Question about Sony PlayStation 2 (PS2) Console
After cleaning, the power wont turn back on
Earlier in the day I cleaned my lens, then closed my PS2 back up. I sat down to play and it wouldn't accept power, I unplugged it, moved the cord... blah blah. Nothing worked. What could have I done to my PS2 during cleaning to create this problem? My PS2 is the old fat one, but a slightly newer model so I learned from opening it. It's two and a half years old. Please help...
    New Friend:
  • 129 Answers
80% chances that the flexible cable ,its unplugged. please open it a check if the power switc has this properly connected on both sides, and if is not broken.
Posted on Jun 20, 2007
  • Luis Amado Jun 22, 2007
    if that didn't fix the problem check for broken solder joint ,exactly where the ac cord jack is connected
SOURCE:
I just got the game god of war, now the playstation2 will not read the disc. why?
The problem can be with your scanning lens that might be dirty.Clean your PS2 lens first.Watch this video to learn how to clean PS2 lens.
Always keep your PS2 in clean place.If lens cleaning wont work then try following trick.Click to view it.Although its for PS2 DVD movies but you can try it to play God of War too. Good luck!
Trick to play games and DVD movies!If not loading.
Dec 04, 2009 | Sony PlayStation 2 (PS2) Console
Ps 2 wont read game disc, goes straight to browser setup.
Your PS2 lens is probably weak or its dirty.You should try to clean your PS2 lens first.A dirt on lens wont let your PS2 lens to read your Game disc. Watch this video this will help you to know how to clean your PS2 Disc Reading Lens.
Try to place your PS2 at clean place and clean your PS2 regularly.
Nov 30, 2009 | Sony PlayStation 2 (PS2) Console
Wont load
Disc read errors are mainly due to worn out lens or dirty PS2 lens.Clean your PS2 lens to get rid of this problem if your lens is dirty.Watch this video it will help you to know how to clean your PS2 lens.Watch it carefully.
Remember to keep your PS2 in Dust free environment if you don't want your PS2 lens to get dirty.
If your PS2 can not play certain games like Rock band try this tip:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  5. New screen will appear like
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
And after that wait till your game is loaded.
Click here to view full tip.
Nov 16, 2009 | Sony PlayStation 2 (PS2) Console
Neither my Playstation nor my Playstation 2 will play most of my black bottom discs..it shows the Playstation logo and sound but no picture..most are role playing .like Dragon Warrior 7 or Lunar.please...
How to Clean PS2 laser lens. Older PS2
  • Step 1 Check the lens-cleaning disk. It is important that it is free from dirt or debris. If its dirty, the disk can damage the laser lens on the Playstation 2.
  • Step 2 Press the Playstation 2 open button. Insert the lens-cleaning disk in the tray and close.
  • Step 3 Wait roughly 10 seconds for the disk to read. The brushes on the lens disk will clean the laser.
    New Slim PS2
  • Step 1 Unhook the PS2 from the outlet and the TV. If the power cord has a connection to the outlet, damage can occur.
  • Step 2 Dip a cotton swab into an alcohol bottle. Open the lid of the PS2 with the button.
  • Step 3 Use the cotton swab to rub the lens. Gently brush the laser lens with the cotton swab, covering the entire area.
  • Step 4 Wait about an hour for the laser to dry
  • I had this same issue with my Older style PS2 and I had to take it apart and manually clean the lens. It worked perfectly after that. I was extremely nervous opening up my system, but if it didn't work I was willing to take the chance.
    Here is a link on someone taking a ps2 apart.
    http://www.youtube.com/watch?v=_6AgzkU2C3g
    Mar 07, 2009 | Sony PlayStation 2 (PS2) Console
    Ps2 wont play games
    you will need to replace lens but due to the cost of the part i recommend you getting a new one or if not do a pot adjustment or clean lens with alcohol and Q-tip
    May 28, 2008 | Sony PlayStation 2 (PS2) Console
    Playstation 2 problem
    I would try cleaning your Playstation games, Check and make sure that the games your trying to play are not cracked in anyway. Also, if you have your system standing vertically lay it down horizontally. Many times after you've closed the disk in it lens to far away from the lens.
    Dec 27, 2007 | Sony PlayStation 2 (PS2) Console
    Wont spin
    get the software that allows you to play copied games and use that on the ps2530d765.jpg
    Nov 25, 2007 | Sony PlayStation 2 Slimline Console
    Games wont read
    open up your ps2 and clean the lens with a cotton swab. this happened to me a while back ago and it solved my problem. you might have to take the ps2 apart and make sure the whole thing is clean
    Nov 10, 2007 | Sony PlayStation 2 (PS2) Console
    My PS2 will not play PS2 games, but it will play PS1 games
    Hi
    If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
    I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
    1. Disconnect power and turn the case upside down.
    2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
    3. Remove all the screws.
    4. REmove the Warranty sticker to the right edge of the power socket.
    5. Turn the PS2 over to set it right side up.
    6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
    7. Remove the Cd tray lid.
    8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
    9. Hook up the power and A/v Cables.
    10. REmove the little white disc from the Cd tray lid.
    11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
    12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
    13. Put it back together, and your in business.
    If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact [email protected]
    Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
    PS2 Wont Play
    4. Remove the Warranty sticker to the right edge of the power socket.
    6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
    7. Remove the CD tray lid.
    8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
    10. Remove the little white disc from the CD tray lid.
    13. Put it back together, and you’re in business.
    Oct 30, 2007 | Sony PlayStation 2 (PS2) Console
    Sony PlayStation 2 (PS2) Console Logo
    48 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Ekse
    shevantha perera
    Damen Wong
    Damen Wong
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
