Question about Kenmore 75022 / 75024 / 75029 Gas Kitchen Range
We have a Kenmore 75022102 gas range. Tonight, the stove was not in use but we heard a loud pop. Later when I tried to light a burner there is no gas flow, just the click. The oven has gas flow but won't light. The clock still works so I don't think I blew a fuse. What's going on?
  • Anonymous Feb 08, 2009
    Loud popping noise then white flame what is going on?
catriver
  • 878 Answers
SOURCE: burners don't receive gas though oven/broiler does
tommi, this model has a cooktop lock-out solenoid feature. Try pressing and holding the top light keypad for 5 seconds and see if the top comes back to life. If not, check your owners manual, it may be a different key. The lock-out solenoid is in the back behind the outer panel. The cooktop lockout valve has been redesigned from a AC to DC voltage because of complaints of chattering. The new part number is 8184768. Lets hope you don't need it and just have the top locked out.
Posted on Apr 10, 2007
freetek
  • 5568 Answers
SOURCE: Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Posted on Jun 19, 2008
reg501
  • 413 Answers
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
Posted on Jun 26, 2008
rickzilla
  • 706 Answers
SOURCE: circuit blows and when we get it back on the fault code says H3
Hello rcgrecco,
I will try to assist you but will be making some assumptions based on your problem description. First off, when you say it takes a few tries torest the fuses.. are you referring to circuit breakers? or changing out fuses a few time until it begins to work ok? In either case, the fact that it is drawing more current than the service ( fused or circuit breaker protected implies that you have one of two problems, 1. undersized service ( meaning the fuse of circuit breaker which protect the circuit is under-sized) or 2. a short internal to the stove or receptacle that supplies power to that stove.
I would approach a solution in this manner. Remove or disable power to the stove then open the wall receptacle and ( with power verified and off) tighten all wire junctions.. I have seen cases where a loose wire termination becomes resistive and then in order to meet power demand at the burner, more current is drawn which in turn causes the breaker or fuse to trip..) I would also check the terminations at the point of entry for the power cord at the stove. Make sure all the wire terminations are tight. Once you've done that, try turning on one burner at a time and see if the service remains on or trips the protector ( fuse/breaker) I wouldn't use the oven until I verified that each burner works OK.. then try the oven by itself.. and add a burner .. then two.. ( the point being is to try to determine if you have one of the heating elements shorting. 12:00 flashing is the default time setting after power is lost and restarted. I am almost 'questioning your electricians findings" since circuits do not trip unless there is a fault ( too much current being drawn or the service is under-sized for that oven) or... the circuit protection in and of itself is failing due to marginal components. The fact that it is getting worse suggests that whatever was shorting is shorting more frequently.. perhaps a heating element is shorting after it gets hot.. they are typically resistive elements and it is possible for a short to develop between the core material and the protective jacket.. I hope that helps you... or at least provides a few ideas on where to look...
Regards,
Rick
Posted on Feb 16, 2009
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
I have a kenore stove model 665 75022102. Do you know if it is possible to light the stove burners with a match if we lose electricity?
yes is it entirely possible to do that..without power the oven will not work however...good luck i was hit with hurricane irene yesterday and it was a bad one but its the cost of living on the eastern shoreline (virginia)
Aug 28, 2011 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Large pop noise tonight while using oven, then problems where buzzer would come on by itself & lock oven. Oven does not work now, nor do the buttons make the usual noise. The stove top burners work...
Sounds like you overloaded a capacitor on the clock assembly. Before you replace the clock, you should check the voltage to your stove to be sure it's a steady 110 to 125 volts. But yes, it sounds like your combo clock brain got zapped.
Mar 07, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Stove cutoff after loud popping sound
The element burnt in to and arced which is the loud noice you heard red flash of light. It probably tripped the breaker at the electrical panel. Don't turn it back on until someone checks the element and replaces it.
May 28, 2009 | Kitchen Ranges
Clicking sound on my gas stove
You just need to turn the knob a bit more, thats the igniter you are hearing.
Mar 17, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
No spark on all burners, oven doesn't work either
Give me the complete model # from the sticker on the oven and I will try to help.
Nov 07, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kemore Gas oven - trouble igniting
Hi Deeg, there was a service flash regarding this problem. The bake burner and bake igniter have been modified to assure consistent oven ignition and performance. The number of ports on the burner have increased located at the electrode tip. The electrode shield has also been modified. This repair should be covered under warranty. The kit part number is 8190618 for your information. If your serial number ranges from RK01 through RR11, this is your problem. I would call Sears and request service. Catriver.
Sep 12, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore 75022 / 75024 / 75029 Gas Kitchen Range Logo
74 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
