Question about Asko 24 in. D3530FI Built-in Dishwasher
Drain Pump The dishwasher over filled by back syphoning down the waste pipe. I have raised the pipe so this cant happen again but the drain pump keeps running and the LCD reads "Overfilling" Anyone know how to reset the control panel?
  • fraser heaven Jun 20, 2007
    Have you tried turning off and on again
    Genius:
  • 2,985 Answers
The machine is over filling because the fill sensor is blocked with debris Somewhere low down on the body of the machine there is a small bottle like object clipped to a small pipe coming from water tank , from the back of this will be a small plastic tube going to a dish like object somewhere high up. This is the fill sensor. The bottle like device is in all probability blocked with -grunge- a combination of grease/detergent/scale -it needs removing and a good clean out.
Posted on Jun 20, 2007
Where to drain the bad gas from I mixed it with diesel
There is NO drain on the tank bottom.....Disconnecting fuel line/add extension if/as needed,place hose/extension in aux fuel tank,add 'Modis',request fuel pump 'on' & drain tank.....Add fresh fuel,replace fuel filter & ad fuel injector cleaner (Preferably Lucas #10020) & PROPERLY dispose of waste fuel.
May 01, 2015 | 2006 Nissan Maxima
Lights 2+4 flashing on dishwasher & won't drain
Doe the pump make a sound as if it's trying to pump out? As it sounds as though your pump is either obstructed, or the outlet waste water pipe from back outside of the dishwasher to the drain, maybe bent somewhere or blocked & not allowing water to exit the dishwasher, if both are clear of blockages & no noise of the pump kicking in to empty the dishwasher then I would definitely say the pump has failed...
I hope this helps....
Feb 22, 2018 | Dishwashers
My dishwasher won't drain properly. The pump has been making a weird sound for a month or so and last night it couldn't drain. It starting beeping and the pump was running. I cleaned the drain filter
If the pump is running but noisy then that indicates a loose pump impeller (new pump I am afraid) if running (no noise) but failing to remove water, then I would be checking that drain hose is clear, or even that your machine is not syphoning water from waste disposal, a quick check would be to disconnect waste hose from waste disposal and see if it will then drain into a bucket, hope this is helpful.
Feb 18, 2013 | Dishwashers
The inlet water does not stop
It could be that your waste pipe is pushed to far down into the drain not giving you an air break between the waste pipe and the water in the bottom of the drain pipe causing the water to syphon out and never allowing the machine to fill to its operating level. raise your waste pipe up until you have an air gap inside your drain pipe and fix it in this positionwith the hose crook that came with the machine or purchase one for a few pence if you have lost it.
Jan 09, 2012 | LG Washing Machines
AEG 73630: wont take water in, cant pump water out, when choosing a program the timer seems to have changed minutes with seconds, and when choosing af program, the only thing happening is, af few spins...
The machine knows what the water level should be at every step of the program, so if its full when it should be empty, is not filling when it should be or is taking too long to fill or empty the program will abort and count down in seconds as you describe.
First - check the drain filter for blockage!! if clear, can you hear the drain pump running on 'drain' program? a chug chug chug noise. If not pump may be jammed or seized - or the drain tube maybe be blocked at the waste connection on the sink, etc. Or maybe the water supply pipes have blocked or got turned off? Possibly the waste pipe may not have been installed correctly and the machine is syphoning empty? ie the end of the waste pipe is lower than the water level in the machine - so it syphons empty like draining petrol from a petrol tank! That would empty the machine when it should be full.
Check all the basics of filling, draining and filter before suspecting anything else.
Feb 01, 2018 | AEG Washing Machines
I have a brand new whirlpool DU1055XTV5 dishwasher, installed two days ago. After the cycle completes there is about 1/2" clean standing water left in the bottom. It is not just down in the well area,...
Ensure the outlet pipe is below the level of your floor and straight to a drain or plumbed into the waste pipe directly with no chance of syphoning from standing water in your drain/waste pipe.
Apr 04, 2017 | Whirlpool DU1055XTS Built-in Dishwasher
My Dishlex Global 300 dishwasher stops mid cycle and the rinse light keeps flashing ?
I think I had the same problem. I don't know much about dishwashers, but the "Flashing Rinse" has something to do with the drain, or the drain pump (which is why the water doesn't drain).
My dishwasher stopped its cycle, after having filled up with water, even though everything else worked fine, because the drain pump was not even turning on. So I guess, the first question I asked was, is the drain blocked? No. When this happened the first time, the flashing rinse cam up. After that, the dishwasher just wouldn't drain, and there was no longer a flashing rinse.
So then, I figured, the drain pump is probably rooted. The drain pump is found underneith the dishwasher, just behind the front panel on the left hand side.You'll need to remove the metal covers from the front and the left.
When this happened to me, I thought I'd need to buy a new pump, so I pulled the other one out (its a bit fiddly, you have to disconnect the two electrical wires, then remove the drain pipe from it, and then wiggle it off. But when I got it out, I unscrewed it (it has the special hexagonal screws, not phillips or flathead), and it turns out, a fairly large fruit seed had got into the drain pump and blocked it, preventing it from spinning. I put it back together again, and it worked.
It so far has beaten paying $100 for a new pump.
If you want a visual of what the drain pump looks like, look up the dishwasher part number #8905912, you should be able to find it on the internet. Hope this helps.
Jul 29, 2010 | Dishwashers
The waste water backs up into the dishwasher when sink is plugged
Dishwasher manufacturers recommend a syphon break be fitted - but usually there is not a problem if your sink has an overflow pipe incorporated.
You have a partially blocked drain - causing wastewater to flow into the dishwasher instead.
Use 1/2 a cup of caustic soda or proprietary drain cleaner down the sink drain. Add about a pint of water, and leave overnight.
Next morning pour a full boiling kettle down the drain which should move things on and clear the drain.
You may have to repeat this process once, but is preferable to taking your pipework apart - which is next if this does not clear it.
Sep 14, 2009 | Dishwashers
Machine keeps filling and draining simultaneously nonstop
You have a syphon problem . This happens when the drain hose is too tightly into the drain pipe . Remove the drain hose from the pipe and put maybe a pencil or piece of copper tubing between hose and pipe ( or get a syphon break from home depot , or an appliance parts store ) . This will let air into the line , so syphoning will not occure when filling . Undisolved soap can cause this problem , by sealing the end of the drain hose as it splatters out into the drain , or some people will tape the end of the hose to the drain pipe , trying to keep the drain from backing up out of pipe ( mistake ) .
Aug 26, 2009 | Kenmore 24032\24036 Top Load Washer
Hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Feb 14, 2008 | Dishwashers
Asko 24 in. D3530FI Built-in Dishwasher Logo
441 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
