pairing
that motorola is in the series of bluetooths that all have 0000 for pin numbers and they are NOT changeable.
turn bluetooth off push the button with the phone on it until lited LED turns Purple immediately release and open mic, now it is ready to pair.
then go to the phone tool>bluetooth> search for device enter pin 0000
it will then verify and Voila you are set
Nov 25, 2008 | Motorola Mobility HS850 Consumer Headset
How/where to get a pin for my bluetooth on my samsung SGHE250 mobile phone
Hi-
You mean the passkeys? Basically pins or passkey can be set, but if you mean that you need a pin to connect the default pins is either 0000 (4 zero's) or 1234
Keep me posted. Thanks!
Aug 05, 2008 | Samsung Cell Phones
Jabra BT350 Wireless Headset Logo
4,127 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
