Question about Uniden BC248CLT Base Scanner
BC248CLT: The unit will scan & pick of traffic, but you never hear a word, or sound. This unit was turned off and put aside for a couple of months. After being plugged in, everything seems to work normally except there's no sound. Got any quick fixes, or things to check? Thanks in advance!
  • 1 more comment
  • badassbowtie Jan 20, 2009
    Thanks. I have tried an earphone with good results. I'll try the plug it in, unplug it thing to see if that works. Thanks again!
  • tgrimes5 Mar 01, 2009
    how do i set frequency codes?
  • Rick Byrd
    Rick Byrd May 11, 2010
    if you happen to have an earphone from most an radio type device try checking if sound is ok through the earphone jack , if so unplug check for normal sound again , if so good , if not , poke the earphone jack in and out a few times , sometimes the jack canceler can stick , its worth a shot .
Set frequency
Posted on Mar 01, 2009
I was given an old uniden bearcat 16 channel 10 band scanning radio bc144xl and i would like to hear all the fire,police and emergancies in my area but i have never had a scanner befor and dont know the...
Programming the BC248CLT is fairly simple, and detailed instructions can be found in the factory manual that you can download and print here:
http://www.uniden.com/pdf/BC248CLTom.pdf
What you can program and what you can hear will depend on your location. Many communities now use trunking systems and digital (APCO-25) systems, and your scanner is not compatible with either. For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B
Sep 12, 2010 | Uniden BC248CLT Base Scanner
New BC355C put 7 channels in,but only will stop on 2
1. Be sure sure that your squelch is adjusted properly. While scanning, turn the SQUELCH control down slowly until scanning stops and you hear a hissing sound. Then slowly turn the control back up until scanning resumes. That will set a proper threshold level for the frequencies you're monitoring.
2. Be sure that signals are not blocked in your area. Topography plays a large part in VHF and UHF radio reception. A hill, a tall building, even a thick grove of trees can prevent a signal from reaching your antenna.
3. It's possible that there was just no traffic on the five freqs while you were listening.
4. Be sure that the frequencies you've programmed are assigned in your area.
5. For a comprehensive database of active frequencies in your area, visit:
BillB
Jan 26, 2010 | Uniden BC350C Base Scanner
I don't have the manual for my Uniden Bearcat BC 855 scanner.
You can download/print the complete manual for your scanner by following the link below. It's a free download, and it provides detailed programming instructions. If you're programming a channel that is "empty" (showing 000.0000) just enter your frequency. Empty channels automatically show LOCKOUT but it clears with programming. The squelch setting will vary according to the strength of the signals you receive. Once you start scanning, turn the squelch down until scanning stops and you hear a hissing sound, then turn the control up slowly until scanning resumes.
Dec 30, 2009 | Uniden BC248CLT Base Scanner
I bought a boat with a clarion cd/stereo head unit. I noticed a problem while trying to play the radio that the speakers continually cut out. I get music for 2-3 seconds, then a popping sound, followed by...
try taking antenna lead out of set and put a length of wire into the center hole were the antenna fits then scan,you should pick up at least one station,if you do fit a new antenna,if not try switching off any traffic anouncement services on the set ie press and hold button marked either ta/rds/tta/ast
Topspark
Aug 21, 2009 | iLO XM-MP3-CD Car Stereo
Acts like squelch is stuck
I had the same problem. Your board may be fried. I had to buy a new unit.
Jan 28, 2009 | Uniden BC248CLT Base Scanner
Won't stop scanning
L16 Disc coil needs adjustment, Audio is slightly off, and improper noise to DC squelch level detect used to stop scan on active channel. Set to an on freq signal like a NOAA weather channel, and useing a non-metallic tool, adjust to best sounding audio, probably less than a half turn either direction. An on freq signal moduated by 1000hertz, connect scope to speaker and adjust for highest undistorted recovered audio would be better if you could.
Dec 31, 2008 | Radio Communications
Uniden BC248CLT BASE SCANNER
If it seems to be locking on a channel like someone is talking but no sound, it's possible that the speaker quit working. Simply plug in an external speaker into the plugin on the back. I have a BC 860 that the speaker recently quit. That's what I did and it sounds better. Good luck Mechanic
Jan 14, 2008 | Uniden BC248CLT Base Scanner
Uniden BC248CLT Base Scanner Logo
82 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
