I have no audio (picture present) on ONLY channels 04, 05 and 10 when using the VCR side of my GoVideo DVD/VCR record/player. When I use the TV/VCR button to switch to TV I get my sound back. All other channels work properly. I have Comcast cable.
  • 3 more comments
  • mrnatural666 Jan 17, 2009
    It was suggested that I check video input. I did that before asking my question. Since I get sound back by simply selecting the TV/VCR button on the remote which enacts pass through of the GoVideo unit to the TV using the same cable video input it seems very unlikely it is an external connection issue.
    It has been suggested that I may need a DVD decoder. I don't understand why that suggestion. My problem is with translation of sound only from the Comcast signal coming in over wire, not DVD. The DVD side of my GoVideo functions perfectly. I just don't get audio ONLY on channels 04, 05 and 10. I had audio on those channels until about 10 days ago for three years. Again, I do have picture AND audio on all other channnels that I receive from Comcast.
  • mrnatural666 Jan 21, 2009
    The last response I received made a lot of sense but didn't solve the problem. The three points made were AGC, Inline amp and compatibility with the incoming signal. I was able to check the last two. The inline amp has a gain adjustment and I changed it from full to the lowest setting. There was no change. The setting for incoming signal is correct. I tried changing it to other choices than 'Cable' and they were wrong for sure. Since the unit has been operating properly with all the settings it had for at least three years until about two weeks ago I believe there is no problem any setting I can control. I didn't change any setting in the last two weeks either. I'm now convinced that the only solution is a trip to the repair facility. I also found one more channel that has no sound. It is 33. As I change channels a bar across the top of the TV tells me what kind of sound is being received. I find it interesting that those that don't have sound are either SAP or Stereo yet the same types of audio come in fine on the remaining many channels. Two other DVD/VCR units in my home receive the sound on the channels that this one doesn't. One final point. I'm embarrassed to admit that I listed the wrong brand. It is not my GoVideo unit. It is a Toshiba D-VKR3SU.
    The last suggestion was that it was my Comcast unit. That is wrong because I don't have a decoder box because I don't need one since I don't pay for nor want premium channels. The wire comes to my house and is fed through an amp with multiple connections on the back to most rooms of the house. Everything works fine in all the other rooms, including two other VCR/DVD units.
  • mrnatural666 Jan 23, 2009
    I was hoping to get an answer that I could use to fix it myself but your answer is the only one that really seems to apply to my problem.
  • 744 Answers
Hi sine u said there might be some problem with ur connections u can better contact a tv repair person who could handle dis problem efficiently.
Posted on Jan 21, 2009
    Genius:
  • 2,035 Answers
Try to swap the channels playing audio to the channels which do not have the audio in them ,if its plays audio then its problem with signal, if does not play the audio in those channels then there is internal tv issue with channels audio ....You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
    Scholar:
  • 58 Answers
You got the right idea. Take it to repair.
    Scholar:
  • 160 Answers
It sounds the signalling issue with your device and i dont feel that its anything with wrong internal connections.connections will be fine just the problem in the device which acts the mediator  between tv and cable receiver it indicates tuner is faulty
    President:
  • 1,990 Answers
Welcome to Fixya! This ia A Problem with the Unit that ComCast has sent you. Get ComCast to send you a Replacement and it will work. Not the First time I have heard this Same Problem Here.
Posted on Jan 17, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, it would appear to be a tuner problem of the GoVideo DVD/VCR record/player. Doubt if it were a problem with your cable provider (Comcast) otherwise, the TV would be suffering with the same problem.
If it were a tuner problem on the DVD/VCR record/player, then it should be common and present on all channels and not channels 04, 05 and 10. Based on these, possibilities are:
  • agc - (automatic gain control) of the VCR is clamping on the above channels. Simply stated, too strong signals. See if you can install inline bandpass filter;
  • in line amplifier/splitter - if your house cable/wiring uses an amplified distribution type of splitter, might require gain adjustment or switching to a passive splitter;
  • compatibility - check whether the DVD/VCR record/player is set to Cable and if the selection STD, HRC, IRC matches what Comcast is using in your area.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 21, 2009
    Appreciate the comment/postback and the additional information.
    Based on your feedback, I now inclined to think that it is not the tuner but the sound processor of the Toshiba D-VKR3SU. The tuner would not discriminate they type of audio signal received as it is embedded into the incoming RF signal (FM). It would be the function of the sound processor to auto adjust whether it is sap, stereo or mono hence failure to correctly identify the incoming sound would lead to the processor muting the audio.
    And if this would be a board replacement, then the services of an authorized SC (Service Center) would be your best bet.
    Should however the cost of repair and the downtime be factored in, perhaps you may want to reconsider your options and look for a suitable replacement.
  • Louie  Role
    just a thought and call it a hail mary pass if you will.
    it would be relatively easy to try this; bypass or remove the inline amplifier since as you posted no significant channge from max to min gain adjustment. all that would be needed is a double female FP-5 connector or a passive splitter.
  • 818 Answers
You may need a dvd decoder
    Brigadier General:
  • 3,614 Answers
Check the c0nnecti0ns at the vide0 input, c0uld be a pr0blem 0n wire
Can't get video on vhs sound but no picture, is it broken
I had the same problem, so I took it back to basics. Hooked cable into VCR/DVD player and another cable from player to TV. S cable too, plus red/white audio. Plays DVDs on AV1 and VHS on Channel 3 on TV setting.
Jun 30, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
CAN'T RECORD TO VCR FROM TV
depending on the tv, use scart 2 as the connection as this usually sends the signal out as well as in, but set the recording channel as the av or scart input.
Mar 29, 2010 | GoVideo DV1130 DVD Player/VCR
It says "play" and my tv is on Ch.3 but there is nothing playing. I tried turning my direct tv off but it made no difference.
do you want to record programs on your vcr? connect the out to tv cable from your dir/tv box to antenna or cable in on the vcr, then connect the cable from out to tv on the vcr to antenna or cable in on the tv, you'll have to select channel 3 on the tv to get the vcr to show a picture and you will need to select channel 3 on your vcr to record the channel selected on your dir/tv box. confusing?thanks and good luck.
Jan 02, 2010 | GoVideo Go Video DVD/VCR Combo
Can not record channel 160? GoVideo only goes up to channel 125??
all machines go only to channel 125 maybe you have channel 160 on cable box or sky just set vcr to channel 3 or 4 and channel 160 will come thru vcr to your tv
Dec 16, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
I cannot get my DVR4300 to go in to TV channel change mode while recording a program
Why not simply record a channel tuned into the vcr and use your tv remote to watch a channel tuned into your tv? that is how it is normaly done... don't forget a vcr/pvr/dvd recorder has it's own channels just like a tv does... just no screen of it's own the tv has of course it's own channels and in fact does not even need to be switched on in order for your recorder to record a program neither does the recorder need to be on to use your tv
Oct 14, 2008 | GoVideo DVR4300 DVD Player/VCR
Digital converter box
You need to select channel 3 or 4 on your VCR! , or line-in if you connected through the (yellow/ white/ red) cable "better video quiality!" and selct the channel you want to record on your DTV box, not the VCR!
Sep 13, 2008 | GoVideo DV2150 DVD Player/VCR
Go video VR3845
Try unpluging the unit and the plug it back in
Apr 19, 2008 | GoVideo VR3845 DVD Recorder/VCR
No picture
might have to use it thought your vcr cable and tune it thought your tv
Jan 14, 2008 | GoVideo VR3845 DVD Recorder/VCR
Timer recording on GoVideo VR2940
First, you need to have the cable directly input into the recorder.
If you only plug the cable box into the machine, you get what is happening now.
After splitting the cable, one side into te box and the other into the recorder, run the channel seek part of the program and it will scan all the channels available on the cable and place them in memory.
Then plug the output of the cable box into the other input on the recorder, and you get yor pay channels and upper tiers.
Your recorder is now a switching unit as well
Woody Woodcasters@hotmail.com
Nov 19, 2007 | GoVideo VR2940 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
