Question about Frigidaire GLER642A Electric Dryer
Light is on but wont tumble
Belt is good.
  • msmax1999 Jan 17, 2009
    thanks for the help. I was not the problem but it helped us to narrow it down to the door switch
  • Frigidaire Master
  • 8,220 Answers
The fuse is mounted on the rear bulkhead upper right hand corner. About the size of a dime. It only blows if there is a restriction of some sort in air flow.
Posted on Jan 17, 2009
  • Dan Webster
    Dan Webster Jan 18, 2009
    Glad you could get it a goin
Dryer wont tumble
Probably a broken belt. Remove the back panel and see if the belt is still around the tumbler. You might pull on it and see if it is broken.
Oct 11, 2014 | Dryers
Kenmore 70 series dryer. Heats up but quit tumbling.
belt is off or broken here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
routing of belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Good Luck Tim
May 11, 2011 | Dryers
Drum belt installation
here are some belt diagrams, don't know what dryer you own:
http://www.partselect.com/dryer+examine-belt+repair.htm
http://www.applianceaid.com/images/belt-config.JPG
here is how to open some dryers:
Good Luck Tim
Mar 11, 2011 | Dryers
Turned on dryer & tried to start but it gave a load thud noise & wouldn't go. Stop it then re-started a light came on stating clean filter. Clean filter & look inside that area to see if...
there is a sensor located beneath the lint filter, more the likely the dryer sheet residue is on it, gently brush it off, it has two screws. As far as the loud thud noise is/may be a problem with the drum/rollers/glides/belt/idler arm/motor Here is a website that will assist you, once the filter light goes off and the drum will not turn.Good Luck Tim
Mar 05, 2011 | LG DLG5988 Gas Dryer
Where is the belt located?? This maytag legacy elec dryer is 4 yrs old. over the last few mths it has made louder sqeaky noises but now all of a sudden it stopped tumbling!! It still heats up like it's...
it is inside the dryer, you will need to disassemble the dryer here is a website that may help:
diagram of belt routing:
Good Luck Tim
Feb 09, 2011 | Maytag MDE308DAYW Electric Dryer
How to replace a crusader tumble dryer belt
this is a good website, hope it helps Tim:
Oct 16, 2010 | Dryers
Creda T622CW condenser tumble dryer drum wont turn
You need to check if the belt is o/k.
Remove top cover, and grasp belt, it should be firmly wrapped around drum.
If o/k, then could be a motor problem, or programmer fault
Once you have got the drum turning again, it is possible the filter light will go off,if not, then you have another fault
Hope this helps.
Dec 16, 2009 | Dryers
My dryer wont tumble
Your belt is not installed correctly. The weight of the clothes is making it slip.
Jun 30, 2009 | Maytag SDE2606 Electric Dryer
Maytag neptune dryer wont tumble
The standard drive system on all driers is a large belt that fits around the tub. These belt don't last forever and can brake or slip off if warn. It's not a super detailed job for someone with mechanical skills, but it will require braking down the machine to get to the belt.
May 07, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Nov 15, 2007 | Dryers
Frigidaire GLER642A Electric Dryer Logo
54 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
