Question about Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
Reset code - Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
  • 3 more comments
  • undercoverme Jan 17, 2009
    not sure it is a power vent richmond/rheem 50 gal model #6G50PVW-42F it has a soft touch temp adjust on the front, no pilot,also has flamable vapor sensor,which is what tripped the unit.thanks john
  • shennes1123 May 11, 2009
    Need Reset Code richmond water heater
    Need reset code for Richmond water heater
  • Thomas F. Schneider May 11, 2010
    Sorry .Don't know much about those type.
    Reset code? It has a microprocessor?
    Standing piolet light? thermocouple?
  • 90 Answers
Go to www.richmondwaterheaters.com and click residential products on the lfet and see if they can help you out. Good luck!
Posted on Jan 22, 2009
Reset bosch error code
reading the manual would be my first choice .but try Google and see if there might be one available . I don't use hi tech appliances as they seem to fail more than the old manual type units
May 23, 2015 | Bosch Water Heaters
Just installed, shows error code E2, is not heating water
An E2 code is often an indicator of an electrical problem inside the water heater. The most common problem is with the inlet water temperature sensor. Often a reset will fix the problem. To achieve the reset unplug the unit. Open the unit being careful of fragile electrical wires. Next remove the computer board and then disconnect each plug in wire and reseat them one at a time. Reassemble the unit and plug it in. It should be in working condition, without the E2 code.
May 22, 2015 | Water Water Heaters
How do I erase error code 1l
1L is scale build-up in heat exchanger: delime tankless unit:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#delime
If error code will not reset afterwards, then holding both arrow buttons down on remote might reset error code.
Models have changed since this pdf was posted in 2008
http://hometips.me/Tls/Clear-fault-history-Service-manual-2008.pdf
If error does not clear, then call Rheem and expect them to try to sell you a service call.
Gene
Water Heater Timers Save Money
Dec 07, 2014 | Water Heaters
HOW TO RESET CODE 1L
Open cover.. find buttons min/max press nim then press mas and then hold min and max presses for 5 seconds or so. Power off controller and power back on..You have reset your fault code til next time. Rheem is poor on info and poorer yet on service..Good luck
Aug 04, 2011 | Rheem Tankless Hot Water Heater...
My water heater is flashing a cod 2 then 3 how can i reset this i lost ths manual
First thing to try for any electronic problem is unplug the machine and see if problem resets.
Before calling service technician, open following link for Rheem tankless resources including error codes and possible manual and Rheem chat and contact:
Error code 2 and 3 do not show on Rheem/Paloma charts or in typical manual.
Error codes are generally considered start places for troubleshooting.
Multiple error codes can mean PC board failure, but same problem on one unit can have different cause and solution than another unit.
Read the manual and make sure yearly maintenance is caught up.
Add a comment and say what you did to solve problem.
Jun 13, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
The control unit needs to be reset when I loose power
have two boilers one a rheem the other raypak, the raypak keeps turing off i have to push the reset button. what could be wrong
Dec 30, 2009 | Rheem Paloma Tankless Water Heaters...
Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
298 people viewed this question
Top Audiovox Water Heaters Experts
Paul Carew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
