Question about Maytag Neptune MAH5500B Front Load Washer
Speed indication error
On Maytag Neptune Model No. MAH7500 "speed indication error" - what does not mean?
  • gouveiaf Jan 17, 2009
    We tried that but it did not work.
  • 51 Answers
IT WAS NOT TURNING FAST ENOUGH.UNPLUG FOR 5-MINUTES AND RETRY.
Posted on Jan 17, 2009
Model MAH7500 door will not latch
Clearly it's broken requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Oct 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
My maytage neptune washer is flashing PF what does that mean?
Hi
Error code PF means power failure. This happens when there is a power surge or the washer is unplugged manually. To reset this error you'll need to turn off the washer and unplug it for 10 minutes. Restart the washer and check, If the error still appears then pressing the Spin Speed key will begin the Board Output Test. This test turns ‘ON’ a specified output after a key press. Pressing the Spin Speed key again cancels the test. Please post back for further assistance if required.
Daniel
Aug 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer will not get up to speed in spin cycle error code E3
E3 means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code somes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 09, 2010 | Maytag Washing Machines
Maytag error code F My Nepturn washer stopped midcycle and the panel is flashing F What is wrong?
have a look at this manual:
Maytag manual
Its a PDF file but should open automatically and could take a minute or so depending on your internet speed.
Scroll down to page 15, this will show and tell you what the error codes mean.
I hope this helps
Regards
Mike
Mar 22, 2010 | Maytag MAH6700AWW Neptune Front-Load...
What does a 3E error code mean? i have a maytag
Trouble shooting guild for this machine indicates this means Motor Failure. Over current is detected
Feb 08, 2010 | Maytag MAH8700A Front Load Washer
My maytag washer is giving an F H reading. I
http://laundry.manualsonline.com/manuals/mfg/maytag/mah7500.html
If the manual on this site doesn't help, you may want to try maytag.com for a manual.
as for the F H reading---you got me
Aug 09, 2009 | Maytag Neptune MAH7500WH Front Load Washer
We had a power outage in middle of a wash. Now washer (MAH7500) says "Speed Indicator Error." I press pause/start, motor hums, but stops and message reappears. Have tried turning off & waiting and...
Check voltages at the outlet. My guess is that you are on the HVAC circuit, and the Neptune is more sensitive than your hvac equipment. Also check that the neutral is about the same potential as the ground.
Speed indicator issues could also mean a bad motor/motor control. If the above did'nt worked out, then most likely, its an issue with the motor control. You can try checking out this kit. This includes an video installation how to.
Please let me know about the results.
Thank you.
Aug 08, 2009 | Washing Machines
I do not get the door lock indication on my maytage neptune frontloader washer, which prevents the high speed spin.
what model is it if its the 3000 or 4000 u have to replace lock latch and top board not worth fixing if its thee 5500 model just the locklatch and its worth fixing
May 20, 2009 | Maytag Neptune Washer
CODE SYMBOL " LR" (MAYTAG NEPTUNE SERIAL # MAH6500AWQ")
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
Dec 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Speedindication Error
Yes, The motor and motor control board are not talking to each other. The motor has a built-in tach that signals the board as to its' position and speed. One of the two is faulty. This is an expensive repair. Parts will cost between $225 and 325 depending on where you are. Make sure the repair tech has a good reputation before proceding or do it yourself.
Dec 23, 2007 | Maytag Neptune MAH7500WH Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
448 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
