Question about Amana ARB8057CSL Bottom Freezer Refrigerator
I have a Amana TC20e the refer stays to cold 29-30 degrees the freezer is about 10 degrees I've adjusted the temp down in the freezer but the refer still stays to cold
  • 51 Answers
UNPLUG THE FRIDGE FOR 5-8 HOURS LET COILS UNFROST/CHECK TO SEE IF YOUR FAN IS RUNNING.
Posted on Jan 17, 2009
How cold should the freezer get?
I am assuming you are referring to Fahrenheit.. 16 is a little warm for a freezer. They usually stay around zero to 10 degrees above or below.
Sep 14, 2014 | Samsung Refrigerators
The fridge is at 64 degrees and the freezer is working well. Coils are clean.
In most fridges, the cooling coils are in the freezer section. The other section is cooled by air flowing from the freezer section.There should be a valve/vent/knob that allows more or less air to flow from the freezer. Adjust this to maximum cold to see it the temp changes. Or is 64 degrees too cold for you?
May 06, 2012 | Amana ABB1927DE Bottom Freezer...
I have an Amana Refrigerator Model ARS2666AW. The refrigerator temp is running at 38 to 40 degrees, but the freezer will only go down to 26 to 27 degrees.
your ref possible short cycling operation check your condenser fan of woking . check the refrigerant charge if ok if not need for recharging try to adjust the setting of thermostat. check filter drier maybe clog up if drier cold when u touch this means clog up if warm means ok if condenser not hot it means possible leak of refrigerant.
Feb 19, 2011 | Refrigerators
My freezer works but my refrigerator wont stay cold...getting warm. it is 4 years old. what could be wrong?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 26, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Freezer does not get as cold as the setting made but refrigerator
If the unit is working correctly, it could be that you are trying to adjust the freezer with the wrong knob. The fresh food section is cooled by forced air from the freezer and can get about as cold as the freezer if not adjusted correctly. The thermostat its self controls only the temp in the freezer. Some times telling which is which is confusing. Here is the best way to tell the difference.
The knob that will turn the unit off is the thermostat. The other one controls how much air can be forced into the fresh food section. The thermostat should be adjusted to where the freezer stays around -10 degrees. The other knob should be set so the the fresh food section stays between 35 and 38 degrees. If this does not help or if you find that there is indeed a problem with you unit, please get back with me and I'll be glade to walk you through diagnosing the problem.
Please post a rating if solution is helpful. Thanks
Aug 21, 2009 | GE Profile Arctica Stainless Steel Top...
Refrigerator is warm @ 60 degrees and the freezer is still freezing happens every so oftern
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
Amana ARB8057CSL Bottom Freezer Refrigerator Logo
112 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
