Question about Memorex iWake MI4004 Clock Radio
Memorex Mi4004 - buttons will not work due to static electricity
My daughter was turning off the alarm, but had static electricity when she touch the radio/alarm - now none of the buttons work. We can not set the time, change the alarm, raise/lower the volume, etc. Is it worth trying to fix or is it broken and ready to be thrown out?
  • KariN89 Jan 31, 2009
    My clock would often reset when I touched it because of static electricity and one day when that happened all of the buttons stopped working.
3 Suggested Answers
jmgldsmth
  • 1906 Answers
SOURCE: No owner's manual. Is there a free one on line somewhere?
http://memorex.com/support/support_main.php
Posted on Jun 03, 2009
  • 159 Answers
SOURCE: I have the memorex Mi4004 and it won't charge
Hi, I do have the solution, the Memorex Mi400 clock radio does not itself support charging of the iPod touch. last model supported was the iPod video 5g. There may be a way around this however, I have an iPod sound system that doesn't support charging either-however it has a ipod charging port on the back-if I plug in my iPod touch's charger there it charges, so I would look on the back of your clock radio to see if there is a connector that looks like the one on the bottom of your iPod touch. Plug charger in there and you'll be good to go. I hope this was helpful and thanks for choosing FixYa-good luck, Prodzilla.
Posted on Apr 20, 2011
I have the memorex Mi4004 and it won't charge my ipod touch. I have to third generation ad it is 8GB.
Apr 20, 2011 | Memorex iWake MI4004 Clock Radio
My memorex quit playing all sound
  1. Unplug the unit and remove the batteries, wait 5 minutes, plug the unit back in and install the batteries.
  2. Check the male end on the iwake and the female end of the ipod for damage, if you are using an ipod it sounds like you may have a bad connection.
  3. Check if the Radio function plays sound.
  4. Make sure the Volume is not turned down.
  5. Does it play through the headphone jack? If so, your speakers may have failed.
  6. Most likely this will need to be sent in to Memorex, or a new unit will need to be purchased.
Contact Memorex product support, please call 1-877-363-6673 Monday - Friday: noon to 9:00pm, EST
Feb 25, 2011 | Memorex iWake MI4004 Clock Radio
I don't know how to set the clock for a MA4203 model
I couldn't find the information for your particular model, but I did figure out the general procedure for Memorex alarm clocks currently in production:
  1. Make sure power is turned off (no radio or whatever playing). Press the Time Set button (on some models, this is the Skip Search Back button for an iPod docked in the unit).
  2. When the display blinks (on one model, the volume control knob lights up), press the Hour button (Vol. -) to set the hour, then press the Minutes button (Vol. +) to set the minutes. On the model with the light-up volume control, rotate the volume control knob to set the time.
  3. When you have the time set, either wait 15 seconds or press the Time Set button again to start the clock.
Setting the alarm works the same way on single alarm models, but the Alarm Set button may be the Skip Search Forward button. Dual alarm models have separate Alarm A and Alarm B buttons.
Feb 05, 2011 | Memorex Audio Players & Recorders
My alarm clock does not distinguish between AM and PM. it simply does not turn on the sign for either, so i cant tell if my alarms are set for am or pm...kind of important.
Sounds like a display problem where the indicator isn't working. This might be a bad connection or it could be the display itself or the driving electronics. In any case, it would probably cost you more than the clock radio's worth to have it repaired (assuming you find someone who'd take it for repair in the first place!).
Here's a "solution", though. Set your alarm for a time only a couple of minutes later than the current time and wait around. Depending on whether or not the alarm sounds, you'll know if it's set for AM or PM. At least you'll be able to keep using it until you decide to replace it.
Oct 06, 2010 | Memorex iWake MI4004 Clock Radio
My mi4004 radio does not have any sound everything else works but no sound at all
I have the exactly problem with my radio ....Model : Mi4004BLK ....it's do not have sound and every time click boton it blink in the screen when
I don't have the ticket to return the radio because I have 2 years with it and I can't remember in which store I bought....( Walmart, Target , Best Buy )....why can I do so I can resolve this and it can work ?
Jul 23, 2010 | Memorex iWake MI4004 Clock Radio
My dock can only charge my iPod.
Try unplugging it for a while then plug it back in and try again. If that doesn't work, you may have to get another remote or have it serviced.
Best of luck :)
-James
Jul 21, 2009 | Memorex iWake MI4004 Clock Radio
Battery area
The batteries (2 AAA) are made as a back up for the clock and alarms only, and would not be powerful enough to run the radio on their own.
Jun 01, 2009 | Memorex iWake MI4004 Clock Radio
Display
the screen is waring out and needs replacing but very costly
can i suggest its not worth fixing its cheaper now to buy a new one
Jul 16, 2008 | Memorex iWake MI4004 Clock Radio
Memorex iWake MI4004 Clock Radio Logo
178 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
