Question about Quantum PX502 (PRA22AAYF) Ultrium Tape Drive
Quantum Error Hi, I'm getting the below error while trying to open tape magzine in Quantum PX 502 Problem type 4A: Doors locked via SCSI how to solve this? waiting for your reply Thanks in adv Vinodh
The host backup application probably still has ownership of the library. You normally need to select to 'open door' or something similar to release ownership back to the library
Posted on Aug 09, 2007
    New Friend:
You need to "unlock" the door.
In Backup Exec, go to the Devices tab.
Expand Robotic Libraries and locate the library.
Right click on the library, then select Unlock and wait for the job to complete.
You can read teh full details on how to do this here:
http://www.confighelper.com/2009/06/quantum-px502-doors-locked-via-scsi.html
Posted on Dec 16, 2009
SOURCE:
Quantum superloader 3 drive error type
Hi Ulrike
I suspect that your backup software has "locked" the drive / library from the front panel.
This is why disconnecting / rebooting the library solves the issue.
If you are using backup exec or similar, try going to devices, selecting the library, right click and "unlock" before using the front panel buttons.
You could also use BUEX to do the tape moves for you instead of even touching the front panel.
If you are in the UK and are still having problems then click the link below and we will do what we can to help.
LTO Repair service UK Based All manufacturers of LTO drives repaired
Mar 10, 2014 | Computers & Internet
HP StorageWorks 1/8 Tape Autoloader SDLT 320 - tape library - Super DLT - SCSI Displayed Error! Code: A0 When you try to import or export are displayed error code 90
The library picker arm cannot move to the home position. There could be something blocking it. Try the Reset option from the Configuration menu. This is detailed in the library user guide.
Jan 11, 2011 | Quantum ValueLoader SDLT 320 Super DLT...
Cartridge error: 50C and Hardward Error: 502
The "clear tape" that you are playing with is called the "encoder strip." A barcode is etched on it that tells the printer carriage where it is. If you clean this carefully (google encoder strip for best methods) you may be able to get rid of 502 error for a while.
Not sure about 50c.
Jan 23, 2009 | Dell A960 All-In-One InkJet Printer
SCSI Inquiry Command Failure w/Tandberg TDC 4120 tape drive
Try putting the tape drive on the last scsi termination point.
Jan 01, 2009 | Adaptec Cables & Converters...
Quantum superloader not showing in windows device manager
First off, I have to say that I have had nightmares with Quantum tape libraries. It is possible that they are still manufacturing lemons. I had one replaced 4-times and it still did not work!
Start troubleshooting by making sure that it is identified by the controller card it is connected to. You should see this during the server POST before Windows starts. If you don't see it there then Windows definitely won't see it. Send it to Quantum for service.
If the controller sees it then make sure that you are using the Backup Exec drivers. Never use the manufacturer's drivers with Backup Exec. Veritas, now Symantec, has a downloadable utility called the Device Driver Installation Wizard that will make sure you have the correct driver loaded.
I hope this helps.
Nov 13, 2008 | Quantum SuperLoader 3 LTO 2 Tape Drive
Scsi tape drive not recognized on the library
Please check your firmware on the tape drive. Update with X-Talk software that can be downloaded from www.quantum.com.
Apr 28, 2008 | Computers & Internet
Error on ATL M2500
most likely this is a drive issue or picker problem. did u try to power cycle the library?
Nov 19, 2007 | Quantum ATL M2500 Tape Drive
Media is not inserted: tape backup
it's HPE day, why post to fixya for HPE , enterprise level products?
no pc stated
no sever stated.
no exact products stated,just symanted? what is that? ah Symantec tape backup software.version?
hp lto1 with scsi adapter
what model LT01. what model scsi adapter make and model.
hp makes vast versions of that drive
like (wild guess)
HP Q1515A
C7401-60024
StorageWorks Ultrium 230 LTO 1 Tape Drive
SCSI LV/DS
Q1516A
try a new tape yet, be wise, no?
never own only 1 tape, and always have 1 spare new on shelf
of the tape runs via the scsi port, ok , all but the error works.
then it is not the scsi card .
tape first.
then get the drive rebuilt.
keep a spare drive on hand after all, is not backup a key function in any data center./? or small business, be ready?
Jan 10, 2018 | HP Computers & Internet
Adic faststor2
Try changing the autoloader SCSI ID and the tape drive SCSI ID at the front panel:
Use this option to view or change the SCSI IDs used by the autoloader. The autoloader occupies two SCSI
IDs, one ID is assigned to the autoloader and the second ID is assigned to the tape drive.
The default SCSI ID for the autoloader's SCSI controller is 0. The default SCSI ID for the tape drive is 5.
You only need to change a SCSI ID if there is another device, or devices, already assigned to these IDs.
NOTE: This option is primarily used if the autoloader is in an error state. However, any
backups that have not been verified as complete should be considered lost.
NOTE: If you changed the SCSI ID, you may also need to cycle power on the host
system and reconfigure your backup software before you can use the
autoloader. Consult your hardware and software manuals for more information.
Dec 27, 2006 | ADIC FastStor2 LTO (90024202)
Quantum PX502 (PRA22AAYF) Ultrium Tape Drive Logo
1,307 people viewed this question
Top Quantum Computers & Internet Experts
SirEbrum
Shawn DuRee
Ekse
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
