Question about D-Link Computers & Internet
Having problem installing my dlink dir615 router
My paradyne router will not issue an ip address.i have static ip address .tech support told me to leave my modem unplug for 30 it can assign a new mac address.dlink techs can not solve my problem.also,i cannot get into the router to configure.can anyone help !
    Problem Solver:
  • 6 Answers
First, is the problem truly that you can't get an IP address from the router or is it that you can't get on the internet. I will touch base with both issues briefly. Many newly placed routers need the MAC address cloned within the router setup to register with the ISP and recieve internet access. If the PC is truely not recieving an IP from the router, make sure DHCP is turned on and set a range of address you wish use. Tip: limit the number of addresses to only what you will actually use. Make sure your computer is set to recieve an IP automatically and you have the proper client, service and protocols running. Basically, If the PC will run directly from the cable modem, then it should run from the router also. If the PC will not obtain an address from the modem directly then your winsocket may be corrupt. Malware will often do this. It is easily repaired and there are many winsock32 repair tools on the net. Just Google "winsock repair" without the quotes and you will find a multitude of software.
Posted on Jan 21, 2009
Set up epson workforce 600 printer wifi via dlink dir615
Configure the IP address range your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but higher address eg. so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg.
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Oct 26, 2012 | Epson WorkForce 600 All-In-One InkJet...
I have a dlink DIR-615 attached remotely to another home router system. It is hardwired via a LAN port and I connect to internet via the remote DLINK router via wire or wireless just fine. Problem is I...
After you change the IP address of your Router, you have to reset your Network Card IP address if it is Dynamic. If your IP address is Static you need to manually make these changes from within Windows. Else, reset your computer and try accessing the newly issued IP address for your Router.
Close all Browser Windows and Programs before continuing.
From the Command Prompt, type:
C:\> ipconfig /release
Press Enter, and then type:
C:\> ipconfig /renew
Now try and access the New Router IP.
Oct 24, 2011 | D-Link Computers & Internet
IP conflict on dlink WLAN router
If you are using static IP address on your computers then please switch over to dynamic IP. Also, please turn off all the devices on your network and then first turn on the modem and then dLink router and then your computers. This should resolve the issue.
Feel free to reply if the issue persists.
Mar 13, 2010 | Computers & Internet
If you have not unplug the power to the modem and router then turn back on the router first then the modem most reviews forget to tell people turn off everything reboot modem router and computer for the DHCP to work properly the switch on cable modems only place the modem in standby mode you must turn off the power
Oct 27, 2009 | D-Link DI 514 Wireless Router (DI-514)
Paradyne 6218 12 200. With dynamic IP address, this modem/router will assign addresses to both fixed all 4 ports, and wireless laptops. How do we program it to do the same when ISP has assigned a static IP...
If desired change the IP address or Gateway will please right click the name (My Network Places), then right click (Local Area Connection), (Properties), have at the bottom to select, high light the name (Internet Protocol (TCP / IP), Lift Click the Properties, to trim after you customize IP add and modify the following required.Good Luck
Jul 23, 2009 | Paradyne (6218-A1-200) Wireless Router...
What are the settings for windows 98 for d-LINK DIR615 ROUTER
In control panel, find the network applet and double click it. in the white box, locate TCP/IP(Internet Protocol) and select that, then click properties
Make sure you're set to DHCP which should, once you're physically connected to your router, obtain an IP address and DNS server addresses automatically
Mar 03, 2009 | Microsoft Windows 98 Second Edition for PC
Dlink dgs 2208 switch
pls check your connection between the switch and the router,dsl,access point.
2.make sure the gateway router is receiving good signals
Apr 12, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
Game console and router
try or call customer support at 1-800-4myxbox if that doesnt work you can call your internet provider and they may have info on your problem
Jan 13, 2008 | Video Game Consoles & Games
Wireless access point connecting to router...
The question is how do you want to cable the netgear and what do you want to do with it.
If you cable a lan port of the DLink to the Netgear WAN port you will have two subnets that must be addressed differently. Opening up and forwarding the ports for XBox could be difficult.
I believe cabling the Netgear as an access point makes more sense. CONFIGURE THE NETGEAR BEFORE CABLING. This is achieved by wiring a lan port on the DLINK to a lan port on the netgear and ignoring the wan port on the netgear. This will involve configuring several router items that should be completed before the devices are cabled together. You will need to remember the Netgear's new network address and probably use a static IP address from a computer to configure it back into being a router after these changes, if required. Or reset the configuration to factory default following the users guide.
First the Netgear needs DHCP turned off as it will be part of the DLink's network and not a separate subnet - the DLink will perform the DHCP services.
Second the LAN side of the Netgear will need a static IP address in the DLink's network. This is where it may get tricky for you. Verify the DLink has an IP Address like and a subnet mask like That means all IP Addresses in your network start 192.168.0.??? where ??? is unique for your network. Verify your DLink router has a set of addresses reserved in the DHCP setup for dynamic address assignment these addresses like to If the above is true or with the information you extract from you DLink router you need to determine where you can create static IP addresses -- in the above case to are available. You need to assign one of those like to the LAN side of the NetGear Router. You will probably want to assign another to the XBox == like You will probably need to deal with opening ports or placing the XBox into the DMZ of the DLINK router which will require a static IP Address.
Now cable the devices
When considering the XBox Configuration below the DLink is the router that must be configured to allow the open ports or DMZ access to the Xbox == the netgear is not functioning as a router in this configuration.
Check out the following links on XBox Configuration if required.
The second link may be the best to start with.
The generic connection and configuration document
This is a good description of possible router2.gif options.
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Dec 27, 2007 | NetGear MR314 (MR314NA) Wireless Router
Router won't speak with computer
If you check your computer's IP address, is it getting one from the router? Normally out of the box these routers are setup to give out DHCP, which basically means that your computer, if also set that way (again, default) will grab any necessary info from the router (IP address, subnet mask, gateway, etc). You didn't at some point set your PC to use a static IP address that's different than the D-Link's subnet did you? D-Links default to, so your computer should be getting an IP in that range as well.
Sep 22, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
227 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
